refreshing the gold 350
Old May 5, 2013 | 12:24 AM
gbody 442's Avatar
so i tore the 350 down to the short block today and it looked pretty good so i ordered the fel pro gasket set from summit which should be here on the 6th and am going to be regasketing everything. I'm not new to cars but this is the farthest I've been into an engine before so any useful tips on what I'm going to be doing here? (rtv where the pan gasket meets the timing cover, and that type of stuff) and while I'm this far into it should i get a new oil pump just for peace of mind? again ANY tips on this process is greatly appreciated. i really really want this to turn out right the first time and am trying to not unknowingly cut any corners
Old May 5, 2013 | 05:38 AM
DENT's Avatar
Well I sorta did the same thing except I did a cam swap and some head work. The rear main seal was one thing I wanted to do for sure. So fare its all good.
Old May 5, 2013 | 07:22 PM
gbody 442's Avatar
well thats good, hopefully mine goes just as well. how was the rear main seal? as in difficulty and did you take the crank out to do it?
Old May 6, 2013 | 04:44 AM
DENT's Avatar
I removed the main caps and lifted the crank just slightly and slid the new seal in.
Old May 6, 2013 | 07:11 PM
gbody 442's Avatar
ok, seems simple enough. did you use any RTV on it and if so where exactly?
Old May 6, 2013 | 07:59 PM
Are you replacing with a rope seal or a rubber seal?
Old May 6, 2013 | 08:28 PM
gbody 442's Avatar
i ordered the Fel-Pro Gasket Kit # QKS2613, so I'm pretty sure its a rubber seal
Old May 6, 2013 | 08:42 PM
It'll be a rope seal.
The only rubber seals are the Ford 292 seal BS6141 and the AMC/Jeep 258 seal BS13879.
Old May 6, 2013 | 08:47 PM
gbody 442's Avatar
actually, i believe I'm mistaken. i looked it up on summit and took a closer look at the picture and it looks like the oem rope rear main seal, but i might just get a rubber one if theres any major advantages compared to the rope seal
Old May 6, 2013 | 08:51 PM
gbody 442's Avatar
and MD, how should i go about installing the rope seal? like i stated before i really dont wanna have to do this more than once so any advice is greatly appreciated
thanks
Old May 6, 2013 | 08:54 PM
If I recall from my studies of ancient history, you soak it in oil overnight, then push it into the groove. There is an installer that can help keep it from snagging or bending - I assume they still sell them, but if you can get the crank up and eighth of an inch, you probably don't need one.
No sealant if I recall - they're soaked in oil and the ends mush together.
Old May 6, 2013 | 09:06 PM
gbody 442's Avatar
ok seems pretty straightforward. thanks again MD
il be trying to put up a video of it running when I'm done with it, can't wait to hear that olds rumble
Old May 6, 2013 | 09:26 PM
There should also be clear instructions in the CSM about how to do it.
Old May 6, 2013 | 09:47 PM
gbody 442's Avatar
i should probably get one of those for the 72 model year, i have 64,78,80, and 84 an i swear they'll be valuable some day..
Old May 9, 2013 | 09:10 AM
DENT's Avatar
Sorry I didn't get back to you. I used a rubber seal but it seems to be leaking just a bit. Probably something I did wrong. Good luck with yours.
Old May 10, 2013 | 11:57 PM
gbody 442's Avatar
its all good, eh I'm startin at high noon tomorrow, hopefully it'll be running in the car by tuesday (fingers crossed)
Old May 11, 2013 | 12:24 AM
ROCKET VAPOR's Avatar
Lance
IMHO, I would replace not only the oil pump, but I would also replace the freeze plugs if they are older. Also, you might want to consider the timming chain if the engine is suspected to have a lot of miles on it.
Cheap insurance and easy to do while the engine is out of your car.
ddd777
Aug 31, 2023 08:52 AM
miko442
Mar 22, 2015 05:06 PM
theoldsrocket
Paint
Feb 4, 2011 02:52 PM
cutlassKing
Nov 29, 2010 03:05 PM
RAMBOW
Mar 14, 2010 07:44 AM
