Body mounts
Old Jan 7, 2020 | 06:03 AM
scrappie's Avatar
Body mounts
A little confused about number and location of body mounts (70 442 hard top) I lifted the body from the frame and removed the original body mounts. I didn't document which ones went where because it seemed pretty straight forward. After ordering new ones it doesn't seem to be a matching set? I then found pictures that confused me even more. The new set I have has only 2 solid mounts when I removed 6. There were 6 bolts to hold body to frame and 6 solid mounts for a total of 12 (seems minimal)
The new set has 10 bolt in mounts with 2 solid. The new set has more bolts which is more secure but I want to know what is right or wrong or better or worse.
To top it off I then came across a picture of a 72 A body restoration with a solid mount right next to the torque box mount in front which Ive never seen. Does anyone have any info on this? is the 72 body mount different?
Thornton sells a kit that is also different: They're kit has 4 solid mounts and 8 bolt-in. I haven't referenced the ASM or CSM but Im sure it will tell me something different.
Ill add some pics
scrappie
Dec 4, 2019 02:34 PM
DENT
Dec 20, 2014 07:40 PM
oldsman330
Tech Editor's Desk
Apr 7, 2012 03:55 PM
Shradezz70S
Feb 19, 2012 08:11 AM
Destroyer67
Dec 11, 2010 09:26 PM
