comp cams 1442-kit
Old October 1st, 2012, 09:56 PM
onofre442's Avatar
comp cams 1442-kit
hello everyone, just finished building the 455 engine...i have installed a comp cams 1442-kit in it. just ran maybe a good 3 hrs and i hear a ticking sound inside valve cover. i removed valve cover and found one of the pushrod had been mushroom on top of the tip. i called comp cam and ordered one along with a new rocker for a true mate. after installing it, im hearing a ticking sound again...and i think its coming from the same pushrod location...(by the firewall and below the booster). anyone having problem with this kit....or maybe the pushrod? im using pushrod part #7841 5/16 dia 9.654 length. can i go with a higher end pushrod part#7658 5/16 dia 9.650 length...??? help....
onofre442 is offline
Old October 2nd, 2012, 04:29 AM
507OLDS's Avatar
The pushrods that come with the kit almost never work.They usually bend,or distort at the ends.I have always had to use a longer pushrod as well,like a 9.900"
507OLDS is offline
Old October 2nd, 2012, 06:01 PM
442scotty's Avatar
I have the same kit...had to measure for the proper push rods also
442scotty is offline
StickW31
January 19th, 2014 07:14 PM
69OLDSCUTCONV
December 1st, 2011 09:48 AM
geckonz08
February 24th, 2010 12:56 AM
BosMobile
May 6th, 2009 03:14 PM
Quick Reply: comp cams 1442-kit
