1966 cutlass holiday coupe, 330 high comp
Old Nov 28, 2015 | 11:19 AM
biddlesticks's Avatar
hi everyone this is my first post. I am rebuilding the car I grew up in and need some help finding some parts. my passenger side exhaust manifold is cracked and I am having a hard time finding a replacement. also I am confused as to whether I can buy premade headers that will fit? can anyone help me out?
Old Nov 28, 2015 | 11:43 AM
2blu442's Avatar
Welcome to the site! I can't speak to the header questions, but the manifold should be easy to find here. I've got one in Oregon, depending on your location it might be cheaper to purchase one close by. If you don't need the 1966 casting code but just a small block one that will fit there's likely dozens of members here with spares. Create a parts wanted thread for the manifold with your location asking for one nearby. Or create a new thread asking about the headers with that in the title to help people find your thread.
John
Old Nov 28, 2015 | 12:00 PM
lemoldsnut's Avatar
Welcome this is a great site with lots of helpful people. Many of us have parts for sale and have lots of knowledge as well.
Enjoy
Larry
Old Nov 28, 2015 | 01:23 PM
Welcome, post some pictures of your car when you get a chance. As John and Larry stated a suitable manifold should be no problem. A set of headers on the other hand is. Kooks and American Racing Headers makes them for your sbo powered car. The problem is they are very expensive, $1k+. You may be able to find a set used if your patient and quick as they don't last long when placed for sale.
Old Nov 28, 2015 | 01:40 PM
The 1964-67 Cutlass cars have a frame that is about 1.5" narrower than the one used on the 1968-72 cars. Headers for this application used to be readily available. Unfortunately, given the small demand these days, header manufacturers no longer list headers for this application. There are one or two vendors who do list them, but the price for those is quite high.
Depending on the specific tube routing used, SOME headers made for the 68-72 cars will fit the early ones, possibly with minor "tweaking" in a couple of spots. Others here can probably assist with specific brands and part numbers.
Used stock manifolds should be readily available used from a parts car. Post an ad in the Parts Wanted section.
Old Nov 28, 2015 | 01:43 PM
im in silverdale WA. ill post a parts wanted add thanks for the tips and welcome guys.
Old Dec 2, 2015 | 06:18 PM
zeb's Avatar
zeb
Old Dec 2, 2015 | 07:35 PM
The difference between the sbo and a bbo is height.
Old Dec 4, 2015 | 06:38 AM
Originally Posted by zeb
The difference in frame width on 64/67 A bodies is correct. Also, if I remember correctly, the flat angle of the exhaust manifold to cylinder head was different than the 400 engine. The numbers I seem to recall were 33 degrees & 37 degrees, {if memory serves} So headers for a 400 engine interfere to far inward.
Sorry, but memory does not serve.
There is no difference whatsoever in "flat angle of the exhaust manifold" (whatever that is). All 1964-1990 Olds V8 heads are dimensionally identical on the outside. The exhaust flanges on every single one of those motors is at exactly 45 degrees from vertical. One can interchange BBO and SBO heads and they will bolt up just fine (differences in port size and combustion chamber volume are an internal difference). As noted above, the ONLY external difference between a BBO and an SBO is the extra deck height. This naturally increases the width of the intake (that's called trigonometry). The manifolds/headers are different because the manufacturers have chosen to take advantage of the extra deck height to provide slightly more room for exhaust routing.
Old Dec 4, 2015 | 07:14 AM
lemoldsnut's Avatar
Ok Joe if I understand what you are saying I could take a 350 Olds lets say and bolt up a set of C heads and all will remain the same? What about the intake manifold will it just bolt up with no changes?
Old Dec 4, 2015 | 11:58 AM
EXTERNALLY all will remain the same. The C heads will have 80 cc chambers vs. 64 cc on the SBO heads. The SBO intake will bolt up but there will be a dramatic internal mismatch in the ports. There are SOME SBO intakes with enough meat to be port-matched to BBO heads - the Performer RPM is one such intake. Of course the BBO heads will have larger valves, but valve locations and valvetrain geometry are identical. Exhaust manifolds or headers will also bolt up. This has been done by a lot of people.
Old Dec 4, 2015 | 02:56 PM
RAMBOW's Avatar
Ben
Welcome from another PNWer...
Watch the local seattle craigslist. There is a decent ammount of olds stuff that shows up in the auto parts listsings on a regular basis. Look for someone selling a olds 350 block and ask if you can buy the manifolds (they will be the same for a 330).
You can also buy the thornton reproduction true dual manifolds taht will fit a 350, to get extra flow and eliminate the cross over plug that was on all the factory ones. They are a couple hundred dollars, but are new and should perform better than the factory ones.
Any pics of your 66?
Old Dec 4, 2015 | 03:47 PM
lemoldsnut's Avatar
Thanks Joe. I knew the answer but not able to correctly detail the difference as you can and the previous post by you could have been misunderstood.
Thank you for clearing it up
Larry
Old Dec 5, 2015 | 06:08 AM
Larry
My whole point was to respond to the incorrect comment that there was some dimensional difference in the exhaust flange location. There is not. My response was not intended to be a definitive discussion of the differences between BBO and SBO heads.
Tedisthebestkingintheworl
May 29, 2014 01:43 PM
mike63078
Apr 14, 2013 06:54 PM
Col Wickham
Aug 29, 2009 10:43 PM
64starfire
Jun 1, 2009 10:32 PM
Mr. King
Dec 12, 2007 05:47 AM
