shes finally legal
Old February 17th, 2015, 10:43 AM
  #41
Justin
oldstata's Avatar
Bill take a pic of the fuel leak I am not understanding where it's leaking from. From my experience witch is limited to carbs. Float adjustment only helps bowl over flow from my understanding you might be leaking from the carb base witch could be a easy fix
oldstata is offline
Old February 17th, 2015, 11:54 AM
  #42
I had a 2-Jet that leaked out the shafts when I was a kid.
Did it for a couple of years.
Rebuilt it once or twice, ended up swapping it for a QuadraJet, 'cause I thought it'd make the car go faster.
Never did figure out exactly why it did that, but I really didn't care much, either.
Looking back, there had to be a leak in the bottom of the float bowl, maybe a crack, maybe a porous spot, probably not a bad gasket.
It's worth taking it apart, plugging the jets, filling the float bowl, and seeing where the gas comes out.
MDchanic is offline
Old February 17th, 2015, 01:29 PM
  #43
major noob
billmerbach's Avatar
Ok and will do may be a few days and how do I properly adjust a detent cable as far as hooking it to the carb etc cause I feel that's where I'm loosing a little bit of my power is the tranny not shifting at the proper intervals cause ik I didn't adjust it right
billmerbach is offline
Old February 17th, 2015, 04:07 PM
  #44
Chevy budget Olds powered
coppercutlass's Avatar
The detent cable does not affect upshifts it only controls downshifts. The ahift points are controlled by the modulator (to some extent) right rear of the trans . New one is like 15 bucks for a red stripe its adjustable you can dial in the shift points. You can also change the wheights and springs in the governor . Ultimately a shift kit will change your shift points all together along with line pressure . The only external thing you can do the change the shift points is the modulator.
coppercutlass is offline
Old February 17th, 2015, 04:10 PM
  #45
major noob
That's what I thought but I still wasn't sure.....ok on that note why aren't my shifts consistent then could it be in the modulator cause the trans has been rebuilt with shift kit installed.
  #46
major noob
I mean it isn't that the shifts are bad and hard they just don't always occur consistently if that makes any sense
Old February 17th, 2015, 04:18 PM
  #47
major noob
Ok cause yea my car really don't shift till bout 30 mph and that ultimately scares me
Old February 17th, 2015, 04:27 PM
  #48
if it does not shift from 1 to 2 until 30 then it could be one of two things. #1 you have a 2.56 or some 2 series gear where it takes some time for it to shift but if its reving up at 30 and not shifting then its (#2) the modulator . Do you have the vacuum line hooked up from the modulator to the intake ?
Old February 17th, 2015, 04:33 PM
  #49
major noob
Yea its to the intake and apparently haven't gotten to check this but I have 3.73 or something like that gears which I think is the case by the way it will throw you in your seat cause really I don't have but stock torque numbers and I don't think those would be enough to throw you and spin tires but then again I'm learning so I may be wrong
66 Olznut
September 23rd, 2008 06:34 PM
ddusty1
June 7th, 2008 08:30 AM
ddusty1
May 29th, 2008 04:43 AM
Starfire61
March 24th, 2008 06:01 AM
cutlasssupreme442
August 17th, 2006 08:47 PM
Quick Reply: shes finally legal
