The underside of my roller rockers
Old Jun 29, 2017 | 01:30 PM
boese1978's Avatar
Hey all, Been waiting for a response from Scorpion, in the meantime I thought I would ask here- what caused this wear and should I re-use these rockers? 68 350
Thanks for the thoughts.
Old Jun 29, 2017 | 01:35 PM
Your picture is too small
Old Jun 29, 2017 | 02:42 PM
boese1978's Avatar
See the shiny "circle" in the middle of the underside where the stud goes through? That was all the blue color before installation.....let me know if that makes sense please.
TY!!
Old Jun 29, 2017 | 03:11 PM
The wear is not normal. what do the studs look like?
Old Jun 29, 2017 | 03:54 PM
boese1978's Avatar
The more I look at these I am beginning to think my machinist ( I think I mentioned before he has lost much of his mental capacity and therefore I can not confirm) may have "machined" them to clear because there is not a single mark on any of the studs nor is there any evidence of blue aluminum on the inside of the heads. I guess that being said it makes me wonder why some are machined more than another- although most are very close in appearance to the naked eye. I have tried putting them on the same stud they came from and there is nothing rubbing or touching even when twisting the rocker while rocking it, not even close and I can see clearance between bottom of rocker and stud nut , thoughts? Thanks!
Old Jun 29, 2017 | 04:36 PM
Qwik71442's Avatar
Full-time Taxpayer
Pushrod too short? I would re-mock it up and verify the witness mark the rocker is leaving on the valvestem via a sharpie. You want the the tightest or narrowest pattern anywhere from the center to slightly on the exhaust side of the valve stem. I personally wouldn't let it ride anywhere on the intake side of the valvestem. Do this while checking for clearance at the rocker to the retainer and the rocker to bottom of the stud during the complete revolution of the camshaft.
Old Jun 29, 2017 | 06:05 PM
boese1978's Avatar
Each valve , save the 5 scarred up ones, has a nice tight, middle of the valve stem, even "wear mark".
Old Jun 29, 2017 | 09:03 PM
steverw's Avatar
Someone on here had the same problem with Harland Sharp rockers as well, a couple of years ago. So when i got my HS rockers i discussed with Mark/cutlassefi we decided i should remove the same on them, so i did. No problems to date that im aware of. As i recall the other member did the same after seeing that the studs started the process for him. Sorry i cannot remember who it was.
OldSkoolFool
Jun 19, 2010 07:19 PM
nelsontj
May 6, 2010 03:04 PM
scr8p
Feb 22, 2010 08:44 PM
tpawlik
Apr 28, 2009 07:09 AM
Redog
Aug 14, 2008 06:56 PM
