1961 98 bogging under load
Old Jul 9, 2011 | 12:11 PM
61olds's Avatar
Question 1961 98 bogging under load
Hi everyone, new guy here. love the site! got a 1961 98 holiday 4 door 4bbl 394. I'll get picture up soon. Original car 26,641 miles when i got it a year and a half ago. now 29,000. runs good until i tromp it,them it falls on its face.whith out any load on it tachs up now ,no hesitation.also when on highway,going up a hill it will cut out or bogg,let off pedal and it will regroup.when i first got car i rebuilt carb,new points,coil,wires,set timing and dwell,advave turns freely with vac. plugs look good (choc brown).I did remove choke lock plate to secondaries .looked after warmed up, like it was sticking.maybe the secondaries are actually hanging up. I hope someone can help me! seems like a lot of smart people here!
Oh! also looking for a rear bumper,doesn't have to be perfect.
Old Jul 9, 2011 | 02:43 PM
Welcome
Welcome aboad
I'm gonna let the timing/carb gurus chime in
Old Jul 10, 2011 | 05:51 AM
Oldsguy's Avatar
Past Administrator
It is possible that the secondaries aren't opening upon demand. I think there is a lock out on the lower plates, at least on the quadrajet i think there is one but not sure about the older gen Rochester on your car. Hope you are able to get it worked out with the help of our members and welcome to our site.
Old Jul 10, 2011 | 06:04 AM
Rickman48's Avatar
When you rebuilt the carb, and installed new needle + seat, did you re-set the float level?
Could be as easy as that.
Old Jul 10, 2011 | 03:29 PM
61olds's Avatar
Took carb apart, found secondary float inverted and hanging levels to be off a little, adjusted and put back together.runs better off the line, but if you stay in it, it will start getting a flat on its face feel, like before but seems to recover quicker.think I will put a fuel pressure gage on to see running pressure.could my fuel line be collapsing?
Old Jul 10, 2011 | 04:27 PM
citcapp's Avatar
Cold also be poor fuel pump performance. You'll find that out with a pressure test
Old Jul 12, 2011 | 05:55 AM
61olds's Avatar
Thanks Citcapp, Clogged filter! checked pressure and had 6 lbs. but low volume.pulled filter had high volume. Yeah!!! She runs Great now. I had pulled the filter an blew through it a couple weeks ago and it was straight thru. I guess the dirt had fallen off when i checked it ,but was getting sucked back up after running for a bit.
Thank You for the responses!
Old Jul 12, 2011 | 06:45 AM
Oldsguy's Avatar
Past Administrator
That is great news! I know you are very happy about correcting that problem. My best friend is an ASE certified mechanic and teaches at a VoTech. Someone like him could probably have hit a home run on the first pitch but hey, that's why we have this site and have members that contribute. Sooner or later we get the job done. Don't be scarce now and keep posting. Let's see some pics of your car too.
Old Jul 12, 2011 | 12:36 PM
61olds's Avatar
Not sure if this is how to put a pic up ,but here goes.
Old Jul 12, 2011 | 01:51 PM
don71's Avatar
same but different
Thats a cool ride, like the background too.
Glad you got the problem solved.
olds 307 and 403
Aug 16, 2015 08:07 PM
jd25q
Jan 31, 2015 01:53 PM
56Holiday88
Nov 4, 2011 12:00 PM
defiant1
Aug 8, 2011 03:27 PM
66ninetyeightls
Aug 23, 2010 12:24 AM
