1970 455 Oldsmobile pilot bushing
Old Jul 12, 2025 | 11:22 AM
Steveg@3224's Avatar
I own a 1970 Rallye 350 with a transplant 455. I installed an America Powertrain Underdash Hydraulic throw out bearing. Im having an issue of setting up the clearance between the bearing and pressure plate. I installed a 1/4 adapter between the bell housing and transmission. Now that i have the clearance correct the input shaft is only in the pilot bearing 3/8 of Inch. I found Mcleod made one for a Pontiac 455 that is the same size 1.38OD. Inner diameter. 0.594 0.954. Has anyone run into this problem? And do you know a better fix or any ideas? Thank you Steveg@3224
Old Jul 12, 2025 | 11:54 AM
2blu442's Avatar
Is your crankshaft drilled for a pilot bearing/bushing?
Bullwinkle
Mar 16, 2023 11:51 AM
Delmont 88 PA
Apr 13, 2022 04:47 PM
Oldsmaniac
Jul 11, 2018 05:54 PM
jsteph
Aug 18, 2017 06:41 AM
olds3442
Aug 20, 2012 10:50 AM
