What mounts do I need for my '67?
Old Dec 8, 2010 | 07:59 AM
Destroyer67's Avatar
I need the mounts that are located right below the back of the front fenders. Are these body or frame mounts? These are badly deteriorated and make squeaking noises much like an old mattress. Are these difficult to replace and where is a good source for them. The ones in the back should probably be replaced too. Thanks for any help. .
Old Dec 8, 2010 | 08:48 AM
Run to Rund's Avatar
They are body mounts. Fusick sells them by the complete set. you have to remove the bolts and jack up the body a little to slide them out. I'd spray rust penetrant on the exposed threads of the front ones. They are loctited by the factory and are tight. Be careful as they can break off if the threads are rusted. You could drill a small access hole above in the body and squirt in penetrant. Some people have broken them off and had to cut larger holes to access the caged nuts inside the body cavities.
Old Dec 8, 2010 | 09:11 AM
gearheads78's Avatar
car guy
Just replace all the body mounts at once. I got my kit from Fusiks. Spray all the bolts a few days ahead of time with some pb blaster and pray the nuts don't start spinning.
edit........ it looks like I posted this way after Rund. I started to reply about 30min ago and got busy with customers
Old Dec 8, 2010 | 10:59 AM
Thanks for the response guys. I'll check with Fusiks and order a set.
How many are there?
Old Dec 8, 2010 | 12:37 PM
car guy
I think there are 8 with bolts and 2 with no bolts if I remember right.
Old Dec 8, 2010 | 02:04 PM
10 with bolts. On each side, 2 at firewall, 1 under door, one behind rear wheel, one at rear corner of frame. Generally there are only cushions in front of the rear wheel and up on the cross member at the differential.
Old Dec 11, 2010 | 09:26 PM
Thanks again everyone. I have a set coming.
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
Eddie Hansen
May 17, 2010 11:50 AM
chris83
Jul 21, 2009 02:16 PM
flatoz
Mar 15, 2009 02:03 PM
