Pro-Touring 66 Cutlass
Old May 11, 2011 | 07:38 PM
Jocko124's Avatar
I've been a member here a few months and have been buried with work, but I figured I better post something up before Richard (gearheads78) gets upset with me! I've owned my Cutlass for about 5 years now. Shortly after I bought it I had Bill Trovato drop a '68 455 in it.
DSC_0012.jpg?t=1264142700
DSC_0010.jpg?t=1264142860
DSC_0007.jpg?t=1264143000
My engine was built by Bill Trovato.
1968 455 Block bored 30 over
rotating assembly balanced
Edelbrock Heads
Edelbrock Torker Intake
KB 455 pistons/pins 14cc dish 10:1 compression
Cat H beam full floating rods
Comp Cams hydraulic roller cam
Comp Cams Aluminum roller rockers
CSR electric water pump
MSD 6AL Ignition
2" Kooks Headers (Swain Coated)--3" exhaust
850 Demon Carb
11" Competition Trans. converter (3000 stall)
DSC_0002.jpg?t=1264476010
Last summer I Dynamatted the interior:
DSC_0001.jpg?t=1264143565
DSC_0005.jpg?t=1264143618
Then I had some BMW M3 seats installed:
CSC_0002.jpg?t=1265822137
DSC_0003.jpg?t=1265822286
Next I decided to tear out the front suspension and install ATS AFX spindles & steering arms, SPC Pro-lite UCA's, and SPC LCA's. I replaced the inner/outer tie rods, the pitman arm & idler arm, and the center link. Also installed SPC performance springs and double adjustable Varishocks.
DSC_0003-1.jpg?t=1267303976
DSC_0021.jpg?t=1280246686
The entire front suspension and the steering box, intermediate shaft & steering column removed:
Library-788.jpg?t=1271113951
Library-793.jpg?t=1271114593
Wheels are off--getting ready for the Forgelines:
Library-789.jpg?t=1271114090
I got some black SPC UCA sleeves from Marcus and reassembled the UCAs. I think they turned out pretty good.
DSC_0001-3.jpg?t=1271114430
and then attached my Upper & Lower Control Arms
DSC_0007-2.jpg?t=1272489998
DSC_0001-4.jpg?t=1272490021
Finally got the helical spacers in from SPC!
DSC_0012-3.jpg?t=1273449071
TADAAAAA: assembled the UCA, LCA, SPC springs, VariShock QS2 shocks, and ATS AFX Spindles.
DSC_0002-2.jpg?t=1273449346
Old May 11, 2011 | 07:41 PM
Jocko124's Avatar
Couple of goodies from Lee Steering:
Forgeline FS3P's:
DSC_0046.jpg?t=1292890339
DSC_0007-4.jpg?t=1292890309
DSC_0011-2.jpg?t=1292890371
Old May 11, 2011 | 07:42 PM
Jocko124's Avatar
Currently working on a T-56 Magnum swap, HPI k-brace install, and dropping the rear end.
Old May 11, 2011 | 08:17 PM
Ranzan's Avatar
Getting There
that is one sweet ride...................
Old May 11, 2011 | 08:55 PM
Jocko124's Avatar
Thank you sir.
Old May 11, 2011 | 09:54 PM
Big Blue 72's Avatar
That thing has some STANCE!!! Well done sir!
Old May 11, 2011 | 10:01 PM
Jocko124's Avatar
Thanks Big Blue. It's got the "Starsky & Hutch" stance right now. I'm working on dropping the rear end.
Old May 12, 2011 | 08:42 AM
slowolds's Avatar
Loose Radical
THAT is well done and beautiful! Are you driving it?
Old May 12, 2011 | 08:46 AM
Jocko124's Avatar
Thanks Scott. No I just dropped the trans to do a T-56 Magnum swap.
Old May 12, 2011 | 09:47 AM
Stevec's Avatar
Dude! Thats one bad *** car!
Old May 12, 2011 | 11:12 AM
Jocko124's Avatar
Thanks Steve...It's a never-ending project.
Old May 13, 2011 | 07:49 PM
gearheads78's Avatar
car guy
Glad to see you post it over here. Its looking great.
Old May 13, 2011 | 08:32 PM
Jocko124's Avatar
Thank you sir. Hopefully gonna make some major improvements in the next couple of months.
Old May 14, 2011 | 04:50 PM
therobski's Avatar
Very nice buggy, great upgrades....
Old May 14, 2011 | 04:55 PM
ddx77's Avatar
Awesome!!!
Old May 14, 2011 | 05:09 PM
Jaybird's Avatar
Jocko124... You've got me wondering! What more major improvements do you have planned? You car looks like it just had one hugh major improvement!
Very nice work!
Jaybird
Old May 14, 2011 | 06:39 PM
70vista's Avatar
Nice looking ride you have there. Enjoy it.
Old May 14, 2011 | 07:25 PM
firefrost gold's Avatar
any ground clearance problems with the spc lower arms ? Did the fort end go together easy or were the shocks a bugger? what rear arms are you running?
Old May 14, 2011 | 09:02 PM
Jocko124's Avatar
Very nice work!
Jaybird
You know how it is Jay, it's a perpetual project. I still have to plumb the power steering pump & and install the lower SPC springs in the rear end. I'll be replacing the gas tank (just found out it leaks) and replacing the fuel pump and lines and also setting up a fuel return line & cooler. Also, doing an auto to manual (T-56 Magnum) transmission swap. I need to redo the wiring and install HIDs. It's a total money pit!
Jocko124's Avatar
thank you sir.
Old May 14, 2011 | 09:10 PM
Jocko124's Avatar
My headers are the low point right now--about 3.5" off the ground. I have to drive it a bit to decide if I need to raise it an inch, but I think the front end looks killer the way it is right now. The front end actually went together very easily. The shocks were OK to install, but in full droop they are about 3/4" too short and so I'm trying to figure out if I want to shim them. As far as the rear, I do not plan on doing anything right now, but a 9" rear is in the plans for the future. If you want to talk in detail about anything regarding the front end or shocks specifically drop me a PM and we'll talk.
Old May 14, 2011 | 10:14 PM
Wicked!
Old May 14, 2011 | 10:55 PM
Jocko124's Avatar
Wicked!
Thanks 69.
Old May 15, 2011 | 12:20 AM
garys 68's Avatar
Nice build. Btw, I just put the jeep steering box in my 72, it feels like a new car. You're going to love it.
Old May 15, 2011 | 12:25 AM
Jocko124's Avatar
Thanks Gary. I haven't had a chance to drive the car since I changed it over to power steering, but I'm hoping it feels like a new car also.
Old May 15, 2011 | 05:29 AM
therobski's Avatar
I like the low stance very much also. Here is a shot of my 67. Now on the 64 F-85 post build under major projects and builds-64 post update I'm going to add a thread to it. I have got in my suspension components. Very similar to your set up on the 67.
Old May 15, 2011 | 07:50 AM
Aron Nance's Avatar
Now that car does have some WOW factor! Why do you think Richard (Gearheads78) would be interested in pictures????? LOL! To have seen his car, in person, is/was just awesome. Yours is in similar territory. Congratulations on joining the "money pit" group of our hobby.
Old May 15, 2011 | 09:40 AM
Jocko124's Avatar
Rob,
yeah the stance on the 67 is very nice indeed. Just checked out your thread on the 64---you are making excellent progress.
Old May 15, 2011 | 09:42 AM
Jocko124's Avatar
Thanks for the kind words Aron.
Old May 15, 2011 | 09:06 PM
nonhog's Avatar
Registered car nut
Looking good! So Autocross? 1/4 mile? track? or just a really fun street car?
Just curious
Old May 15, 2011 | 09:30 PM
  #31
Jocko124's Avatar
Just curious
Thanks nonhog..I really haven't thought about it much lately. It seems like I'm always messing with it. But it'll be mostly street with some autocross peppered in there if I can find the time.
LI Olds
Jan 8, 2014 06:06 PM
71drolds
Jul 5, 2012 01:25 PM
gearheads78
Apr 24, 2010 10:33 PM
gearheads78
Nov 8, 2009 04:27 PM
ent72olds
Aug 1, 2009 08:51 PM
