Sammy"s Save ..68 442
Old March 2nd, 2013, 07:46 PM
Sammy70 455 Supreme
sammy's Avatar
I am beginning work on my Canadian built 68 442, and am pumped about it....
Body is self explanatory...I will be sending it to my local body man who is on board for the project.
Ted
sammy is offline
Old March 2nd, 2013, 07:59 PM
"Car"mudgeon
GAOldsman's Avatar
Good score Ted and even better save
GAOldsman is offline
Old March 2nd, 2013, 08:05 PM
Sammy70 455 Supreme
sammy's Avatar
undercarriage...
frame is solid...surface rust only..no rot
floor pans are good
trunk floor and rear wheel wells will be replaced......
sammy is offline
Old March 2nd, 2013, 08:19 PM
Rocket331's Avatar
Wow!
Rocket331 is offline
Sammy70 455 Supreme
sammy's Avatar
trim,emblems interior...
442 trim all there and in good shape
bumpers..i may be able to give a good clean....but prob need to be rechromed
interior in really good shape..front buckets will need to be recovered eventually....
front grill was the only item missing when i bought the car
sammy is offline
Old March 2nd, 2013, 08:42 PM
Sammy70 455 Supreme
sammy's Avatar
more...
engine..400 4bbl replaced under warranty in 1971 by the dealer..good shape,starts and runs
gas tank is surprisingly in good shape
tranny.400..shifts no leaks
rear drums are new
4 piston caliper front dics breaks were seized...cleaning and replacing seals and caliper components as needed
metering valve removed and replacing lines and fittings one at a time!
and started to replace all break lines
sammy is offline
Old March 2nd, 2013, 08:50 PM
Old School Olds
tru-blue 442's Avatar
Score!
Looks like you have your work cut out for you though.
Did you find the build sheet yet?
What was the code on the rear?
Looking forward to the progress Ted, Good luck on it.
tru-blue 442 is offline
Old March 2nd, 2013, 08:56 PM
Sammy70 455 Supreme
sammy's Avatar
the car will be painted the original willow gold and the original provincial white stripe and driven!.
Ted
The car did not come with the W36 stripe.
Came with the original pinstripe, that followed the moulding across the top of fenders, and since the car came with no vinyl, it followed the curve of glass around C pillar, under the peak moulding.this is what will be put back on.
sammy is offline
Old March 3rd, 2013, 06:24 AM
Randy C.
rcorrigan5's Avatar
If you are going with the W36 stripe, it appears your car did not originally have that option. The 442 numbers were located a bit further aft and lower with the W36 stripe than where your 442 numbers are located on your fenders. With the body work that's being done, it might be a good time to relocate your 442 numbers so they are in the factory-designated position for the W36 stripe.
Randy C.
rcorrigan5 is offline
Old March 3rd, 2013, 07:00 AM
vette442's Avatar
Ted
Glad to hear that - I think Willow Gold is a great color on '68s.
vette442 is offline
Old March 3rd, 2013, 08:32 AM
Registered Luser
ent72olds's Avatar
X2 on the willow gold! Made me laugh when you said "body speaks for itself!".... These '68's are starting to grow on me.......
ent72olds is offline
Old March 3rd, 2013, 09:20 AM
Sammy70 455 Supreme
sammy's Avatar
Score!
Adam, no build sheet yet...Do have POP tho
The ring gear has 14-43...so it has 3.07 gears(US built cars apparently had 3.08 gears)
No posi or lockup
Ted
sammy is offline
Old March 3rd, 2013, 09:25 AM
Sammy70 455 Supreme
sammy's Avatar
Randy C.
Randy, see above on the W36 option...
So since the car had the standard pinstripe, are the 442 numbers in the correct place?.....I would assume they are...any precise measurements out there?
Good idea to get the placement of the trim correct while doing body!
Ted
Ted
sammy is offline
Old March 3rd, 2013, 05:23 PM
Randy C.
rcorrigan5's Avatar
Hi Ted,
For the standard pinstripe fore and aft on each side, your numbers are in the correct place. I thought maybe you were talking about the W36 option (wide vertical stripe on each fender), in which case the the 442 numbers are located further aft and down a bit (see my picture to the left). If you are talking about the horizontal pin stripe, though, I stand corrected - your numbers are where they should be!
Randy C.
Old March 7th, 2013, 10:33 AM
chadman's Avatar
Actually both myself and Dan Macal have Canadian built '68s that were originaly W-36 stripe cars and both have the 4-4-2 numbers in the typical non stripe location. Both cars have a three digit paint code as well. We believe the Canadian built stripe cars were different. Mine happens to be willow gold with black vinyl roof and black w-36 stripe.
chadman is offline
Old March 7th, 2013, 02:03 PM
Sammy70 455 Supreme
sammy's Avatar
Any pics of your 68 that you could post? .
Mine will be painted the orig color...willow gold I think it was G on the cowel...
Ted
sammy is offline
Old March 7th, 2013, 02:11 PM
Nilsson's Avatar
rear drums are new
My 68 also has a dealer warranty engine. Did they stamp the pad on yours with the original engine number or leave it blank like they did mine?
Nilsson is offline
Old March 7th, 2013, 04:58 PM
chadman's Avatar
Ted
chadman is offline
Old March 7th, 2013, 07:51 PM
allyolds68's Avatar
Dan posted his GM of Canada docs a month or so ago. It was not a W36 option car from the factory.
allyolds68 is online now
Old March 7th, 2013, 08:03 PM
car guy
gearheads78's Avatar
Looking forward to seeing how it comes out. I should be working on mine tonight but just too tired. Heater core started leaking on the maiden drive the other night.
gearheads78 is offline
Old March 7th, 2013, 10:18 PM
lil_no's Avatar
Nice score. Another one being saved from the iron grave. I'll be watching as thing progress... Good luck!
lil_no is offline
Old March 8th, 2013, 06:09 AM
j_link's Avatar
I just noticed the build thread on this car, very cool. I'll be watching for inspiration. Good luck.
j_link is offline
Old March 8th, 2013, 07:13 AM
chadman's Avatar
I'm not so sure that Dan agrees with you.
http://72.22.90.30/phpBB2/viewtopic....5993&highlight=
chadman is offline
Old March 8th, 2013, 09:03 AM
berettass's Avatar
Hey, another person from ontario and you are not too far from me neither!
I have one 68 442 convertible, they seem to be hard to come by in this area!
Good luck with the build!
berettass is offline
Old March 8th, 2013, 09:10 AM
chadman's Avatar
That was one of the first things I had to do on my '68 when I bought it last year.
chadman is offline
Old March 8th, 2013, 09:37 AM
wait.... what....
oldzzy's Avatar
There's quite a few of us from Ontario on here!
oldzzy is offline
Old March 9th, 2013, 06:43 PM
Sammy70 455 Supreme
sammy's Avatar
left it blank.......cannot see a mark
Ted
sammy is offline
Old March 20th, 2013, 07:08 PM
Sammy70 455 Supreme
sammy's Avatar
lines...
My goal is to get this car moving and stopping.....then off to the body shop.I can do most of the mechanicals, but i want a pro to do the body.
Fuel and brake lines were replaced today. Where the line goes thru the frame, noticed it had a covering on it...was this asbestos? I got it off the
original line and was able to put back around new lines.
Gas tank will remain out of car until body work is done
Right front caliper i removed tonight and will be cleaned up. It is as big as the ones on my 1989 F350 7.3 Diesel that carries around 10,000 pounds!
Waiting on brake parts
More to come..
Thanks,
Ted
sammy is offline
Old April 6th, 2013, 06:38 PM
Daycab's Avatar
I love the color on that car.. Just says "vintage" to me. Best of luck on the resto! Can't wait to see the body and paint start to come together.
Daycab is offline
Old April 30th, 2013, 08:31 AM
Sammy70 455 Supreme
sammy's Avatar
a start.....
Have to admit, lost patience waiting for brake rebuild kit, so off to the local body shop it went....
trying to save as much of the original body metal that we can...
blasted the back to see what we have(or do not have)
frame looks pretty solid
all panels have arrived
It is a resto on a budget, so the frame off option was denied. The main thing is the car will be saved and a nice driver
More to come!
Thanks,
Ted
sammy is offline
Old April 30th, 2013, 08:38 AM
  #31
Old School Olds
Looking good Ted!
Old April 30th, 2013, 09:57 AM
  #32
Sammy70 455 Supreme
sammy's Avatar
Thanks Adam.....where the heck is Marble Falls Texas ....I even like typing it
Who's is pictured in your Avitar.? ...
Ted
sammy is offline
Old April 30th, 2013, 04:09 PM
  #33
Old School Olds
Where in the world is Marble Falls TX?
Ha ha, we are on the lower Colorado River.
The fourth lake of the chain of the Highland Lakes.
Buchanan, Inks, LBJ, Lake Marble Falls, Travis,
then, what used to be Town Lake in Austin and
was changed a year or so ago to Ladybird Lake,
After Lyndon's wife, Claudia.
Three blocks to the boat ramp, sweet.
You cannot see the Falls now as the were covered
up back in the 40's. Only when they let the lake
down for folks to repair boat lifts and such.
That little boy is my oldest son, the pic
was taken in '83. He goes about 230 lbs. today.
Old April 30th, 2013, 04:33 PM
  #34
Nice work Ted.
oldcutlass is online now
Old April 30th, 2013, 06:33 PM
  #35
Sampson's Avatar
Nice find and save Ted. I will be following along and look forward to your progress.
Sampson is offline
Old May 10th, 2013, 11:07 AM
  #36
Sammy70 455 Supreme
sammy's Avatar
coming along...
a ton of work in the rear of this car
just a few pics of the progress
Ted
sammy is offline
Old May 19th, 2013, 06:32 PM
  #37
She's sooo fine, my W29!
j442's Avatar
442 restoration
Hey Ted,
Super find with the '68 .... your work towards getting this car on the road is great!!!!... if you need another hand just pm me! I am close to you! Keep up the great work...will be following your thread!.... your perserverence will hopefully motivate me to get my resto underway!
j442 is offline
Old May 24th, 2013, 05:18 PM
  #38
68conv455's Avatar
Ted,
The 68's are the best (I'm biased). Looks like you are going to do a great job. I can't wait to see how it turns out.
I enjoyed your opening statement when you said you would send it to your local bodyman. I'm still hoping to find a bodyman, engineman, interior guy, plumber, electrician, carpenter, etc. LOL. Unfortunately for me, I always see him in the mirror.
68conv455 is offline
Old May 24th, 2013, 09:16 PM
  #39
Sammy70 455 Supreme
sammy's Avatar
Originally Posted by j442
Hey Ted,
I just might take you up on your offer!
Hope to have it on the road by late fall
Ted
sammy is offline
Old May 24th, 2013, 09:26 PM
  #40
Sammy70 455 Supreme
sammy's Avatar
Originally Posted by 68conv455
Ted,
Thanks!the car will be kept as orig as possible....willow gold and all
Darn mirrors
I did all the work on my first resto....found out just how much time it took(ended up taking it to a pro to fix my lousy paint job)soooo a local body man is giving me a hand with this resto...) the car deserves it
Ted
sammy is offline
Quick Reply: Sammy"s Save ..68 442
