SBO 350 Refresh
Old May 2, 2011 | 08:20 PM
defiant1's Avatar
SBO 350 Refresh
Well, figured I would post pics before I get the motor completely installed. I forgot to take pics while it was on the engine stand. But, it is what it is. I hope it runs as good as it looks (IMHO) .
Here are a few before pics:
Old May 2, 2011 | 08:22 PM
defiant1's Avatar
Here are a few after pics:
Old May 2, 2011 | 08:32 PM
defiant1's Avatar
And a few more after pics:
The base motor color is Seymour EN66. It is called AMC Blue Poly. I was fooled by an internet picture due to the lighting. In the pic it looked like a dead ringer for 455 blue metallic. But it has a more aqua/green tint to it. It is growing on me.
Valve covers, intake, basically anything gray is Engine Enamel DupliColor Cast Aluminum. I baked both the covers and intake in an oven to help cure the paint. I like how they turned out.
The A/C Compressor and alternator I painted with wheel paint (some metallic silver that is supposed to resist chemicals and etch to the metal. Time will tell if it will last.
Painted the master cylinder DupliColor Cast Iron Engine Enamel and installed a new booster ($20 bucks on ebay-due to scratches, but good enough for the girls I date)
Still have a ways to go, and I would like to thank all those on the forum that have guided me and answered a thousand questions I had and will continue to have.
Thanks again
d1
Old May 2, 2011 | 10:49 PM
Dapapadon's Avatar
Looks great! Nice job!
Don
Old May 3, 2011 | 06:09 AM
Ranzan's Avatar
Getting There
that thing looks slick..... I really like the color combo nice job
Old May 3, 2011 | 12:09 PM
defiant1's Avatar
Thanks, still need to figure out how I am going to do the OAI and a few other things. Hope to get the carb together and mounted by the weekend and try to fire it up.
I will post new pictures and engine specs when all is said and done.
d1
Old May 3, 2011 | 12:21 PM
815Cutlass1972's Avatar
" Hoo yah "
D1... That engine looks good! What are the specs on your SBO?
Kino
Old May 3, 2011 | 07:15 PM
defiant1's Avatar
Kino
Let me get my notes together and I will post the specs soon. Basically, stock 350 bottom end and the cylinder heads were just rebuilt. I will post more specifics later.
d1
Old May 3, 2011 | 09:41 PM
Big Blue 72's Avatar
Lookin nice D1!
Old May 6, 2011 | 09:00 AM
boondocker's Avatar
Where were you in '72?
Nice and clean, good eye!
Old Aug 26, 2011 | 07:48 PM
defiant1's Avatar
Kino
Sorry it has taken me a while to respond:
Cylinder heads: #6,
Intake valves: 2.00" Exhaust valves: 1.564"
Vviton seals, hardened seats on exhaust side
4 Angle valve job
Cylinder head bowls: 67cc
Rocker arms: Comp cams kit-roller tip rockers w/poly locks
Custom length push rods w/guide plates
Camshaft: 217/224 @ .050" Erson custom grind
Intake manifold: Edelbrock 3711
Carb: Edelbrock 600 (1406 w/electric choke)/ 1" spacer installed
Short block: Stock, 14cc pistons, pistons are .025 in the hole,
Exhaust: Sanderson ceramic coated shorties, dual exhaust
Ignition: Pertronix III w/flamethrower coil
Outside air induction with ramair box (dual snorkel), under bumper air scoops
73CS
Jun 29, 2014 09:51 PM
Sampson
Mar 8, 2013 03:28 PM
Oldssupreme
Dec 23, 2012 01:03 PM
Gbobby
Jan 22, 2009 07:58 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
