Body off frame
Old May 4, 2020 | 05:17 PM
myolds72's Avatar
Body off frame
My project has been stalled for 6 years. My buddy who started it lost interest do I made an appointment at a body shop to get this moving again. I want to clean thw frame up and into paint
I have remove all the body mount bolts (what a PITA). 2 of them i had some difficulty with. Right now I just have 4x4 pieces between the frame and body. I would like to lift the body and support it with a 4x4 across the front and rear. Will the pinch welds at the bottom of the rockers support the weight of the body without damaging it.
Old May 5, 2020 | 11:24 AM
Eddie Hansen's Avatar
I put my supports under where the body bolts to the frame, although I see a lot of guys put boards from one side to the other and then roll the frame out, I am guessing if you used a wide enough board you should be ok temporarily, but who knows what condition the pinchwelds are in? I myself would leave it jacked up on them, but I am sure others will chime in
Old May 5, 2020 | 12:50 PM
4speed455's Avatar
When I took the body of my convertible I stored it on 4x4’s on jack stands. The 4x4’s had a one inch slot cut down the middle to make it U shaped. The pinch weld sat inside that slot which allowed the rocker to sit flat on the 4x4.
Old May 6, 2020 | 03:18 PM
myolds72's Avatar
I found this YouTube video
Old May 6, 2020 | 03:41 PM
4speed455's Avatar
That basically how I did it, except my groove was wider and in the center of a 4x4 and I used jack stands because I didn’t have that many jacks.
James71Cutlass
Aug 29, 2019 06:57 AM
Eric De Guzman
Body work
Apr 2, 2019 02:56 PM
raw442
Sep 30, 2012 01:57 PM
Eddie Hansen
Sep 14, 2012 06:26 PM
Gary's 2 442-S
Nov 18, 2008 04:08 AM
