New Project 67 Trac Pac
Old April 7th, 2010, 04:44 AM
  #41
Trying to remember member
wmachine's Avatar
Originally Posted by gearheads78
Great piece of history to restore. So what's the going rate on plastic 67 fender wells? I happen to have a pair.
Original red plastic 67 wells would be pretty desireable I would think but only came on factory w30 cars and not trac pac cars. They are reproduced as well and the Parts Place sells em. Plain black plastic wells are repoped too and originals would be favored over repops if in good shape. I usually put my stuff on ebay and let the world decide the value.
I don't know for sure the application of the '67 black plastic pieces, I believe they came on Vistas. I don't know if that was all F85 wagons or just Vistas, or just some Vistas, but not all? Part year? Understandably less know than the red variation, and I can only presume more common (greater numbers).
Love the standard steering wheel, Joe!
wmachine is offline
Old April 7th, 2010, 07:10 AM
  #42
66400's Avatar
67 Vistas seem to be the only user of black plastic fender well. Not all Vista had them. I've looked at a dozen plus 67 Vistas and 4 had them. Don't know why, maybe production time built?
By the way the standard steering well only came on the base 67 F85 series, never on a 67 442.
Henry
66400 is offline
Old April 7th, 2010, 07:45 AM
  #43
Cecil Anderson's Avatar
Oldsmaniac--It does not look very new, but my money says it soon will Cheers Andy
Cecil Anderson is offline
Old April 7th, 2010, 07:52 AM
  #44
Oldsmaniac's Avatar
Henry
CORRECT!....one of my not quite stock additions.
Oldsmaniac is offline
Old April 7th, 2010, 08:22 AM
  #45
wmachine's Avatar
Henry
Henry, that mirrors anything I've observed or heard of. Until recently, it never occurred to me to check build dates.
I've not seen any reference to them in Oldsmobile records.
wmachine is offline
Old April 7th, 2010, 01:46 PM
  #46
Birdman's Avatar
very nice project! Keep up the good work
Birdman is offline
Old May 28th, 2010, 07:06 PM
  #47
Oldsmaniac's Avatar
A little more progress, front suspension rebuild, most everything needs new here, bushings, ball joints, springs and shocks. Now if only the grass didnt need cutting so quick..... I would be getting more done!
Old May 29th, 2010, 06:04 AM
  #48
Getting There
Ranzan's Avatar
It looks like it`s coming along Nice Joe
Ranzan is offline
Old May 29th, 2010, 06:26 AM
  #49
Oldsmaniac's Avatar
Thanks Wes!
Old June 21st, 2010, 07:49 AM
  #50
Oldsmaniac's Avatar
Will post some pictures soon. Found a E block and it is in the machine shop for a sleeve in #7 due to rust/pitting and .030 overbore. Front suspension is done. Rear glass channel has been repaired and as soon as I paint this area the glass can go in. Soon I will need to pick a cam. It would be nice to use a factory W-30 cam but everyone says the modern cams have it all over the factory grinds.....
Old June 21st, 2010, 04:36 PM
  #51
Run to Rund's Avatar
cyloinder walls are thick on the E block. Why not bore it more instead of sleeving it? The W30/W31 cams weren't bad at all, but the Comp XE and magnum series are a little better.
Run to Rund is offline
Old June 21st, 2010, 04:49 PM
  #52
therobski's Avatar
Yes indeed the early 400's can be safely bored .057, then use 350 pistons. U can confirm this and alot of other motor info on http://www.442.com/oldsfaq/ofeng.htm...20Big%20Blocks Over an out
therobski is offline
Old June 21st, 2010, 05:30 PM
  #53
olds425's Avatar
That is a really neat car! Love to see it up and going.
olds425 is offline
Old June 21st, 2010, 06:49 PM
  #54
wmachine's Avatar
Every time I see anyone reference the old FAQs, I'll say this again: The FAQs are (and have been for some time) a dead source of information. The live source is now:
http://oldsmobilewiki.com/index.php?title=Main_Page
wmachine is offline
Old June 21st, 2010, 07:07 PM
  #55
Oldsmaniac's Avatar
Originally Posted by Run to Rund
cylinder walls are thick on the E block. Why not bore it more instead of sleeving it? The W30/W31 cams weren't bad at all, but the Comp XE and magnum series are a little better.
I am leaning toward the W-31 cam which has spec's the same as the 67 W-30 cam. The machine shop made the decision to sleeve and I agreed rather than boring all the cylinders excessively right now. I know, or at least read that the E blocks can be bored out to 425 ci and a little beyond so this one will have a few more rebuilds yet I would think. I am also aware of using the 350 pistons. A few pictures of the E block as I got it for 300 bucks.
Old June 21st, 2010, 08:02 PM
  #56
edzolz's Avatar
The black plastic fender wells were installed on some body styles other than Vistas. About two months ago a 67 Cutlass Supreme 4 door hardtop sold and went to Houston that had the black plastic wells. Tho only one I have seen other than vistas that had them. Also the trac pak cars could be had with the red wells. It depended if the customer wanted to buy them. They had a seperate part number (no I don't know it). There is a 67 Trac Pak car in Greenville, TX that I tried to buy years ago. It has Red Wells. Also has factory air and power steering. It has been hit hard in the right front, but not bad enough it couldn't be brought back. The guy still has it and it is now in his barn. He has owned it for over thirty years in this same condition. I keep checking back every now and then to see if it is for sale yet.
edzolz is offline
Old June 21st, 2010, 10:30 PM
  #57
Ben
RAMBOW's Avatar
not sure if it applies to this conversation, but my 66 cutlass has black plastic inner fenders.... 99% sure they are original to the car.
RAMBOW is offline
Old June 22nd, 2010, 05:33 AM
  #58
therobski's Avatar
Thanks WMACHINE that site is new to me, you can still teach an old dog new tricks.....
Old June 22nd, 2010, 05:56 AM
  #59
wmachine's Avatar
Right, some 4-doors ended up with them too.
Yes, there were 4-doors that ended up with the black wells in addition to the wagons.
There are rumors that they red wells could be bought separately. Though the red wells did have a *known* part number, all parts have a part number so that by itself means nothing. I know of no evidence or documentation that they were ever able to be purchased. Unless the car you refer to has something to back up the claim, I still consider the purchase of '67 red wells to be only a rumor.
What is the build date of your car? I have to say it is almost impossible for me to believe that they came on any '66 cars. Primarily because I don't think they tooled for it until well into the '67 model year.
wmachine is offline
Old June 23rd, 2010, 12:28 AM
  #60
Ben
RAMBOW's Avatar
3rd week Feb '66
Its possible they are not original, but you'd have a hard time getting me to believe it based on the history i've got on the car from the original & 2nd owner.
RAMBOW is offline
Old June 27th, 2010, 03:25 PM
  #61
Oldsmaniac's Avatar
Just a little more progress, front suspension and brakes are done. Rear glass can go in!
Old June 27th, 2010, 03:46 PM
  #62
rear glass uses 3M 051135 08610 Windo-Weld kit, .25" x 15' and clips #386.
Old June 27th, 2010, 03:56 PM
  #63
Oldsmaniac's Avatar
Thanks R-R, I have a 1/4 kit that I bought for the front glass but used the 5/16 kit there instead. The clips I have too, matched em up with originals at the last swap.
Old August 4th, 2010, 06:03 PM
  #64
Oldsmaniac's Avatar
Got the engine, E block back from the machine shop. It was bored .o30 and a sleeve in #7. Along with hot tank, magnaflux, core plugs, crank bore alignment check, finsh fit pistons to bores, supplied new pistons press and rod big end resize it cost me just over 1G. I put the cam bearings in and as soon as I wash the reground stick crank it will be ready to go in the block!
Old August 4th, 2010, 07:22 PM
  #65
Oldsmaniac's Avatar
Wink
So with a grand in the block plus the 300 dollar purchase price, add the crank machining, piston purchase, cam bearing purchase, rod and main bearing purchase, cam and lifter and spring purchase, timing set, etc I will have about 2500 out of pocket. I could have bought a chevy crate engine cheaper than that! he he
Old August 4th, 2010, 08:54 PM
  #66
Getting There
Ranzan's Avatar
it would but then it would have been a chev engine and not as Fast
looks great .....
Ranzan is offline
Old August 9th, 2010, 05:45 PM
  #67
Oldsmaniac's Avatar
Not great progress but crank bolted in nicely. Plastigage said .0018 on mains 1-4 and # 5 in the beginning of range. Am anxious to bolt up the rods! It will be a stock rebuild with EGGE original style flat top pistons.
Old August 14th, 2010, 04:33 PM
  #68
Oldsmaniac's Avatar
Got the rods bolted up today, plastigage said all is well. Side clearnaces ok too. Need to buy some more parts now and get the heads done....anyone got any extra cash they dont need?!
Old August 14th, 2010, 04:44 PM
  #69
wmachine's Avatar
:d
wmachine is offline
Old September 16th, 2010, 07:28 PM
  #70
Oldsmaniac's Avatar
It has been a few weeks without an update. The heads are still sitting in my basement waiting for my wallet to catch up some!! Oil pan is on as well as timing cover and balancer. With the swaps coming up I am hoping to score a pressure plate and disc at a good price. I have been cleaning the stock intake for installation and need to rebuild the quadrajet but I may just start out with the quad from a 67 Toro that has already been rebuilt and run tested... I have also been cleaning and painting the front wheel wells. I hope to get a few pictures soon.
Old September 16th, 2010, 09:17 PM
  #71
Getting There
Ranzan's Avatar
Get er done Joe ..............
I still can`t believe you scored a trac pac car..... shaking head lol
post pics when you can
Ranzan is offline
Old September 17th, 2010, 04:18 PM
  #72
One part at a time
67 442's Avatar
I will be watching this thread, it should be a good one! Love those A bodies!
67 442 is offline
Old September 17th, 2010, 05:25 PM
  #73
Oldsmaniac's Avatar
A few picts, lots of time and cash still needed.
Old September 17th, 2010, 06:28 PM
  #74
Oldsmaniac's Avatar
A few more pictures as when I got it.
Old September 17th, 2010, 06:32 PM
  #75
Oldsmaniac's Avatar
A few more.
Old September 19th, 2010, 05:24 PM
  #76
Oldsmaniac's Avatar
Since everyone loves pictures here is the last of the ones I took when I got her home.
Old September 19th, 2010, 05:36 PM
  #77
Oldsmaniac's Avatar
Lastly
Old October 3rd, 2010, 05:44 PM
  #78
Oldsmaniac's Avatar
Funny, a picture of how NOT to change a heater fan motor. Found this when I got the car home. Got some work to do on the passenger fender. Scored a new pressure plate (11 inch diaphram) and disc and bearing at Etown swap for 50 bucks. Its a Power Brute by Hays I think.
Old October 3rd, 2010, 05:51 PM
  #79
Getting There
Ranzan's Avatar
wow that third pic is of the top of the fender near the cowl???? what the heck did they drop on it???? looks like some good old redneck repairs on the old girl
Ranzan is offline
Old October 3rd, 2010, 06:36 PM
  #80
Oldsmaniac's Avatar
Wes, it looks like something heavy fell on the top of the fender. I ground major bondo out of this area. Will bang the dent out and weld up the slide hammer holes. Then the bottom needs a patch. There was a surface patch here and lots of bondo. I can do better than that. Another disappointment was that the 442 hood is shot. Bracing has come loose from top and the whole hood is like an oilcan and its pretty wavy. A few years ago I got a nice hood for 75 bucks at a swap so I am good to go for a hood.
Quick Reply: New Project 67 Trac Pac
