1970 Cutlass Problems With First Start After Complete Engine Rebuild
Old December 6th, 2017, 10:28 PM
oldscutlass74's Avatar
So I have a 1970 Cutlass (to be specific, the block is '70 and the heads are '72 7A's) 350 4bbl. I rebuilt the engine with pretty much all new parts except for the valve train. This is my first time doing a rebuild so I'm learning as I go. The car turns over, sounds like it wants to start but won't start up. I set piston 1 to TDC, I get a lot of backfire and coughing depending on where I have the rotor pointing (I've tried pointing it in different directions trying to find the right spot to start it up). Any suggestions would be appreciated. Thank you!
oldscutlass74 is offline
Old December 7th, 2017, 02:40 AM
Double check your firing order and determine if the distributor is 180* out.
oldcutlass is offline
Old December 7th, 2017, 04:03 AM
scrappie's Avatar
Might be a good idea also to list exactly everything you did on the rebuild. Timing is a common culprit but other things may have changed if heads were planed or block decked. Remember Dist turns counter clockwise also.
scrappie is offline
New'n72
August 25th, 2020 11:36 AM
chasman414
June 25th, 2020 07:05 AM
pfergy600
February 23rd, 2015 06:44 PM
Jonmueller1
December 20th, 2013 07:27 AM
emarkay
December 8th, 2004 08:23 AM
Quick Reply: 1970 Cutlass Problems With First Start After Complete Engine Rebuild
