Help ID-ing rear end
Old Nov 13, 2012 | 12:03 AM
Redog's Avatar
I found a rear on CL an the guy says its a 8.5 10 bolt rear. He also said it will NOT fit a G body car
I emailed him and he doesn't know the rear end ratio but its totally stock with a LSD in it (I know what to look for there)
The code on the axle is "CA C 146"
Does anybody know what kind of car that's from? I found some info that suggests that 146 could be either Jan 4, 1976, 86 or 96. The C could be "buffalo plant" he thinks it might be an A Body rear, which I'm looking for a 73-77 one for my Delta
He wants $300
Old Nov 13, 2012 | 05:47 AM
507OLDS's Avatar
The "C" is Chevy,and the 146 is the 146th day of the year.
There is a "CA" code in 1965,for a 3:08 posi,which would be an 8.2" 10-bolt.
There is a "GA" code in 1971,for a 2:56 non-posi,which would still be an 8.2" 10-bolt.
I don't have codes for the 73-77 A-body rears,but if it is a 73-77,then it would be an 8.5" 10-bolt.Depending on what it came out of,and what year,it could have c-clips,or bolt-in axles.
Are you able to get a picture of it?
Old Nov 13, 2012 | 06:05 PM
Redog's Avatar
Can't find the add now, I guess it was taken down
Meh, if it is a factory posi, a '65 rear won't fit my Delta
Old Nov 27, 2012 | 04:09 PM
Redog's Avatar
It popped back up!
http://philadelphia.craigslist.org/pts/3402052976.html
coppercutlass
Drivetrain/Differentials
18
Dec 12, 2013 04:09 AM
62radarlove
Feb 24, 2012 07:37 AM
56rocket
Mar 6, 2011 09:31 AM
6inarow
Oct 16, 2010 02:58 AM
Karl
Jun 19, 2009 10:34 PM
