1969 Hurst Tribute Resto Mod
Old Nov 19, 2015 | 04:57 PM
ctosiflying's Avatar
Progress on my project after 4 years. Details to follow.
New floor pans and full trunk pan
Just primed
Ready to cut in.
Sikkens Autobase Plus BaseCoat
Sikkens HS Plus Clear
Finally done! Next step, block and buff!
Viking Coil overs and Hotchkis upper and lower arms
Speed hut Guages
Intro Wheels
Old Nov 19, 2015 | 05:34 PM
Beautiful, look forward to following the rest of your build.
Old Nov 19, 2015 | 05:58 PM
Octania's Avatar
Wow, that is nice.
Great work.
Old Nov 19, 2015 | 05:59 PM
Thanks Eric!
The build is as follows...
Stock 1970 low mile Toro 455 iron E Heads home ported. Mark Remmell helped with the hydraulic roller cam and head work. Stock bore. Sean Murphy stage 2 Quadrajet
Performer intake, Headers
Vintage Air
Turbo 400 with FTI 3000 stall and GV overdrive
3:42 Posi
C5 Disc brakes Kore 3 brackets
UMI rotojoint upper and lower adjustable control arms 1" sway bar
Viking adjustable shocks with front coil overs.
Hotchkis control arms 1.25 front sway bar
Iroc steering box
18x7 front 18x9.5 rear Intro Wheels
235-40-18. 275-40-18
Old Nov 19, 2015 | 06:07 PM
Doors looked like they got run over with a Delta 88
After a whole lot of metal work and a skim coat of filler.
Old Nov 19, 2015 | 06:37 PM
wr1970's Avatar
Some very talented work going on.Nice project you have there.
Old Nov 19, 2015 | 06:41 PM
RetroRanger's Avatar
72 Olds CS
wow great work so far love the HO and resto mod combo.
wheels look really nice too all parts choices seem well thought out
what advantage does the coil over up front offer over the traditional shock in spring ?
Old Nov 20, 2015 | 03:20 AM
Thanks guys! RetroRanger, I lowered the rear 1" when I get it all together the coil overs give me the ability to set my ride height and stance easily.
Old Nov 20, 2015 | 07:56 AM
Don R.'s Avatar
Impressive! I'm subscribed.
Old Nov 20, 2015 | 02:30 PM
72 Olds CS
ahh i see very nice then. Do / did you need to reinforce the shock mount area on the LCA or is it stronger on the after market arm ?
Old Nov 20, 2015 | 02:46 PM
No. It's stronger on the AM arm. It's plate not stamped steel.
Old Nov 20, 2015 | 05:38 PM
70vista's Avatar
Very nice looking project you got going. Very nicely detailed. Look forward to seeing the completed car. Steve
Old Nov 21, 2015 | 05:19 AM
rob1960's Avatar
Nice car!!! can't wait to see the end results!! Love the gauges! They "fit" the car much better than the Dakota all digital ones I've seen for our cars.
Old Nov 21, 2015 | 06:21 AM
Yea, Speedhut Guages were easy to work with and customize. I used the 4" Revolution Guages. To mount them I used the cans that the OEM Guages came in and fabricated some extension brackets to fit the bezels on just like O.E. I hate how some aftermarket Guages I see in the forum are just stuck into the bezels and sit almost flush. I wanted a modern twist to the factory look.
Old Nov 23, 2015 | 02:09 PM
salb58's Avatar
Gorgeous through and through. WOW!
Old Nov 23, 2015 | 04:38 PM
Thank you, for the kind words!
Old Nov 23, 2015 | 07:38 PM
Gary's 2 442-S's Avatar
Gary
Very impressive work on your car.
Old Nov 24, 2015 | 08:39 AM
TripDeuces's Avatar
What model Intro wheels are they? They look sharp!
Old Nov 24, 2015 | 02:34 PM
I wish I could tell you. I bought them at the Turky Rod Run in Daytona a few years back. The guy that sold them to me said that they were special ordered and not picked up. I got one heck of a deal....$2000.00 wheels and tires. They look just like the Lime Green 442 that's on the forum except for the bigger windows. I need to find a shop that can machine a new set of center caps that I can add the Olds decal too. Intro won't do it.
Old Dec 3, 2015 | 11:21 AM
A little more progress
Smoothed firewall for the vintage air setup.
Blacked out firewall and bottom of shell and wheel wells.
Old Dec 3, 2015 | 01:56 PM
Paxtonshelby's Avatar
Gorgeous! Now get back in the garage - we want more pics!
Old Dec 13, 2015 | 04:39 PM
Did a little buffing the week end. Shiny!
Old Dec 19, 2015 | 01:33 PM
Waiting for the spring ps to settle.
I know...w27 on a 1969? Hell Yeah!
Finally going back on the frame.
Old Dec 19, 2015 | 10:13 PM
orange442's Avatar
Your car is looking great, you are doing a very nice job on this one!
Old Dec 20, 2015 | 05:09 AM
tru-blue 442's Avatar
Old School Olds
Beeutiful! Nice work!
Old Dec 20, 2015 | 07:45 AM
Octania's Avatar
Overdrive Trans?
Great progress, great pix...
Old Dec 20, 2015 | 09:12 AM
PHP Code:
v
Originally Posted by Octania
Overdrive Trans?
Gear Vendors. Thanks for the comments.
Old Dec 20, 2015 | 03:04 PM
Magna86's Avatar
Man that thing will be sweet once she is all done! Some great meta lwork talent you have there as well!
Old Dec 20, 2015 | 03:54 PM
pacekar's Avatar
very nice work and attention to detail
Old Dec 20, 2015 | 05:57 PM
Awe I'm blushing guys....lol...thanks for the comments.
Old Jan 16, 2016 | 06:49 PM
  #31
A couple of updated photos. Stainless moldings going on and final buff.��
Old Jan 16, 2016 | 06:58 PM
  #32
Gary
It really looks great!
Old Jan 16, 2016 | 08:08 PM
  #33
timholliday's Avatar
Member
Looking good! Definitely ahead of me. How wide did you go with the stripe on the trunk. I see way to many that are too wide, but yours looks just right.
Old Jan 17, 2016 | 08:20 AM
  #34
70vista's Avatar
Smile
Very,Very Nice work!! That is going to be a beauty when done. Paint and body look awesome. Steve
Old Jan 17, 2016 | 08:29 AM
  #35
Beautiful
Old Jan 17, 2016 | 05:19 PM
  #36
Stripe size
I got the original sizes and layout from Jeff Meister complete with the correct radius for the corners. I can post the layout if you guys would like.
Old Jan 17, 2016 | 05:22 PM
  #37
Got the left fender buffed and installed today. Looking more and more like a car every weekend.
Old Jan 17, 2016 | 06:58 PM
  #38
Hurst Olds Stripe template
Template from an original 1969 Hurst Olds
Old Jan 18, 2016 | 09:13 AM
  #39
Joffroi's Avatar
Runner
X2 on those wheels looking sharp! to bad you don't know what model they are.
Old Jan 18, 2016 | 09:31 AM
  #40
Unknown wheels
I know. I looked on Intro's site and couldn't find them.
Maybe they were a custom deal. idk. I just got lucky coming across them at
The Turkey Rod Run.
