1967 w30 air cleaner clearance
I hope some of you 67 W30 guys in your vast wisdom can help me with an issue I'm having. My W30 air shroud sets so high that it touches the hood insulation. Do any of you guys have the same issues? and is that normal? If not, what can be done to create more clearance?
I'm hoping some of you 1967 W30 guys in your vast wisdom can help me with an issue I'm having. My W30 air shroud sets so high that it touches the hood insulation, that doesn't seem right to me. Do any of you have the same problem and what did you do to gain more clearance?
Welcome. I merged your two identical threads. It is neither necessary nor in your own best interest to ask the same question in multiple threads. You'll get a better answer if all responses are kept in a single thread so that incorrect info can be caught and corrected. Good luck.
oldspackrat
January 27th, 2013 07:00 PM
69CutlassAlex
December 2nd, 2011 08:01 AM
