What to keep and what to get rid of?
Old Apr 23, 2015 | 12:07 AM
TrippNGolfBallz's Avatar
I have a 4 dr 87 cutlass and i put in a 73 olds 350 engine in. Im also in Arizona and seeking advise on what to keep on the engine and what to get rid off like smog parts, vacuum lines, etc...
Old Apr 23, 2015 | 06:17 AM
Welcome to the site. What to keep depends on whether your going to run it on 87 or 73 model year specs. I'm not familiar with Arizona emissions requirements.
Old Apr 23, 2015 | 09:20 PM
I want to get close to 73 specs to have a clean look with out all the vacuum lines.
Old Apr 24, 2015 | 01:40 AM
nsnarsk65cutlass's Avatar
Then use 73 specs.
Old Apr 24, 2015 | 06:56 AM
hookem horns's Avatar
First, I assume you are emmissions exempt or all bets are off. Everything the factory used had a purpose, so decide what options/funstionality on the 87 you want to keep compared to cleaning out the engine bay. AC takes up a bunch of under hood space but is pretty important in AZ for example
EGR (if still there after the swap) could go. Bare minimum for the '73 would probably be PCV (and opposite side vent), vac for distributor advance, vac for brake booster and vac for transmission. Since you are in AZ, could use an electric choke and eliminate all warm up stuff.
Old Apr 24, 2015 | 01:11 PM
Keep the sensors from the 307 for oil pressure and water temp so your stock gauges work.
MattD
Aug 13, 2011 07:55 AM
OldsVentura
Apr 10, 2009 01:43 PM
gearheads78
May 28, 2008 08:38 AM
tex70
Feb 14, 2007 09:49 PM
