1972 Cutlass S Wreck to Resurrect
Figured I'd start this post here and I can update as it goes on... and on and on and on.
Background:
1995 - Car was given to me by my great Aunt when I was 10 - she was the original owner.. drove to the bank, grocery store, back home - had 13,000 miles on it in 1995
2002 - Wrecked - clipped and run off the road into a palm tree - parked in a storage yard underneath an oak tree
2010 - Ressurected - finally got enough money to start and make it happen
Background:
More pics
got the new frame cleaned up
pulled the body (made do with what was available)
married the parts
all 1 car!
Im sure somebody will freak out and how we moved the pieces around - but this is a frame off on a budget lol
Also - got the motor running before the engine transplant
Fired up on the 3rd try (after getting the wiring right - wont run from the key for some reason) and idles smooth as a baby's butt after about 10 min to warm up - not bad for a motor that hasn't been run since 2002!!
married the parts
all 1 car!
Nice work, JL! I really like your technique.
Did you figure out the body's balance point by trial and error, or did you just get lucky?
Take a look at the third pic in the first post for an answer to that question, Rob
.- Eric
Glad it was repaired right with a new frame.
Thanks guys really appreciate it - and I kinda got lucky on the lift point - but was mainly trial and error - the frame buckler pretty bad from the impact - i don't think i took any pictures before i cut up the old frame (talk about bringin a tear to the eye) but the driveline was twisted just a bit and the frame actually crumpled just behind the drivers side body mount.
The body lift you have to use some high quality 4x4's lol - the first we used on the bottom snapped clear in half on the first lift - partially due to the steering arm being bent and not lifting out of place - had to cut it off.
I'll see if I can find a few more pictures too
Regret that wreck everyday of my life lol - doing what I can to correct it tho!
Hey whatever works! As long as you can safely get the body on and off that's all that matters!
It was a nice looking car, and with some effort will be again. I'm not fond of green, but I do like the shade you've got on yours. John
egknz
Oct 26, 2009 06:06 PM
