Installing tubular control arms
Old Jun 21, 2013 | 01:40 PM
Seff's Avatar
Given the daily driver status of my Supreme, old front end bushings and even the backwards geometry is dangerous. So, I ordered a set of UMI control arms, with the tallest ball joints they offer.
Originally Posted by Seff
I love my mailman.
This is what a long winter of salted roads did to the driver's side. A touch-up is in order, I think.
Speaking of rust - just look at that color! But more importantly, look at that unfastened nut. No wonder my steering was sloppy and clonky. o.O
With the brake disc, steering arm and wheel bearing gone, we can work on the ball joints. Remember to leave the nut on the end of the ball joint in place if you don't have a jack under the spring.
With both ball joints disconnected, it's a matter of lowering the jack to decompress the spring.
At this point the upper arm comes off easily, just a matter of rusty nuts. :P
No wonder my front end didn't line up - those are some pretty gnarly bushings.
And finally - what's the torque rating on this nut? Can't seem to locate it, and three of the four I've removed so far (two sets of front suspension, to find the best parts) have been hand-tight, no more. Bearings are fresh-looking.
Old Jun 21, 2013 | 04:12 PM
jag1886's Avatar
Your old stuff was really FU. Keep showing photos as you can.
Old Jun 21, 2013 | 04:27 PM
The torque rating on the spindle nut? Basically it's a small preload, and yes they do loosen easily sometimes. I just pack the bearings, reassemble, install the tire and wheel. Then tighten the nut while turning the wheel until I feel it start to bind, loosen a bit and then retighten until there is no vertical play, and then tighten till the cotter pin hole lines up. I use 100#'s on lug nuts.
Yeah, it was time to change the bushings, perhaps a bit past that time. Looks like your progressing well.
Old Jun 22, 2013 | 02:27 AM
Seff's Avatar
Yeah, the old bushings were way past their prime.
Thanks for the run-down on wheel bearings and spindle nuts, I'm gonna need that.
Old Jun 22, 2013 | 10:52 AM
Seff's Avatar
Spindle and steering arm all ready for some Hammerite. Not sure how it compares to stuff you have over there, but it's rust-resistant, thick, heavy, sticky paint.
All ready to be installed. It has a rubber spring insulator in there already. The bushings need lubrication before you install the arm in the frame - luckily it's included.
The springs on the left is the set I took off the car - the set on the right is from the original car. One car had FE2, the other did not. Both were 350 cars. The set on the right has one flattened end, while the other set has normal ends. I'm better off reinstalling the set on the left, yes?
Ten minutes of mucking about resulted in upper and lower arms being fitted, ready for spring and spindles. Waaay too easy.
Old Jun 22, 2013 | 11:30 AM
oldstata's Avatar
Justin
Love the pallet jack ! Now that's thinking
Old Jun 22, 2013 | 12:55 PM
Seff's Avatar
That's the only jack I own, and how I took apart and put together this car in the first place. :P
Old Jun 23, 2013 | 10:19 AM
Seff's Avatar
All painted and ready to go.
Wham, bam, thank you ma'am! Took all of ten minutes to button that up. Notice the tall ball joint clearly visible on the upper control arm.
But what's that? The shock doesn't fit through the LCA? Do I REALLY have to take it apart again? Fiine.
(Two hours later)
WHY WILL THIS MOTHERFUCKING THING NOT LINE UP?! I JUST DID THIS A MINUTE AGO!! >:O
Old Jun 23, 2013 | 02:09 PM
Run to Rund's Avatar
Check the service manual for spec on the spindle nut. It is usually 30 ft lb while spinning the hub, then loosen, take to finger tight, and loosen enough to put in a cotter pin. There won't be any preload on the bearings.
Old Jun 23, 2013 | 02:10 PM
oldstata's Avatar
Justin
I ve done it this way but have always went tighter to install cotter pin
Old Jun 23, 2013 | 04:12 PM
Seff's Avatar
I had a hard time finding it in the service manual, because I didn't know the name of that nut. Advice duly noted, both of you. Thanks.
Old Jun 24, 2013 | 10:54 AM
Seff's Avatar
By the time I got back to the workshop today, I'd been thinking and wondering about my springy conundrum. The first thing I tried was smearing bearing grease on the outside of the rubber spring seat. Lo and behold, it worked! It worked so well, in fact, that I forgot to take pictures as I put the steering knuckles together.
Look how close my steering is to the sway bar. With the tires hanging free it rubs. I haven't tried turning the sway bar upside down, and I don't know if that's advisable. The immediate thought is that it doesn't matter which way it's turned, since it's just a big torsion bar.
With the steering wheel centered, this is how the tires stood. Talk about different geometry.
I'm doing rough toe adjustment first, then approximate camber and caster. When these are so-so, I'll take it to an alignment shop, I think. If nothing else to make sure the measurements are accurate.
The control arms came with three different recommended settings; "street/show", "street/performance", and "mild competition (not recommended for street)".
Show:
Camber: 0 to 1/4 degrees
Caster driver's side: +4 degrees
Caster pass. side: +4.5 degrees
Toe: IN 1/8" total
Performance:
Camber: 1/2 degrees
Caster driver's side: +5 degrees
Caster pass. side: +5.5 degrees
Toe: IN 1/16" total
Competition:
Camber: -1 to -1.5 degrees
Caster driver's side: +5 to +6 degrees
Caster pass. side: +5.5 to +6.5 degrees
Toe: OUT 0" to 1/16" total (Autocross)
Old Jun 24, 2013 | 03:52 PM
68conv455's Avatar
Any reason you chose the tallest ball joint available?
Old Jun 24, 2013 | 04:34 PM
Seff's Avatar
To get the most performance-oriented setup they offered. I want my car to handle, since it's a daily driver it needs to keep up, safety-wise as well.
Taller effective spindle height raises the roll center and diminishes the camber change during suspension travel, in conjunction with the different UCA. The lower is merely stronger, but the same shape as the factory LCA.
Old Jun 24, 2013 | 04:39 PM
I like these settings:
Camber: 0 - 1/4 degrees
Caster driver's side: +5 - 7degrees
Caster pass. side: +5.5 - 7.5 degrees
Toe: IN 1/16" - 1/8 total
Old Jun 24, 2013 | 04:41 PM
Seff's Avatar
Are those on factory control arms?
Old Jun 24, 2013 | 05:11 PM
In general, I upped the caster settings because you can never get to 7 on factory control arms but you can on yours. Caster helps to keep the car going straight and adds road feel. The camber and toe are standard daily driver to performance settings.
Old Jun 25, 2013 | 01:04 AM
Seff's Avatar
I can certainly try both, see which I like better. :P
Old Jun 25, 2013 | 09:05 AM
Seff's Avatar
Does anyone know why they went from asymmetric camber to asymmetric caster? The camber asymmetry was because of road crown, but does caster asymmetry take care of this as well?
Steering is rubbing. Longer/taller sway bar links in order? I'll start by getting my alignment sorted out, then see if it's still an issue. This picture is with the weight of the car on the wheels, mind you.
Old Jun 25, 2013 | 10:06 AM
oldstata's Avatar
Justin
Caster does pull to the negative side . When doing alignments I try and keep equal
But every tech is different
Old Jun 25, 2013 | 10:08 AM
Seff's Avatar
I can always, and easily, change it.
Old Jun 25, 2013 | 10:19 AM
The reason for caster settings being different on the passenger side is to compensate for the crown of the road.
You don't want any interference with the sway bar or any other object with steering components at either extreme of suspension movement. You can get some GR8 all thread rod and make a longer standoff with tubing to extend it up. Or buy some adjustable sway bar links.
Old Jun 25, 2013 | 10:21 AM
Seff's Avatar
So I gathered - but why compensate for road crown through caster instead of through camber, like in the old days? I'm just wondering.
Old Jun 25, 2013 | 10:39 AM
oldstata's Avatar
Justin
Not positive here so please forgive me if this is incorrect. on this style of set up if you adjust camber or caster it affects each other, so I would think that they leave room for corrects on either side ?
Old Jun 25, 2013 | 10:50 AM
Seff's Avatar
Well, according to the CSM, shims behind the rear UCL bolt only changes the caster, but I could go check that fact quite easily.
Old Jun 25, 2013 | 10:55 AM
No they are 2 separate adjustments. Caster is the angle from the top ball joint to the bottom with relation to the ground, it controls the amount of force necessary to turn the steering wheel and it aids in the wheels to remain straight. Camber is the angle from the top of the tire to the bottom with relation to the ground. You want this slightly tipped in at the top or perpendicular to the ground, it will effect tire wear.
Old Jun 25, 2013 | 11:13 AM
oldstata's Avatar
Justin
I realize they are different adjustment but I though that when I added shims for caster that it changed my camber readings ?
Old Jun 25, 2013 | 11:14 AM
Seff's Avatar
Basic trigonometry says it will, but there might be other factors involved. :P
Old Jun 25, 2013 | 02:15 PM
TeleThunder's Avatar
Swaybar rubbing
Hi everyone
I am new here and I do not try to be an smarta... but isnt his swaybar mounted upside down? I think if it was turned the other way it would not rubb, or?
Old Jun 25, 2013 | 04:01 PM
Seff's Avatar
Heh, I thought the same thing TeleThunder, but when I turned the sway bar around, it rubbed on the idler arm and the pitman arm. It's a very healthy 1 1/4" bar.
With the camber and toe dialed in, neither side touches, but I suspect the driver's side will come closer as caster is adjusted. I extended the sway bar end links 3/4" to make life easier, but it didn't eradicate the problem, and making the link longer will cause other problems.
With the history of a broken frame, this car has lost all symmetry in the front end, so I'm not bothered by the sides acting different.
Old Jun 30, 2013 | 04:36 AM
  #31
Seff's Avatar
I fashioned 8½ inch sway bar end links, it seems to work just fine. I moved the sway bar up and down without the end links mounted, no frame contact.
There IS a sound that consistently appears when I drive over speed bumps - a rubber against metal kind of sound, not a metal on metal clonk. I'm assuming this is the poly bushings talking to me?
First I set rough toe, then camber. Went to the alignment guy, he didn't have time until Wednesday, so I pulled the wheels off and set rough caster, then went back to setting camber and then finally toe. 20 round trip last night, the car hugs corners very nicely.
Old Jun 30, 2013 | 11:23 AM
  #32
ent72olds's Avatar
Registered Luser
Seff, just make sure you torque all suspension with weight on wheels...I'm sure you did, but sometimes, the noise you hear could be the bushings screaming....as you were soldier...
Old Jun 30, 2013 | 02:49 PM
  #33
Seff's Avatar
I did indeed, but always had a re-torque in mind, once everything has settled and the bolts have stretched a bit, etc. You suggest loosening them up before re-torquing?
Old Jun 30, 2013 | 05:06 PM
  #34
ent72olds's Avatar
Registered Luser
If the car was resting on its full weight, on all fours, when you originally torqued , you should be good. If you didn't, yes, loosen and retorque while on all fours. Definitely cool too see you using it as a DD!
Old Jun 30, 2013 | 05:11 PM
  #35
Seff's Avatar
I had 'jacks' under the front wheels and rear wheels on the floor, bounced it up and down a bit to set everything, then tightened it. Will see how it develops.
As for DD use; these cars were made to be driven. :P
Drivetrain/Differentials
Dec 5, 2012 06:20 AM
Creativeindy
Suspension & Handling
26
Sep 11, 2012 04:25 PM
Impin'
Apr 20, 2012 09:36 AM
johnspd22
Oct 29, 2010 07:41 PM
Mikes65
17
Aug 23, 2010 09:43 AM
