Rebuild Carb or Not?
Old Jul 23, 2014 | 07:24 PM
mickyb's Avatar
Hello CO land. Well I know a bit more than the basics of what's under the hood and somewhat mechanically inclined however I'm not that savvy with carb and engine rebuilds. First off, can anyone tell me what carb I have or anything else about it based upon the photos and is it worth getting a rebuild kit or just going with a new replacement carb? If so what kind of kit or recommendations on carbs. At this point, I'm not looking to investing in making this a street rod(maybe someday), but I want to get this engine in good working condition. Its on a 70 Cutlass that hasn't been running for 5-8 years. To my knowledge, it ran fine prior to sitting. Suggestions?
Oh, the butterfly is definitely cruded up.
Old Jul 23, 2014 | 07:45 PM
Octania's Avatar
It's a Rochester 2-bbl
Vintage appears to be 70-72 based on the Trans Control Solenoid to the right of the carb- the CAR's right, not yours.
I suggest you look for a number such as "7041156" or similar stamped into the RH side of the carb fuel bowl. Near the top, near the fuel inlet line. That will get you the right kit.
Yes, rebuild it, or maybe just dismantle, clean, and reassemble.
If you really need a new one I can maybe get a nice one rebuilt around 1975 or so. Not too pricey.
Old Jul 23, 2014 | 08:16 PM
mickyb's Avatar
Great thanks for the tip. I just sprayed some brake cleaner and wiped off the gunk and got 7040155 and just below it 0630NCI off of it. I will check into this. I think I may try to rebuild it. Thanks for the tip and I will keep you in mind if I go the option of a used one.
Old Jul 24, 2014 | 06:02 AM
A kit should be available at your local auto parts store. Pay special attention to cleaning it thoroughly. Also make sure your float is set correctly. Don't use gasket sealers and don't over tighten the screws.
Old Jul 24, 2014 | 06:21 PM
mickyb's Avatar
Thanks for the tips. I will post updates once I order the kit and get started.
Old Aug 28, 2014 | 05:17 PM
oldoldss's Avatar
7041055 code
"0630" means it was built the 63rd day of 1970.
Last edited by oldoldss; Aug 28, 2014 at 05:26 PM. Reason: Used to an extra 1; mine is a 7041156...
Old Aug 28, 2014 | 05:47 PM
drop top olds's Avatar
Be sure to purchase a new gas filter too. It would be best to buy the "bucket" for a carb cleaner and soak it. Just be remove all the rubber parts before the soak.
jensenracing77
Jan 12, 2016 02:02 PM
77GCSX
Nov 9, 2011 02:39 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
