Fender adjustment
Old Sep 12, 2022 | 08:14 AM
Carsick's Avatar
Fender adjustment
Can this be shimmed to line up better? The frame got wacked a while ago so everything is a bit off. I have the front clip off currently. I'm hoping to get it back together and lined up a bit.
Thanks !
Old Sep 12, 2022 | 08:36 AM
You've got a lot going on there with the bumper, fender and hood. It all needs tending to in order to get a better alignment.
Old Sep 12, 2022 | 09:11 AM
Carsick's Avatar
Do you think I can shim things or is it going to be obvious (tweaked frame)?
Old Sep 12, 2022 | 09:31 AM
I'm going to say no because structurally it's too high, shims will make it higher.
Old Sep 12, 2022 | 11:02 AM
Carsick's Avatar
I'm afraid you right....I was hoping otherwise.
Old Sep 13, 2022 | 02:07 AM
Carsick's Avatar
What if I shim the core support a bit?
Old Sep 13, 2022 | 03:21 AM
bennie442s's Avatar
Frame alignment shop
I would recommend taking the car into a frame alignment shop and having it corrected. I had a similar situation and it was easily the best $549 spent on the car.
best,
-ben
ssbigken
Nov 15, 2022 10:29 AM
Bee Saint Louis
May 8, 2022 06:42 PM
J1978
Body work
Feb 6, 2022 03:15 PM
J1978
Body work
Dec 12, 2021 05:05 AM
wills30
Apr 14, 2018 01:06 PM
