1972 Cutlass S Wreck to Resurrect
Old Dec 18, 2010 | 09:00 PM
jlwaller's Avatar
Figured I'd start this post here and I can update as it goes on... and on and on and on.
Background:
1995 - Car was given to me by my great Aunt when I was 10 - she was the original owner.. drove to the bank, grocery store, back home - had 13,000 miles on it in 1995
2002 - Wrecked - clipped and run off the road into a palm tree - parked in a storage yard underneath an oak tree
2010 - Ressurected - finally got enough money to start and make it happen
Old Dec 18, 2010 | 09:04 PM
jlwaller's Avatar
More pics
got the new frame cleaned up
pulled the body (made do with what was available)
married the parts
all 1 car!
Im sure somebody will freak out and how we moved the pieces around - but this is a frame off on a budget lol
Also - got the motor running before the engine transplant
Fired up on the 3rd try (after getting the wiring right - wont run from the key for some reason) and idles smooth as a baby's butt after about 10 min to warm up - not bad for a motor that hasn't been run since 2002!!
Old Dec 19, 2010 | 05:20 AM
bulldog's Avatar
Welcome to the site, looks like you have a great project there with a nice story to go with it. Good Luck with your low budget frame off.
Old Dec 19, 2010 | 05:52 AM
MHENDERSON's Avatar
Good luck welcome and thanks for not crushing it!!
Old Dec 19, 2010 | 06:25 AM
Warhead's Avatar
X2
13K miles in '95.
OMG
Old Dec 19, 2010 | 07:58 AM
Lady72nRob71's Avatar
Wow - impressive! I did not know you could lift the body by the roof without bowing it!
Too bad on the wreck - it was cherry before.
So I assume that the wreck damaged the frame?
Old Dec 19, 2010 | 08:08 AM
Nice work, JL! I really like your technique.
Did you figure out the body's balance point by trial and error, or did you just get lucky?
Take a look at the third pic in the first post for an answer to that question, Rob .
Old Dec 19, 2010 | 08:24 AM
Yea, that was the reason I assumed. However, I figured the control arms or those fragile bolts would have gave before the frame did. I guess all 3 of those could have happened too.
Glad it was repaired right with a new frame.
Old Dec 19, 2010 | 08:31 AM
olds67's Avatar
compliment to the car and the story you wrote.
so it's a family car
Old Dec 19, 2010 | 09:45 AM
don71's Avatar
same but different
Yea, Cool story. The pictures really tell it. You've done a ton of work and its looking good.
Welcome to CO. Good luck.
Old Dec 19, 2010 | 04:18 PM
jlwaller's Avatar
Thanks guys really appreciate it - and I kinda got lucky on the lift point - but was mainly trial and error - the frame buckler pretty bad from the impact - i don't think i took any pictures before i cut up the old frame (talk about bringin a tear to the eye) but the driveline was twisted just a bit and the frame actually crumpled just behind the drivers side body mount.
The body lift you have to use some high quality 4x4's lol - the first we used on the bottom snapped clear in half on the first lift - partially due to the steering arm being bent and not lifting out of place - had to cut it off.
I'll see if I can find a few more pictures too
Regret that wreck everyday of my life lol - doing what I can to correct it tho!
Old Dec 19, 2010 | 06:57 PM
kjr442's Avatar
Kjr442
Things are shaping up nicely. That was a real nice car, I am glad to see you are giving life back to her.
Old Dec 19, 2010 | 07:18 PM
2blu442's Avatar
Hey whatever works! As long as you can safely get the body on and off that's all that matters!
It was a nice looking car, and with some effort will be again. I'm not fond of green, but I do like the shade you've got on yours. John
Old Dec 19, 2010 | 09:22 PM
jlwaller's Avatar
Ya Im looking forward to it for sure - will be posting updates as things get done
Luckily I've got a good buddy who is almost as excited to do it as I am.
travisbeamon
Apr 6, 2013 09:37 AM
rocketraider
Feb 15, 2013 05:17 AM
OldsManNJ
May 2, 2012 05:48 PM
rallye350
Dec 23, 2009 08:11 PM
egknz
Oct 26, 2009 06:06 PM
