1968 442 hei ditributor
Old Jul 10, 2012 | 01:30 AM
Orlando Perez's Avatar
Guys any advice on how too connect the power to the hei distributor i order on ebay it only has two terminals one says ignition and tje other says tach??? Help please
Old Jul 10, 2012 | 03:46 AM
Ignition to 12V source when ignition is on.
Tach to tach pickup lead.
There are probably, without exaggeration, about a hundred threads on this board about how to connect HEI in non-HEI cars, no to mention the threads debating whether or not this is a good idea.
Old Jul 10, 2012 | 06:02 AM
Mike77's Avatar
And you would probably get more question answered if you posted in the correct section. This sections is for introducing yourself to the members of the forum. Hence the title "The Newbie Forum, The place were you should introduce youself and make your first post"
Old Jul 10, 2012 | 11:36 AM
Ok thanks alot .. Eric
Old Jul 10, 2012 | 12:46 PM
FAZ442's Avatar
yea its a real simple install. Make sure you are not using the old wire that was going to the old distributor because it is probably not a full 12 volt source, and that is all it needs. The other wire is just for your tach gauge
joepenoso
Jun 4, 2014 01:56 PM
Redog
Apr 21, 2012 09:04 PM
oldscruiser
Feb 15, 2011 12:44 AM
ctrain22
Aug 11, 2009 02:48 PM
panamracer
Jul 12, 2009 05:57 AM
