Ole Betty is getting heart surgery, wishing her well on a speedy recovery🥲
Old Apr 29, 2021 | 09:36 AM
LegalizeTexasMeetup's Avatar
Bringing my Ole Betty back to life She has been in a coma for about 10 years after she ran hot and blew a gasket. Kids and Wife and a mortgage showed up and I let her sit..
75 Delta with a 350. We are hoping to rebuild it and do some modifications along the way to get more HP out it and more pep in her step. Replacing the heads and bore the engine, replacing the the carb are just a few are in mind
Looking for a set of cylinder heads off of a 67 to 71 olds 350
send me any suggestion on performance enhancements without breaking the 🏦
Old Apr 29, 2021 | 10:37 AM
08-141 K43727's Avatar
Godspeed Betty!! Good luck; I am sure some experts will chime in soon!
Old Apr 29, 2021 | 10:38 AM
Oh and welcome!!
Old Apr 29, 2021 | 02:12 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
A big car, I can see why you want more than 160 hp. What octane gas are you planning on? You can use your current heads with flat top pistons, either Speedpro, DSS or the 4.065"CP piston, if the block is in really good shape. If under the bowls are opened with a cutter, your current heads will flow on par with early heads. Probably the generic 204/214 cam will be fine for a mild power boost. Also consider a 2000+ stall converter to help launch. Good luck.
Old Apr 29, 2021 | 02:55 PM
I hadn’t given the octane preference much thought honestly. Sounds like using a higher octane may be helpful?
Old Apr 29, 2021 | 03:48 PM
OLDSter Ralph's Avatar
What carburetor is on it now ? 2 barrel ? 4 barrel ?
Old Apr 29, 2021 | 03:55 PM
I would keep the original QuadraJet, just get it rebuilt and tuned for your new build.
Old Apr 29, 2021 | 04:34 PM
Ralph
Two Barrel stock I’m pretty sure
Old Apr 29, 2021 | 05:03 PM
I just looked back at your pics. Looks like you have a Quadrajet (4 barrel). Get that carburetor rebuilt and tuned for your application by a specialist that is familiar with Quadrajets.
Greg Rogers
Aug 25, 2019 11:12 AM
flatoz
Mar 23, 2017 04:40 AM
ah64pilot
Mar 3, 2013 08:08 PM
WolfmanG
Jan 16, 2012 03:26 PM
442much
Aug 9, 2010 09:11 PM
