Pro-Touring 66 Cutlass
I've been a member here a few months and have been buried with work, but I figured I better post something up before Richard (gearheads78) gets upset with me! I've owned my Cutlass for about 5 years now. Shortly after I bought it I had Bill Trovato drop a '68 455 in it.
DSC_0012.jpg?t=1264142700
DSC_0010.jpg?t=1264142860
DSC_0007.jpg?t=1264143000
My engine was built by Bill Trovato.
1968 455 Block bored 30 over
rotating assembly balanced
Edelbrock Heads
Edelbrock Torker Intake
KB 455 pistons/pins 14cc dish 10:1 compression
Cat H beam full floating rods
Comp Cams hydraulic roller cam
Comp Cams Aluminum roller rockers
CSR electric water pump
MSD 6AL Ignition
2" Kooks Headers (Swain Coated)--3" exhaust
850 Demon Carb
11" Competition Trans. converter (3000 stall)
DSC_0002.jpg?t=1264476010
Last summer I Dynamatted the interior:
DSC_0001.jpg?t=1264143565
DSC_0005.jpg?t=1264143618
Then I had some BMW M3 seats installed:
CSC_0002.jpg?t=1265822137
DSC_0003.jpg?t=1265822286
Next I decided to tear out the front suspension and install ATS AFX spindles & steering arms, SPC Pro-lite UCA's, and SPC LCA's. I replaced the inner/outer tie rods, the pitman arm & idler arm, and the center link. Also installed SPC performance springs and double adjustable Varishocks.
DSC_0003-1.jpg?t=1267303976
DSC_0021.jpg?t=1280246686
The entire front suspension and the steering box, intermediate shaft & steering column removed:
Library-788.jpg?t=1271113951
Library-793.jpg?t=1271114593
Wheels are off--getting ready for the Forgelines:
Library-789.jpg?t=1271114090
I got some black SPC UCA sleeves from Marcus and reassembled the UCAs. I think they turned out pretty good.
DSC_0001-3.jpg?t=1271114430
and then attached my Upper & Lower Control Arms
DSC_0007-2.jpg?t=1272489998
DSC_0001-4.jpg?t=1272490021
Finally got the helical spacers in from SPC!
DSC_0012-3.jpg?t=1273449071
TADAAAAA: assembled the UCA, LCA, SPC springs, VariShock QS2 shocks, and ATS AFX Spindles.
DSC_0002-2.jpg?t=1273449346
Edelbrock Heads
MSD 6AL Ignition
850 Demon Carb
Couple of goodies from Lee Steering:
Forgeline FS3P's:
DSC_0046.jpg?t=1292890339
DSC_0007-4.jpg?t=1292890309
DSC_0011-2.jpg?t=1292890371
Forgeline FS3P's:
You car looks like it just had one hugh major improvement!
Very nice work!
Jaybird
You know how it is Jay, it's a perpetual project. I still have to plumb the power steering pump & and install the lower SPC springs in the rear end. I'll be replacing the gas tank (just found out it leaks) and replacing the fuel pump and lines and also setting up a fuel return line & cooler. Also, doing an auto to manual (T-56 Magnum) transmission swap. I need to redo the wiring and install HIDs. It's a total money pit!
My headers are the low point right now--about 3.5" off the ground. I have to drive it a bit to decide if I need to raise it an inch, but I think the front end looks killer the way it is right now. The front end actually went together very easily. The shocks were OK to install, but in full droop they are about 3/4" too short and so I'm trying to figure out if I want to shim them. As far as the rear, I do not plan on doing anything right now, but a 9" rear is in the plans for the future. If you want to talk in detail about anything regarding the front end or shocks specifically drop me a PM and we'll talk.
I like the low stance very much also. Here is a shot of my 67. Now on the 64 F-85 post build under major projects and builds-64 post update I'm going to add a thread to it. I have got in my suspension components. Very similar to your set up on the 67.
Now that car does have some WOW factor! Why do you think Richard (Gearheads78) would be interested in pictures????? LOL! To have seen his car, in person, is/was just awesome. Yours is in similar territory. Congratulations on joining the "money pit" group of our hobby.
Rob,
yeah the stance on the 67 is very nice indeed. Just checked out your thread on the 64---you are making excellent progress.
Thanks nonhog..I really haven't thought about it much lately. It seems like I'm always messing with it. But it'll be mostly street with some autocross peppered in there if I can find the time.
