tie rod question
tie rod question
Ok now iam half way done with my front end rebuild kit i used tie rod puller to disconect the linkage from the center link just curious when its time to connect the linkage back to the center link do the tie rods need to be pressed back on or will the screw do the job as i tighten it up and for the controll arms i have them off but before i replace bushings how do i remove the long bolt that goes through the top of the controll arms ?
ok thanks but how do i press the the tie rods back on i used a tie rod removal tool to get them off not sure if it will be that easy pressing them back on
my bad you are refering to the tie rods , but his thread also covers that portion to
To re-reiterate:
Place tie rod tapered shaft in hole, screw nut onto shaft, tighten, place cotter pin in position, and bend.
REMEMBER, the tie rod taper and the hole MUST be perfectly clean - grit and grease-free.
If not, the connection can loosen, causing failure and misfortune.
Remember to get the right and left handed cotter pins in their respective positions and to use the correct technique when bending them.
Thread the new tie rod ends into the adjusting sleeves the same number of turns as the old ones to keep the toe somewhere near right until you can get it aligned.
Coat the tie rod end threads with a thin film of chassis grease before installing them and it makes them a lot easier to adjust and also keeps the ends from eventually seizing up in the sleeves.
Don't tighten up the control arm shaft end nuts or the lower control attaching nuts and bolts until the car is lowered with it's full weight on the suspension including the engine or the bushings will bind up. Once it's on the ground you jounce the front end a few times to settle everything then tighten them to specs.
You can put the tie rods on when the resto of the suspension is assembled (and wheels still off.
Keep in mind when tightening the tie rod end nuts - you must torque them with a torque wrench. The manual will give a wide range - for a reason. Torque them to the lower number and try to put the pin in. If it is not aligned, keep tightening slowly just until the pin can be inserted. NEVER loosen.
My front end rebuild thread is linked below for reference... Lower bushings were removed somewhat easily, the uppers were a cinch!
Looks like the factory did all mine WRONG!
just bend the cotter pin over , good god ! while you're at it ya better change that old air in the tires too actually that does look nice though
Damn... I greased my tie rod tapers a bit. Guess will have to remove and wipe clean. Everything is loose right now anyway... well except for my pass. side upper/lower ball joints/tapers which I already torqued.
72cutlassolds:the specs for torquing your suspension are in the 72 CSM on page 9-8 of this link: http://wildaboutcarsonline.com/membe...Section_9A.pdf
oldzy
June 12th, 2011 08:24 PM
amphicar770
January 18th, 2010 02:02 PM
amphicar770
January 16th, 2010 06:44 PM
