1964 Oldsmoblie 98
Old August 11th, 2016, 10:20 AM
Va46CLANSMEN's Avatar
1964 Oldsmoblie 98
I just got an Oldsmoblie 98 on Monday. My Dad had one back in 1974 and I loved it. Looking for things to make it look nicer and some engine work. First is period correct black paint for it. Where to buy. A quart and maybe a spraycan. And who knows those engines? I have all the specs memorized but I don't know which parts are best. I want a different manifold but where to start? 3X2, 2x4? Brand name, open or dual plane? Anything that fits under the hood and I can hide under the big ULTRA HIGH COMPRESSION Air cleaner. Please help. Use this site or email VA46CLANSMEN@YAHOO.COM or text me @ 260-615-6394. My name is Steve Andrews and I just retired from the Military on February 9th 2016. Please help me soon.
Va46CLANSMEN is offline
Old August 11th, 2016, 11:04 AM
Welcome to the site and thanks for your service. Just a note, we do like pictures. I prefer the single carb setups as the multi's are a bit of a pain in the butt to maintain a tune, especially here in Texas with the summer heat. A good dual plane is probably the best route to go and the stock 4v manifold is not bad although it weighs a ton.
oldcutlass is offline
Old August 11th, 2016, 11:30 AM
Multiple carburators.
Old August 11th, 2016, 12:15 PM
D. Yaros's Avatar
Welcome to CO and congrats on your ride!
Others may correct me if I am wrong here, but I suspect the "period correct black paint," called 'ebony' by Olds was an acrylic lacquer? Lacquer is hard to find these days. That said, here is a link with info/refs for Oldsmobile Ebony Black -
http://paintref.com/cgi-bin/chipcrea...del=Oldsmobile
As for "souping up" the engine, as we used to say in the old days, you will find a lot of knowledgeable Oldsmobile hot rodders (mostly muscle car era guys) at this Olds site - http://http://realoldspower.prophpbb.com/
Any 3 x 2 or 2 4 bbl setup would have to be aftermarket. Did find this at Summit Racing -
Have fun and good luck!
D. Yaros is offline
Old August 11th, 2016, 01:10 PM
Your 64 should have a 394 engine and was the last year of production of the first-gen Olds V8 that was introduced for the 1949 model year. The early Olds V8 was a popular hot-rod motor in the 1950s and early 1960s and there are lots of used aftermarket parts still available for it. The factory offered the 3x2 J2 setup in the 1957-58 model years, though that was on the 371 with a shorter deck height. That intake can be made to fit a 394 with spacers. Good luck.
joe_padavano is offline
Old August 12th, 2016, 05:32 AM
Welcome to our site. I used to own a 1964 Oldsmobile 98 Luxury Sedan. It was a cool car but pretty far gone.
If you change your carburetor setup make sure you setup the throttle valve to your Slim Jim Roto Hydramatic correctly. Those transmissions tolerate no slop in the manual throttle valve.
Olds64 is offline
Old August 12th, 2016, 09:40 AM
Don R.'s Avatar
Welcome aboard Steve, congratulations on your good taste in big Oldsmobiles. We would like to see some pictures of your car. If you don't already have one, buy a factory original shop manual set, this is the most valuable resource for any old car. Next, start using the search feature on this forum for all topics you are thinking about, there is a LOT of good info that has already been covered and a lot of experienced people whose knowledge you can draw on. Good luck!
Don R. is offline
Old August 12th, 2016, 10:14 AM
D. Yaros's Avatar
Spotted this today -
2 x 4 link
D. Yaros is offline
Old August 12th, 2016, 01:22 PM
Dave, that is a cool intake and the price isn't too outrageous either. If I still had my 64 98 that would be a cool toy to get.
Olds64 is offline
Old August 12th, 2016, 01:42 PM
There are many, many aftermarket intakes for the first gen Olds V8s.
Old August 12th, 2016, 01:45 PM
More
Old August 14th, 2016, 10:48 AM
D. Yaros's Avatar
Open up your wallet!
Find it right here on CO!
D. Yaros is offline
Old August 15th, 2016, 05:56 AM
Oh yeah!
I bet some of those setups are as rare as hen's teeth.
Olds64 is offline
Old August 16th, 2016, 07:31 AM
Tedd Thompson's Avatar
And if you have deep pockets Ross Racing can and will make you a screamer motor. Talk to Toney he is one of the best on first generation Old's and they make speed equipment....Tedd
https://rossracingengines.oursafeserver.com/
Tedd Thompson is offline
Old August 17th, 2016, 08:17 AM
btw
Smokin' BBQ Member
btw's Avatar
Glad to see you took my advice to come over the CO. World of good advice on this site. Please post up some photos of your 98.
btw is offline
CRH
January 30th, 2018 09:27 PM
64Olds98
May 5th, 2015 06:30 AM
64oldsf85cutlass
Body work
July 4th, 2014 07:06 AM
UnkleScott
November 15th, 2012 01:06 PM
Quick Reply: 1964 Oldsmoblie 98
