1971 442 Convertible Restoration
Old Jan 11, 2021 | 05:27 PM
HorseCollar's Avatar
Just getting started on this convertible. I had been searching for a first gen convertible when a friend told me about this car. It's rusty but a good project. I'm going to restore it the best I can. This will be my first frame off. Let's get started.
The car is numbers matching, with AC, PS, PB, auto w/dual gate, and 3.08 anti spin rear. The body is going to require a lot of work to sort out. The car looks like someone did a bondo and spray can job on it a while back. The quarters are shot and the fenders are rusted at the bottom. There's a cutlass supreme grill on it from a previous incident. By the way, are those 70 fenders? It's a huge relief to see the amount of expert knowledge on this site. I'm looking forward to this adventure.
Rich
Intro post:
https://classicoldsmobile.com/forums...ew-guy-151367/
She's in.
She's up
3.08 posi. Looks like somebody buffed that axle tube, I had to use brake cleaner to get through the protective layer of grime.
Passenger side front and drivers rear floor pans need to be patched. Otherwise, not too bad.
Small rusty area there.
Driver side rear floor pan.
Oddly clean frame in some areas.
In the market for a clean trunk lid.
Old Jan 16, 2021 | 07:29 AM
Got the fenders off. The fenders look good other than the lowers. Tons of **** in the drivers side cowl.
Drivers lower cowl.
That is the contents of the driver side cowl.
Old Jan 16, 2021 | 07:46 AM
RetroRanger's Avatar
72 Olds CS
Looks like you got a good start on it!
the fenders are in surprisingly better shape than ithought they would be.
Old Jan 16, 2021 | 06:27 PM
Funkwagon455's Avatar
Originally Posted by HorseCollar. Tons of **** in the drivers side cowl.
Pretty typical, I had to rebuild the drivers side on my California car. Prepare to get a little dirty..
[img
https://cimg0.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x971/20210114_181846_ac208acc26bfbc56809fb8613cf6d4e00b f380ad.jpg[/img]
Drivers lower cowl.
Old Jan 19, 2021 | 07:24 AM
Was able to get the engine out last night. Took a bit of a juggling act to get the engine stand and the engine hoist to cooperate.
Hoist and stand not compatible.
Old Jan 19, 2021 | 07:38 AM
72 Olds CS
The hoist wouldnt go highenough to get it on the engine ? Good thing you took out the rad support first !
Old Jan 19, 2021 | 07:45 AM
If the boom on your hoist did not have enough arm, I believe I would have gotten creative. IE: lower the chassis. I guess it is a moot issue since it’s all coming apart anyway!
Edit: I see, your hoist interferes with the engine stand (blocks under hoist legs). I have encountered this as well with one of my storage dollies.. Annoying
Old Jan 19, 2021 | 08:14 AM
No, it came out fine.
It was the legs on the hoist that wouldn't let me get closer than a foot and half to the engine stand once I had it out. I had to put the engine down, chock the hoist legs up high enough to get the engine stand legs under the hoist legs, and pick it up again to get it close enough to connect.
Old Jan 19, 2021 | 08:31 AM
babailey's Avatar
I’m glad you took pictures of that. I’m about to pull my engine and it looks like I have very similar hoist and stand.
scrappie
Jun 4, 2025 02:46 PM
zeeke
Aug 21, 2023 02:23 PM
HorseCollar
Dec 21, 2020 04:53 AM
gearheads78
Dec 7, 2017 07:16 PM
Mattb
May 15, 2017 06:57 PM
