Pics of our 56
Old Sep 11, 2020 | 10:57 AM
DVZ's Avatar
DVZ
Pics of our 56
Here she is. It’s going to be a lot of work, but we are both excited. And no these are not staged pictures. My wife literally does more work that I do on projects
Our little guy is excited too!
Old Sep 11, 2020 | 11:01 AM
Very cool pictures! I must say, that is a great idea regarding the roofing overhang you build above the workbench - I love it.
Old Sep 11, 2020 | 11:12 AM
DVZ's Avatar
DVZ
Thank you. This car is in amazing shape considering. Check out the bezel and horn cap
Old Sep 11, 2020 | 11:13 AM
They don't make hood ornaments like that any longer!
Old Sep 11, 2020 | 11:22 AM
DVZ's Avatar
DVZ
I know! and it's there all there in great shape!
Old Sep 11, 2020 | 11:29 AM
Most of what I see from the pictures appears to be nothing more than surface rust.
Old Sep 11, 2020 | 12:43 PM
DVZ's Avatar
DVZ
It is. It does have a little cancer on the front rear quarter panel and on front floor boards, but other than that it's solid. Which leads me to believe it was sitting under a tree for years. Which would explain why only the front floor boards are rusted out and the rear deck has sun damage, but the dash has little.
Old Sep 11, 2020 | 01:27 PM
Your wife is a keeper... Looks to be a solid start for a project.
Old Sep 11, 2020 | 03:15 PM
DVZ's Avatar
DVZ
[QUOTE=oldcutlass;1278164]Your wife is a keeper... Looks to be a solid start for a project.[/QUOTE
Thank you. She is!
Old Sep 12, 2020 | 03:02 AM
ignachuck's Avatar
Frank Ignachuck
Welcome Very nice car. It's got the hydramatic (not Jetaway) transmission= no Park position. Lots of sources for needed parts here. As mentioned in your other tread, check out the Vintage forum Just ask us.
Old Sep 12, 2020 | 07:56 AM
Tedd Thompson's Avatar
Unusual but not unheard of that a holiday has a slant pan transmission,most non post cars got the Jetaway but not all. If I had to choose I would go for the slant pan, tougher more durable but shifts a little harder.... Lost in the fifties.... Tedd
Old Sep 12, 2020 | 08:53 AM
Bfg's Avatar
Bfg
My wife looked like that 40 years ago!
Old Sep 12, 2020 | 09:09 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Frank correct me if I am wrong. I believe I read somewhere that the regular 88 (not Super 88) got the slantpan hydra-matic. I see this one has a 2 barrel carb so I am guessing it is a regular 88. I wondered if the 88 came in a 4 door hardtop and went to my Standard Catalog of Oldsmobile and it confirmed the 4 door Holiday hardtop was available. I thought it might be rare but they built 52,239 of them compared to 57,092 4 door sedans. That is just for the regular 88. They built 61,192 and 59,725 respectively of the Super 88's. We are all glad to help. Some of here know a little bit and then we have guys like Tedd and Frank who know a lot. I would call Frank our 56 expert.
Old Sep 12, 2020 | 10:22 AM
ignachuck's Avatar
Frank Ignachuck
Glenn, you got it right. In 1956, the Jetaway transmission was standard on the 98's. You could get the Jetaway on the Super 88's, but only the slantpan hydramatic on the 88's. The 88's had the 2 barrel (2GC) carb and the Super 88's and 98's had the 4GC.
Tedd, I agree that the slantpan was a better transmission than the early (56) Jetaways. They didn't correct the sprag problems completely until around 59.
Old Sep 12, 2020 | 05:27 PM
But after 60 years most of the Jetaways have been rebuilt or at least had the sprag replaced. The parts were not heat treated and failed miserably quite often before the warranty had expired..... Tedd
Old Sep 12, 2020 | 06:22 PM
DVZ's Avatar
DVZ
Thanks for all of the info guys! This is EXACTLY the reason I'm glad this forum is up. Gina and I are going to try and pull it tomorrow. I'll post some pics so you guys (Frank and Ted) can direct me on what I have and which way to go. Fingers crossed, we can rebuild this engine.
Old Sep 12, 2020 | 07:56 PM
solly's Avatar
Welcome fellow 56-Er !! On the previous restore (64 Belair ) had the wife involved she was in charge of engine, accessorie and interior trim painting, did a great job and the help was appreciated ! She was much easier on the eyes smelled much better and drank way less beer than my male helpers !! Good luck on your project you will find all the help you may need here. These guys are a wealth of knowledge. Keep the old Olds Rolling !!!
Old Sep 12, 2020 | 08:23 PM
rocketraider's Avatar
Oldsdruid
Spark plugs out and fill the cylinders with magic potions. 50/50 mix of acetone and trans fluid, PB Blaster, or plain old diesel fuel can all seep past frozen pistons. All depends what your nose can tolerate!
Or once you get the engine and trans split, pull the heads, oil pan and crank and soak the piston bores with the juice, and then start tapping pistons with a soft mallet or piece of 2x4. Maybe you'll get lucky and they'll come out.
Old Sep 13, 2020 | 10:40 AM
DVZ's Avatar
DVZ
Thanks guys. I feel very welcome already being here. I pulled the spark plugs a while back and soaked the cylinders with 50-50 mix of F type tranny fluid and Marvel mystery oil. Pulled the harmonic balance or to expose the front engine mounts and the sheer pin on the crank is still intact. So hopefully the motor didn’t seize while it was running. Hopefully it’s just seized because of water getting into the intake manifold. I’ll keep you guys posted on what we find when we pull the heads
Old Sep 13, 2020 | 01:32 PM
That is not a shear pin, its just a square keyway. I moved your thread to the major projects forum.
Old Sep 14, 2020 | 09:02 PM
DVZ's Avatar
DVZ
@oldcutlass - thank you. Getting used to this whole forum thing again.
Old Sep 14, 2020 | 09:08 PM
DVZ's Avatar
DVZ
We finally got the engine out. Taking it to my buddy Luis‘s shop this weekend to see what’s inside.
Old Sep 17, 2020 | 11:04 AM
pherbicide's Avatar
Looks like a great starting point. I'll be following along!
Old Nov 11, 2020 | 03:13 PM
DVZ's Avatar
DVZ
So it's been a couple months since we have been on here. So the engine news is bad. Blown head gasket. The block need extensive machine work, probably to the point of sleeving. Also a complete head reworking. Would anyone happen to have an engine on here for sale that would fit? Running or not. I can just see trying to rebuild this one adding up $$$$
cutlassgal
Jun 10, 2013 02:51 PM
oldsguybry
Sep 16, 2012 08:09 PM
Olds65
Aug 11, 2012 06:55 AM
bonezarally
Aug 10, 2010 07:16 PM
BEAR
28
Feb 27, 2010 04:39 PM
