New member 1972 cutlass build.
Old December 2nd, 2018, 08:05 PM
tyler1972's Avatar
Talking New member 1972 cutlass build.
Hey everyone, just want to share my winter project, this 1972 cutlass, we're separating the body from the chassis to fix some major frame rust as well as repairing some floor pan rust. also we're ditching the factory 350/350 combo to a built 455/2004r combo we built last winter.
I'll get some more pictures as i go along. thanks for looking
tyler1972 is offline
Old December 2nd, 2018, 08:11 PM
same but different
don71's Avatar
Welcome Tyler, Look forward to your progress.
don71 is offline
Old December 6th, 2018, 09:30 PM
tyler1972's Avatar
Thanks alot!
over the last couple days we got the rear bumper and tank dropped, and pulled most of the interior out:
The floor pan was alot worse than I originally anticipated, i new the cross members, and mounts were bad from underneath, however once the carpet was removed it showed some amateur repair jobs and more rust
So i welded in some cross members to help keep things square when I lift the body... with the floor in the shape its in it makes me nervous.
Just used some old angle iron.. nothing to fancy.. (old bed frame LOL)
Hoping to have the body lifted this weekend...
Old December 7th, 2018, 06:54 PM
72 Olds CS
RetroRanger's Avatar
lol i saved a couple old bedframes for stuff just like this !!!
RetroRanger is offline
Old December 8th, 2018, 03:22 PM
Olds Fever
CRUZN 66's Avatar
Welcome to the group... Looking forward to seeing the end result... Good luck with the project...
CRUZN 66 is offline
Old December 10th, 2018, 09:25 PM
tyler1972's Avatar
Thanks!
worst part about separating them was the bolts all either broke off or spun out.. took at least a couple hours just to get all the bolts out.
next up is to figure the extent of the rust on the frame and floor and take it from there.
Over the weeked I got the body lifted, went a lot easier than i anticipated thankfully.
Old December 30th, 2018, 07:33 PM
tyler1972's Avatar
Had some time off over the holidays to get the frame stripped down and get an idea of the extent of the rust. it was about as bad as i expected.
the biggest surprise was this terrible attempt at fixing the rust on the frame.. looks like sheet metal!!??
also found some rust in a few other spots.
so for the next day im going to soak the frame in oven cleaner then bring it to the car wash to get as much of the crud and rust off as possible before i wire wheel it off.
hoping to have the frame washed off new years day!
Old December 30th, 2018, 10:36 PM
Chevy budget Olds powered
coppercutlass's Avatar
your rust could have been worse lol. Looks like a solid starting point to be honest and its headed I the right direction. I only say solid because I had a Wisconsin car in which the roof is about the only original panel left so to speak.
coppercutlass is offline
Old December 31st, 2018, 05:22 AM
Frisbee_k9's Avatar
Welcome.
This is great project you're doing. Please keep posting pictures because I have garage envy.
Guy
Frisbee_k9 is online now
Old January 2nd, 2019, 08:15 PM
tyler1972's Avatar
I live up in Canada, the salt and calcium they use in the winter rusts everything here as well LOL, Its reassuring knowing that people have built them from worst though.
Originally Posted by Frisbee_k9
Welcome.
Guy
Thanks alot! our shop is actually a old hog barn we've been adding tools to over the years.
Old November 4th, 2020, 09:33 AM
tyler1972's Avatar
Sorry guys, been busy with other customer builds for the last year. But I’m back on mine!
picked up a 70 cutlass supreme bondo buggy, the body is pretty much done but it has a solid frame.
between my 72’ and this one I should be able to build one solid car.
Old December 13th, 2020, 06:04 PM
tyler1972's Avatar
Lifted the body off the chassis this week, everything went as planned
Cleaned the frame up as best I could with grinders and wire wheels.
Pulled the diff from a donor car... it’s still a 10 bolt but it’s a 3.55 posi
Got a bunch of new parts delivered as well, excited to get them all in
Got a 12.7:1 box in too
Old December 14th, 2020, 07:15 AM
72 Olds CS
Nice batch of parts, should keep you busy over the upcoming holidays
Old December 14th, 2020, 01:52 PM
tyler1972's Avatar
Thanks, around my area everything is locked down due to COVID so there’s not much else to do but catch up on my projects over the holidays.
Old December 14th, 2020, 04:51 PM
That's a good looking dog you have as a helper.
Fun71 is offline
Old December 21st, 2020, 06:01 PM
tyler1972's Avatar
While I have the frame out and bare I thought I’d spend a little time to stiffen it up.. I want the car to handle whatever I throw in it in the future.
Old December 22nd, 2020, 04:20 AM
Coming right along- Good Job!
Greg Rogers is offline
Old December 26th, 2020, 09:35 PM
tyler1972's Avatar
finished getting the frame bracing all fabbed up and welded in this weekend, time to give I a coat of paint and bolting things together
Old December 27th, 2020, 07:22 AM
72 Olds CS
What about the trans crossmember? Will it still fit w the braceing?
Old December 27th, 2020, 02:48 PM
Just saw this thread. Where in Edmonton are you? funny you did exactly what I first thought when I saw the original rotted frame. BTW, that donor is a 1971 CS by the look of the front clip. What factory produced your car? The VIN should tell you. My guess is either Lansing or Fremont. If the VIN starts out 3G87H2M it's Lansing. If it starts 3G87H2Z it's Fremont. I also have a 72 Cutlass S that I just got back on the road this past August. My VIN is 3G87H2M208783. Is that close to yours? I'm just curious.
You probably already have looked at the changes you'll need to make for the installation of the 455/200R4? Those 3.55 gears should give you pretty good launch. I changed my differential from an SA (2.73:1 open) to a 3.42 posi as part of my build. Still have some minor tweaking to do but I retained my 350/350 combo with the only upgrades being from 2bbl to 4bbl and installation of HEI.
BTW check your cowl tag. I'm really curious to know if your PNT code is 19 19. That would have been a special order for 1972
Allan R is offline
Old December 27th, 2020, 04:49 PM
tyler1972's Avatar
no, I'm planning on building one once i drop the engine/trans into the car. that's also why there is no cross bars in the front yet.
I'm actually about a half hour east of Edmonton by Chapman. next time im at the shop ill snap some pictures of the vin for you. as for the swap i actually had 455/2004r combo swapped in a 68' delta 88 for a couple years. i built the motor in 2015, probably has less that 5000km on it
Old December 27th, 2020, 07:39 PM
Did you mean Chipman?
Re: cross member. There are already holes in the frame to move the existing cross member to the right position. Use the further back set, same as for the TH400. You'll be able to keep the same driveshaft as the TH350 for the 200R4
Allan R is offline
Old December 27th, 2020, 08:37 PM
tyler1972's Avatar
yes sir, chipman, where are you located? and for the trans mount the factory holes wont work for me now that the frame is boxed and has the supports
Old December 28th, 2020, 09:04 AM
Right you are, forgot about the boxing in there. You'll figure it out because the holes are still in the bottom of the frame to show positions, so likely just a modification with brackets on the inside of the new framerail? With that boxed in frame you'll also have to reposition the brake and fuel lines a bit. Are you making your own custom lines?
Went back and looked at the first pictures you posted. There's no build sheet on top of the tank so likely your car is a Lansing car like mine. Fremont, Arlington and Framingham stuck them up there for whatever reason.
With all the mods you're doing to the frame, (and guessing brakes too) I gotta ask what are your plans for the finished product? Pro touring?
I'm in Edmonton Castlebrook very north end of the city - hop and skip from exit 39 on the Henday.
Allan R is offline
Old December 28th, 2020, 03:13 PM
409sleepr's Avatar
Greetings, I'm kind of a new member myself
Just a short note to say hello and welcome to the group , you have a nice car there . my car is a 1965 Cutlass a work in progress . I looking at doing the front suspension and ball joints soon .. they all seem to need something .
work in progress
409sleepr is offline
Old December 28th, 2020, 09:41 PM
tyler1972's Avatar
unfortunately I looked all over for build sheet on both cars but couldn’t find them.. they’ve both been gone through so many times by so many different hands... lost to time I guess.
and honestly I just want a solid do anything car... just simple solid car I can drive anywhere and do anything.. only reason I boxed the frame and stiffened was because I already had it out and dropped.. now or never right?
and I know the area well my in laws live there!
work in progress
Thanks! That’s a beautiful car, looks super clean, what engine does that have the 330?
Old December 31st, 2020, 05:37 PM
tyler1972's Avatar
got the frame primed and painted, and started assembling the front end.. new lower control arm bushings, new tubular uppers, and new heavy duty springs (with a coil cut).
Old January 1st, 2021, 09:32 PM
tyler1972's Avatar
finished getting the rest of the parts in the front end, new proforged tie rod sleeves and the polyurethane sway bar links and bushings.
also, built frame supports for the rear.. everywhere I looked they were 150-200 buck.. built these from some thick wall 3/4” pipe I had on the metal rack.. saved a few bucks.
Old January 2nd, 2021, 07:42 AM
72 Olds CS
Nice work on the rearframe braces.
is that the original fr sway bar?
Old January 2nd, 2021, 09:01 AM
tyler1972's Avatar
Thank you!
and yes, it is the original front sway bar. Unfortunately, it’s just not in the budget this year to upgrade it. The interior of the car still needs attention and I haven’t started on the body.. It something I can easily swap in the future so I’m trying to save a few bucks where I can.
Old January 15th, 2021, 11:42 PM
  #31
tyler1972's Avatar
So I was told I had a BOP 8.2 posi 3.55.. turned out to be a 2.73. But the parts car had a corporate 8.5 so with some junk parts I had in the back and a intake kit from a local shop I have a gov lock 3.42... not sure how the gov lock is goi f to work on the street.. but I have to try it
Old January 16th, 2021, 08:54 PM
  #32
tyler1972's Avatar
Ended up cutting the whole trunk pan and cross braces out of the donor car and welding them into ours.. thankful to have this car..
Welded the front mounts and cross mounts into our car. I have new floor pans to install next
Started fabbing the other trunk into ours.. got it all roughly welded in.. just have to finish the welding.
Got all the bmr control arms and lowering coils in the rear, and energy suspension poly body mount kit.. all quality products highly recommend.
Also lowered the car and bolted it to the chassis.. after all the floor and frame modifications it was time for a test for before I continue..
luckily other than the stiffening bars just kissing the rear floor pan, everything lined up 100%.. I’ll weld in the new floor pans next then pull the body back off to seal/paint the underside, as well as touch up the paint on the frame..
next up I have a few minor tweaks to the powertrain.
Old January 18th, 2021, 02:51 PM
  #33
tyler1972's Avatar
Cut out most of the old floor pan
Got a new one in the one side
Unfortunately ran out of welding materials to finish the other side, hope to get the other half done this week..
Going through the old 455.. it was from a 68.. big valve “c” heads, 30 over rebuild in 2014 (been in storage since 2016) the deck to piston is .030.. and the pistons are 13cc dish.. with the .040” head gasket and 80cc “c”heads I believe my compression will be 9.5:1.. considering sending the heads to a friend of mine to get them milled to bring that comp closer to the mid 10s
Old January 24th, 2021, 09:38 PM
  #34
tyler1972's Avatar
Got the heads back from milling .050 off..
New head gaskets.. between everything should have a compression of 10.3:1
Got my frame braces in
As well as the rear sway bar
Finished getting the engine together
Bolted up just as it should..
And mounted the trans.. next up I have to build up a new cross member..
Old January 25th, 2021, 07:21 AM
  #35
72 Olds CS
Looking good! Engines are so much easier to put in w no body to worry about!
i think the dog approves too!
Old January 27th, 2021, 03:39 PM
  #36
gear head's Avatar
Good looking project, I like it.
gear head is offline
Old January 27th, 2021, 07:07 PM
  #37
tyler1972's Avatar
thanks! I don’t do anything without my helpers in the shop.
thank you!
Old January 27th, 2021, 07:12 PM
  #38
tyler1972's Avatar
Little reworking of the original trans mount turned out well, very happy with how this turned out. Also got the headers in. Just have a couple more small things to finish up on the chassis then we’ll be dropping the body on
Old January 30th, 2021, 08:01 PM
  #39
tyler1972's Avatar
got the car lowered back onto the chassis today, hopefully for a very very long time now. Still have a long way to go but I’m starting to feel like we’re making progress.
Old January 31st, 2021, 06:30 PM
  #40
tyler1972's Avatar
little more progress this Sunday. The right rear quarter was pretty rough.. the left rear has been replaced.. I can definitely work with it. Right now I couldn’t find any stock on the right quarter! After about a week of searching I found one in Saskatoon
Quick Reply: New member 1972 cutlass build.
