1968 442 possible purchase
Old Apr 30, 2019 | 11:39 AM
matt506's Avatar
I’m new so be excuse my lack of knowledge of the 442s. I have this car in my sight for purchase but know little of what the body tag says. The vin tells me it is a 442 but the body tag not sure. Need help deciphering. I know it’s from Lansing, black vinyls interior and jade green with gold vinyl top. Also is a holiday 2 dr coup. Am I missing any thing else, am I wrong?Matt
Old Apr 30, 2019 | 11:47 AM
jaunty75's Avatar
If the VIN starts with 344, it's a 442. I don't think the body tag will tell you anything about this. The 33687 says Oldsmobile Cutlass 2-door hardtop, but I don't think the '68 body tags correctly showed the 442 series. I think this is well-documented. What matters is the VIN.
The rest of it decodes as follows:
04D build date - 4th week (D) of April (04), 1968
LAN - Lansing assembly plant
TR 940 - black strato-bucket seats
Paint S - Jade Gold lower body color
Paint 8 - Gold vinyl top (or gold convertible top if a convertible)
Old Apr 30, 2019 | 12:28 PM
matt506's Avatar
Jaunty
yes first 4 digits of the vin are 3448. Thanks for your info it is a hard top too. Matt
Old Apr 30, 2019 | 12:32 PM
jaunty75's Avatar
From the '68 Chassis Service Manual, something you'll want to acquire if you get the car.
Old Apr 30, 2019 | 12:35 PM
OLDSter Ralph's Avatar
Matt, welcome to C.O. Good luck
Old Apr 30, 2019 | 12:50 PM
matt506's Avatar
Thanks Ralph I hope it goes through, Launty thank you too. Going to print it out take with me!
Old Apr 30, 2019 | 12:54 PM
matt506's Avatar
Ok may regret this but here is the vin
344878m358029
Old Apr 30, 2019 | 01:09 PM
Regret what? Welcome to the site. Post some pics when/if it becomes your new to you toy.
Old Apr 30, 2019 | 01:37 PM
rcorrigan5's Avatar
Randy C.
It is a true 4-4-2 as shown in the VIN.
344878M358029: 3=Oldsmobile, 44=4-4-2, 87=holiday coupe (i.e., 2-door hardtop without a post), 8=production year=1968, M=assembly plant=Lansing MI, 358029=assembly plant sequential number.
The data tags on all the '68 4-4-2 cars from Lansing always show 33687. My '68 4-4-2 is a convertible and the data tag shows 33667 but its VIN starts with 344678M. The truth is in the VIN.
Randy C.
Old Apr 30, 2019 | 03:20 PM
matt506's Avatar
oh some places hat it when you post vins and serial numbers didn’t know how it would be received but it is not a problem here which is cool.
Old Apr 30, 2019 | 03:21 PM
matt506's Avatar
Thanks Randy it helps.
Old Apr 30, 2019 | 03:22 PM
matt506's Avatar
[QUOTE=oldcutlass;1170017]Regret what? Welcome to the site. Post some pics when/if it becomes your new to you toy.[/QUOTE
sir oh if I get this I will post lots of pics thanks.
Old Apr 30, 2019 | 06:02 PM
scrappie's Avatar
Welcome and Good luck.
Anymore details about car? Original engine, trans, rear? Whats interior and body like? any options?
Old May 1, 2019 | 04:23 AM
allyolds68's Avatar
Welcome Matt,
The only thing I can add that others haven't is that 940 is black vinyl (which you have already noted) and bucket seat. Depending on how original it is you may also find a Fisher Broadcast card hog ringed to the bottom of the rear set that will tell you what options were installed at Fisher Body
I have an 04C Lansing 442 convertible built 2090 units before yours
Old May 1, 2019 | 09:43 AM
hurst68olds's Avatar
does the car appear to be a 442 with evidence of the original paint / top / trim specified on the tag?
with the assigned Lansing VIN 358029
and the Lansing Fisher Body # 357493 being only 536 units off (~1/2 a day "early")
the closeness/proximity of the two help provide some assurance that the two "belong" to the same car
Old May 1, 2019 | 03:11 PM
matt506's Avatar
Very cool we are so close. Yes the car has a terrible second paint job and at one time had a vinyl roof which is now missing but trim is still there. The bad part is front buckets have been replaced with 1972 cutlass ones but good news is that the rear seat is original and unmolested. Here are some pics. By looking at the fender 442 emblems would this have had the fender strips or not?? They look in the wrong spot but one fender hs been replaced I guess and owner said there were remnants under the paint, what ever that meant.should car have the floor counsel or were many of these just a stick and boot out of floor hole? Matt
Old May 1, 2019 | 03:12 PM
NO fender W36 stripes
Old May 1, 2019 | 03:13 PM
matt506's Avatar
More pics
Old May 1, 2019 | 03:38 PM
allyolds68's Avatar
I sold a console top plate with three holes in the same location a few years ago
Old May 1, 2019 | 05:00 PM
matt506's Avatar
Where you at? Wonder if this is it?
Old May 1, 2019 | 05:14 PM
Looks to be a fun project with a 4speed, that's a blank slate to do as you wish.
Old May 1, 2019 | 05:26 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Welcome. Nice solid car. Plenty of us 68-69 owners here.
The 68 Fremont Z code 442s will have 344 on the cowl tag. Otherwise, as everyone states the rest are like yours 336.
When the bodies were built by Fisher Coach they didn't care if it was a Cutlass or a 442 as its the same body. Why the Fremont car is different? Could have been all the Sonoma Coma going around in the late 60s..lol. No worries. You got a real 68 442.
If the trans matches you have one of 9433 total stick Holiday Coupes made like that in 68. If it was an automatic it's one of 16571. No way to break it down further by colors or options. Check the Block numbers and trans numbers to see if its OEM. The last 6 digits of the vin will be on the block & trans
If your car had the often later added and misplaced W36 fender stripes from the factory the 442 numbers would be located farther back and down a bit from the non W36 cars. This was done so the front edge of the stripe wouldn't be cut off by the wheel well. Why they didn't just move them all to the same rearward location...more Sonoma Coma spose.
I see the oddball (to me) ventless dash. That means you have the kick panel vents.
The twin white dash stripes are missing.
I see a 4 core radiator top plate with the hose bracket broken off. Those are hard to find intact.< Edit it looks more like an HD cooling system top plate. Its just missing the clamp that encompasses the hose then bolts through that reinforcement. The 4 core plate has a J shaped one-piece bracket spot welded on it in which the hose just sits in the J.> Then there is at least another top plate that has neither of these which is on my AC car. Could be more configs? I can't put my hands on the Cooling systems options charts at this moment.
I see a 10 bolt O type rear axle which is correct for a 68. I see some funky spring extenders that's not correct. I don't see a rear sway bar? Are the lower control arms boxed and do you see the holes for the bolts?
Old May 1, 2019 | 10:43 PM
you can see the holes for the sway bar & the welds from the boxes
Old May 2, 2019 | 04:56 AM
matt506's Avatar
Wow so much info and I have yet to pick her up my biggest challenge yet.
I have had chevelles in my younger days so I am somewhat familiar with these GM B body cats, just not the small things on the Oldsmobile cars. From what I understand it should be a 7/8 diameter sway bar in the rear. Nice catch on the holes in the arms, did not notice the boxed lower arms, but aren’t the top ones suppose to be to? They look open. I suspect the spring lift tubes are to compensate for tired springs or are a drag racing thing as the car was modified for raceing.
The tranny and rear are original to the car but rims and motor are long gone I guess. That’s a 68 455 from a big cutlass car.
Old May 2, 2019 | 11:13 AM
allyolds68's Avatar
I think I sold it to a guy named Julius in Alabama or one of the other gulf states but I think he had since sold it too
Old May 2, 2019 | 11:16 AM
matt506's Avatar
Funny this one is from KY so who knows. Can these be fixed? The whole assembly looks extremely expensive to replace.
Old May 2, 2019 | 11:19 AM
allyolds68's Avatar
The upper control arms were not boxed from the factory. They are open to allow rotation so the arms don't bind
Old May 6, 2019 | 12:55 PM
matt506's Avatar
Correct rims?
Ok well down payment is done now more research. Talking to the guy, he thinks the original rims on the car when they bought it looked like the ones I attached a picture of or would they have been SSII rims? Matt
Old May 6, 2019 | 04:29 PM
JohnnyBs68S's Avatar
Congrats on taking the plunge.
What you have pictured are Magnum 500 rims from a Mopar, nearly identical to the SSIs that Olds offered in the mid-late '60s and early '70s. A '68 442 could've been equipped with either SSI or SSII rims, which I believe were optional over the plain steel rims + hubcaps.
Old May 6, 2019 | 04:58 PM
matt506's Avatar
Thanks Johnny I was shooting for a picture of like Buick GS rims but all I could find. Would you happen to have pics of SSI AND SSII rims?
Old May 7, 2019 | 08:26 AM
  #31
The only difference between the SSI and the Magnums you pictured are the center caps (the SSIs have the Olds Rocket symbol). There are a few variations on them, both in size, width and compatibility with factory disk brakes.
SSII are exclusively the grey painted ones. In '68 the area around the holes between the spokes were painted silver, the later years they used a stainless bright silver snap-in trim around the spoke openings. SSIII are basically the same with snap-in SS trim around the spoke openings, but the spokes are typically painted the same color as the car's body. The center caps for both have the Olds Rocket, but the SSII are bolt-in centers while the SSIII can have either bolt-in or snap in centers. There are a few SSII/SSIII wheels that have chromed rims, but most have the stainless trim rings. All SSII and SSIII rims are compatible with factory disk brakes.
Pictures of each and more info at this site.
Old May 7, 2019 | 11:30 AM
  #32
rcorrigan5's Avatar
Randy C.
Here is a pic of the Super Stock I wheel. It will not fit on cars with disc brakes.
This "super stock" wheel (option code P05) was available for A-body cars for the '66 and '67 model years. For the '68 model year, this super stock wheel was supposedly replaced with a new style super stock wheel (also option code P05), the one we now call Super Stock II, where the wheel had a trim ring with a brushed appearance, a screw-on center cap, and the 5 open slots in the wheel were trimmed in silver paint. However, the new style super stock wheel had production issues and there are several instances, noted on this web site, where it is known that some '68 A-bodies came from the assembly plant with the old style Super Stock wheel, the one we now call the Super Stock I. The production issues with the new style Super Stock wheel were resolved in late March 1968. It appears that there became some sort of demand for both style Super Stock wheels so, starting in model year '69, both wheels became officially available and known as Super Stock I (option code P05, wheel code LE) and Super Stock II (option code N66, wheel code LS, the 5 open slots now trimmed in stainless). In the latter part of the '69 production year, a new style of SSI wheel (also option code P05 but with wheel code LY) was made for cars with disc brakes. All of these wheels were 14 X 6. Olds went to a 14 X 7 wheel starting with the '70 production A-body cars, a wheel that I feel has a better appearance because of the deeper dish look, but when I restored both my '68 and '69 4-4-2 convertibles, I had to go with the 14 X 6 SSI to make it authentic.
Randy C.
Stan Shinker
Oct 7, 2019 07:01 AM
Crazy68Cutlass
Jul 29, 2018 06:48 AM
Matt68442
Jun 15, 2018 12:55 PM
Big Features
Mar 28, 2016 07:39 AM
deaddds
Jun 21, 2014 05:43 AM
