1955 Holiday 88 power steering
Old Sep 28, 2025 | 02:53 PM
Olds Strong's Avatar
Smile 1955 Holiday 88 power steering
Hello, I have a 1955 Holiday that someone added power steering from a 55 Olds 98. It was a complete change, column, gearbox, and pump. Recently my pump has started to seep fluid and is leaking. Can I switch this over to a Saginaw pump without much difficulty? In other words past obvious things like plumbing, will a new style pump work with the older gearbox?
Old Sep 28, 2025 | 03:00 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Probably could but it is probably easier to overhaul the existing pump. There is not a lot to them.
Old Sep 28, 2025 | 04:17 PM
coldwar's Avatar
Your power steering pump is indeed a Saginaw, a older style. They are easy to service and commonly rebuilt by specialists if you want to send it out. If it is only leaking at the pump shaft, you might pick up a seal and replace it yourself. It takes some patience to remove the pulley but it can be done with common tools on the bench. NAPA had the seal last time I needed one, inexpensive. Oldsmobile specialty supplier Fusick now has the seal for $19.50, a deal:
https://www.fusickautomotiveproducts...sp?number=9664
Best of luck.
Carlarena1
Jun 27, 2024 10:25 PM
friesjh
Jun 12, 2021 08:54 AM
hot-rod.
May 29, 2017 09:49 PM
scharpp
Feb 4, 2015 06:57 AM
Holiday55
Brakes/Hydraulic Systems
Oct 24, 2007 09:29 AM
