1965 cutlass hesatation off the line
Old July 12th, 2012 | 07:16 AM
yankeelefthook's Avatar
Hello,my name is kelly and i own a 1965 cutlass 442 post car with a 455 engine,my problem is off the line the engine hesatates to the point of stalling if i dont come off the gas,i run a holley 750 dp also have the same problem with the 750 vac secondaries that i have any help would be very nice thank you kelly
Old July 12th, 2012 | 07:20 AM
Welcome - how about some pics!
What distrbutor are you running, whats your timing set to? Is it auto/ standard trans?
Old July 12th, 2012 | 07:28 AM
i am new to the sight i will put pictures up soon,i am useing a msd ready to run distributer it has a 350 turbo timing set around 12 deg
Old July 12th, 2012 | 08:06 AM
What are the spec's of the engine, cam/ compression, stall speed of the torque converter?
Old July 12th, 2012 | 08:28 AM
72 cutlass455's Avatar
Check the excelerator pump on the carb if this is not working you will get hesitation.
Old July 12th, 2012 | 08:42 AM
He said it did it with 2 different carbs.
Old July 12th, 2012 | 09:04 AM
Hmm I see one carb and two hesitation one off the line and one when the vacuum secondaries kick in.
Old July 12th, 2012 | 09:26 AM
I believe it says it does the same thing with a DP'r and a vacuum secondary carb.
70 ctls
March 17th, 2015 09:18 AM
Del70
November 15th, 2013 02:24 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 1965 cutlass hesatation off the line
