Into the unknown - Underhood restoration!
#561
I'm always amazed. In the summer you complain about the heat. Then in the winter you complain there's not enough heat. LOL had to jab that in there. Just looked at your forecast - I feel so bad that it's only going to be around 80 in your neck of the woods now. Best put on a coat so you don't catch cold.
#562
One piece at a time….
Little by little, she goes back together. After months of waiting, I finally got the preheat pipe back from the sandblaster. It went with a load of a friend’s parts so I was in no hurry - it was free for me.
I painted it with two coats of Eastwood’s Extreme chassis black satin to match the air cleaner.
I was also able to find a use of the giant cotter pins included in the 600 piece assortment I got at Harbor freight long ago – it fit perfectly.
And here it is installed; do not mind the dust on surrounding parts.
#564
Very Nice Master Obi Wan. You interested in some proper date coded plug wires? You can buy them (code 1-q-72) from a company called windy_city_muscle on flea bay.
http://www.ebay.com/itm/1Q-72-dated-...item3ca08912dc
#565
We did our Christmas light cruise last weekend and it was 63* that night, plenty warm. Had the heat on lukewarm and she even told me to turn it off. Never needed the seat heaters!
Heater hose leaked a couple drops when I got home but I gave the clamp another 1/6 turn - hope that fixed it.
Thanks - need to finish the A/C - hoses, compressor, condenser, repaint radiator support, and maybe do the grilles. I will see what the MAWs bring me.
Thanks for the complements but no thanks on the wires. I have my anti-MAW helmet strapped on tightly.
#566
Don't need the MAW helmet and I get that we haven't heard what's happening on the job front lately. Just noticed the wires weren't up to your normal standard. Aren't the ones by the heat stove pipe supposed to go around the outside to stay away from the e-man? I'm prolly going to get a set of those wires to go with the OEM disty that's going back in next year. Not happy with the HEI I put in back in 2008. Prolly a recurve in order, but it also interferes with clearance on the stock air cleaner.
#567
Rob I just found your thread and followed it from start to end. GREAT JOB! I was trying to get the conclusion to O's_Car thread about the Classic Air system he was installing on his Olds and I saw you were talking about evaporator installation with him.(Do you know if the end of that thread has been moved or something...?) Now I am wondering what your outcome is going to be along with his. I am going to redo the air on my 71 Cutlass Convertible this winter and am trying to make the choice between factory type or aftermarket- R12 or 134A-.... etc. Thanks for the great thread. I will be following it. Greg
#568
Great - now you are making me want to try all 7 others to see if they will reach comfortably outside.
In my opinion...
If you have heat only and need AC, aftermarket will be a bit easier to install. No AC'ed defog if that is important.
If you already have factory AC like me, it is easiest to just make it work like it should. The box is not a big deal to restore. I have not finished mine and have not decided what Freon, either. I will use an oil that is compatible with both and all the components were either flushed or are new. Therefore I could start with R12 and change to 134 later if needed. R12 works best in these factory systems. I am most likely going with a NEW A6 compressor.
Hopefully this will be finished this spring...
Oh - and thank you for the kudos!
#569
Rob, I think I am going to go the original type route w/ R134a. I noticed you left your evaporator cover bare- it looks good. Do you think thats the way they were when new? It's sort of a dark grey finish. I know mine had been painted black at some time but is coming off and looks bad. Also 1 of the screws that goes into the firewall is off kilter and looks funny. I have noticed this on other Cutlasses. Did you have that issue??
#570
If your was painted, after you disassemble it all, soak it in oven cleaner - it will strip that paint off like magic.
All of the screws in mine were fine. Recon yours was removed at one time and not reassembled right?
#571
Rob, I think I speak for most of the people here, to say THANKS for sharing your restoration story with us. I love your naritive and attention to detail. I'm sure you've inspired a few here to jump in and tackle some smaller projects. What I'm trying to say is it takes a lot of work to document, photogragh and compose the text, many people here are lucky to have you showing us your progress. You should be very proud. I'm glad you posted again, 'cause I just found this thread and spent a couple hours reading through it, along with throwin' back a few cold ones. Best of luck to you in the new year. ROB YOU ARE DA MAN!
#573
Guys, thank you for the kind words!
While restorations are a passion of mine, so is sharing my techniques so others can help save these old mechanical marvels as well. Besides, why make the same mistakes I did?
I was licky I had a flexible job that gave me the extra time needed to do writeups in that kind of detail. Unfortunately my upcoming far-away new job will barely give me enough time to eat, shower, and sleep, so I might not be around here as much. I will still be seeking a more compatible job closer to home so hopefully this will not last long...
#574
Rob, Looking back thru your thread I noticed on pg 9 the 2nd pic shows your exhaust heat riser stove. It's just like mine but I always thought it was wrong because it looks like there should be a stud type head bolt and then a nut to hold the stove. But mine is just like yours. The slot sits above a regular head bolt so I guess its correct. I know yours is a 72 and mine is a 71. I also have a 70 vista cruiser that the heat stove is different yet....
#575
71/72 will be the same because the 72 was never supposed to exist with this body style it was supposed to originally be replaced with what we know as the 73 'colonade' series. + in 72 there weren't the smog reduction legislation and head differences required for emissions in 73.
#576
Rob, I finally got back to my project and ordered a bunch of parts from Classic Auto Air. I didn't get the sticky goop that goes around the bulb. Do you think I could get that locally? I noticed when I scraped the sealing surfaces of the evap box that the sealer that was there seams identical to the stuff we use at work that we call monkey dung. This is where you said you used the 3 m strip caulk I think. Thanks,Greg
#577
I used the 3M strip calk for sealing the box to the firewall and also the two halves of the box. Also I sealed the blower motor with it, and around the heater box, etc. Works great and almost factory.
What are you doing for a POA valve?
#579
No, no, no - it is a solid 2" wide cork tape that had been saturated in tar. You apply it with your hands and is SUPER sticky. Most of the tar stays off your hands, but have your favorite hand cleaner or solvent handy to clean off the residue.
#581
Rob,
Following your story down here in Carrollton. Bought a 72 442 car in March that orginally it was just going to be a detail & drive type of thing, but one thing has lead to another ... Now going to have it painted by Frank Waggoner, have completely rebuit the 455 and am going to put a 4 speed in it (no console bucket seats), and am putting a OAI hood/W25 set up on it - in addition to new top, cylinders, pump motor, booster, master cyl, fuel pump,water pump, alternator, starter all wheel cyls and hold down parts front seat covers, carpeting, bumpers, handles, brake lines/hoses - and this is just the HALF of it
It was just supposed to be a detail job....
The car looks great from the photo. I am just starting down the long road of restoration and was wondering what your approach was to doing the car? I guess more of what things did you start with, etc,.?
Sean
#582
Not much going on; it has been way too hot to keep motivation.
Last Monday, the starter and TC cover bolts and the positive battery cable tube were cleaned up and the tube clamp was removed for painting.
Wiper motor was removed, partially disassembled, inspected, cleaned up and paint touched up. New rubber mounting grommets were installed, as the originals were a hard crumbling mess.
Checked out the washer pump and all looks okay in there – seals and flaps still soft and flexible.
#583
I got them here:
http://www.firewheelclassics.com/sto...pID=&SKU=WW103
I did not like the screws that came with them, so I got these repros:
http://www.firewheelclassics.com/sto...pID=&SKU=WW298
This is a Camaro supply shop, which I can relate to Fusicks to Olds.
FWC is located very close to where I live so i drop in for parts and stuff or just to talk cars. Fair prices, VERY friendly staff, no hassle returns, and
willing to special order Olds stuff. Great folks there.
Many parts can be found both on the Camaro and the Cutlass so i check with them for lots of parts. Upper A frame bolts I got from them too.
#584
I got them here:
#585
Hey Rob,
When you pulled the evaporator, did you see oil on the inside of the box? My rubber drain hole is a gooey, sticky mess like yours was but I don't feel any oil. I'm hoping to get the box off tomorrow. I have to make the conversion to r134a so I might as well (ugh) pull the condenser and take them both in for test and flush. Did you do anything to your compressor before the conversion?
#586
For those that are needing the wiper motor grommets/ rubber bushings, you can check in the HELP section of many auto parts stores. After buying some online originally, I happen to find them in the help section At Pep Boys. They look identical and probably not the markup of "classic" parts. I did originally check other Stores but I didn't check Pep Boys HELP section. Turns out they have a quite a few things that you can use for your car that others sell online as
"classic". Check that section out you'll save some bucks.
#587
#588
Hey Rob,
Good work on the tests and flushes. Get some oil that is compatible with both freons in case you decide to go back to R12.
My compressor is still in a box on the garage floor and still have not decided what to do with it. I think i will buy a new or reman.
#589
If you are converting to 134a, I highly recommend replacing the condenser with a parallel flow condenser from Classic Auto Air. The weak point in 134a in an original system is the condenser. The original condenser can't cool the refrigerant enough, and the system won't cool as well, especially when at a light. The parallel flow is designed to run with 134a. They can also rebuild and recalibrate the POA for 134a. An rebuilt POA works much better than the POA "updates" they sell. My Cutlass puts out 30 degree air. I replaced all the O-rings, flushed everything, replaced the expansion valve, rebuilt and recalibrated the POA and put on the parallel flow condenser. I am still running the compressor that was on the car when I bought it in 2006. Incidentally, the parallel flow condenser is exactly the same size and mounts identically as the original, using the same hardware.
#590
CAA doesn't have the most intuitive site. Could I ask for part numbers for the condenser and the evaporator? What am i looking at as far as cost? And re-calibrating the POA? Do I have to replace the hoses if they look to be in good shape?
Sorry, this is one I don't want to spend $$$ on but these Illinois summers can be in the 90s with 90+ humidity. And we're still reeling from the propane fiasco this winter. We spent close to 3k for heat this winter.
#591
Parallel Flow Condenser 11-803P $299.00 7/16/2010
POA Valve 15-200 $169.99 + $45 core charge 7/27/2010
GM Expansion Valve 15-205 $52.99 7/27/2010
They are also good to talk to is you have questions. I dealt with Ron 813-251-2356 X 7022.
I also bought a condenser for my 1970 Pontiac Bonneville. It is outwardly the same as the Cutlass, but with different (and correct) mounting brackets.
#592
Thanks Brown, I really appreciate it. I'm thinking I could try using the old condenser and if it's not good enough I can replace it later. Especially since I'm also looking at replacing the evaporator. Thanks for the part numbers.
#595
#596
https://classicoldsmobile.com/forums...2-cutlass.html
I will keep looking.
#600
I cannot find it either. I know I had one with some pictures and better details, here it is in a nutshell.
