Another cutlass! I must be a addict
Old Feb 29, 2016 | 05:46 AM
Rustbucket2's Avatar
Just bought another cutlass, a 1970 Supreme. my wife asked me why, when I had a 72 cutlass supreme setting behind the fence, and a 73 442 in the garage. I told her the car seen me, and talked to me, it said, "Please safe me, make my a great car again". so I bought it!
The previous owner had bought it in 1990, drove it 10 years, then decided it needed a full body off restoration. So in 2000, he took the whole car apart, but he had never did a restoration before, so nothing was tagged, nothing was bagged, and all the bolts went into cans, and boxes, parts were put in boxes the part would fit into, so I have interior parts, with engine parts.
Over the next 16 years the car was moved from place to place 4 times, so parts have been lost along the way. One last negative thing, he sprayed bed liner on the floors, trunk floors, and firewall, that stuff on the floors is fine, but I want to paint the firewall gloss black, so if any of you know a easy way to remove it, I'm all ears. He wasn't good at body work, any dents or low spots were filled with Bondo, the left rear quarter has a dent , the size of a base ball, he filled it with Bondo, and keep chasing the dent, now it has a good amount of filler, I will be taking that all out ,and hammering out that dent.
On the plus side, the car has little rust,, the floors, trunk floors, quarters, and fenders, even the roof are solid! but the part between the rear window and trunk is cut out, so I need to replace that, and the bottom corners, on both sides of rear window are rusted,. The previous owner took the car down to bare metal, and sealed it with something ( that was two years ago) in the pictures the car is still down to bare metal. He had the frame powder coated, installed all new shocks, springs, brakes, gas and brake lines, and all new front end steering kit, new gas tank.
Now I need to get off of here, and head out to the garage! wish me luck.
Old Mar 1, 2016 | 08:32 PM
bigin1978's Avatar
North Coast Rockets
looks like a good project. no rot in the lowers is a good thing. I wonder what happened to the firewall? Looking forward to seeing you progress.
Old Mar 2, 2016 | 04:29 AM
I do what the voices say sometimes also.
Old Mar 2, 2016 | 06:01 AM
m371961's Avatar
Many worse addictions could be had.
Old Mar 2, 2016 | 03:40 PM
True, I could have a lot worst habit. At lest my wife doesn't yell at me , lets me buy cars when the voice tells me to, she just likes to blow me s*** now and then, that's cool, I give her a ruff time whenever I can , so it evens out. As for firewall, I tried stripper, it made it sticky and very hard to scrap off( would take a long time) I tried a little heat, with heat gun, same thing, sticky and hard to scrap. Maybe I will just paint gloss black spray paint over it!
Old Mar 2, 2016 | 05:06 PM
jensenracing77's Avatar
You will find that these cars are like rabbits. You get one and you are OK then if you happen to get a second one it is all over. You end up with several.
Old Mar 21, 2016 | 05:10 PM
got motor painted, trans hooked to the motor, and the motor dropped in, still have a long way to go, but progress ! The headers went right in, no problems, but oil filter adapter was off, and steering shaft is out, that helped . need to pick up motor mount bolts, intake bolts, and get those valve covers painted tomorrow . here are some pictures.
Old Apr 10, 2016 | 07:50 AM
For the 3rd time, I still haven't learned! I bought another cutlass 72 supreme. this is one of the worst ones I have ever bought, but it had a new quarter skin on the roof of car , and the other quarter skin attached to the car. don't know what's inside car yet, lots of scrap metal, and hub caps. I thought I got it cheap, paid less then what the skins go for, and it came with a good title.
Old Apr 10, 2016 | 01:10 PM
RROLDSX's Avatar
Are you starting to attempt to hide them? You may have to join CAA. (Cutlass Addicts Anonymous)
Old Apr 10, 2016 | 01:54 PM
I am! That one is in my enclosed trailer, so no one can see it.
Old Apr 10, 2016 | 02:40 PM
kevdog442's Avatar
Member
It's comforting to know that there are others out there like me. I'm still sleeping on the couch from the last one but it can't last forever. 😁
Old Apr 10, 2016 | 03:00 PM
lol, Yep, Just like rabbits.
Old Apr 10, 2016 | 03:33 PM
You warned me.
Old Jun 2, 2016 | 07:53 AM
found time to work on my car . parts car had to be sacrificed , but that's why it's a parts car. moving along slow, but moving.
Old Jun 3, 2016 | 12:02 PM
bigin1978's Avatar
North Coast Rockets
very nice job on the deck filler panel . looks great!
Old Jun 3, 2016 | 12:50 PM
Thanks. I used fiber strand where I welded in the replacement window channel and filled the seams where the filler panel meets the quarters, That stuff is harder to sand then I thought it would be. But it should hold up better then bondo, I hope!
Old Jun 4, 2016 | 03:06 PM
Some more pictures, I can't believe how solid this car is, original floors, quarters. And also how many tools do you need to replace the rear filler panel , between rear window and trunk. and do body work!
Old Jun 4, 2016 | 07:55 PM
Gary M's Avatar
Definitely an addict.
Talking about me. I found myself today looking at the rafters in my garage and wondering if I could hang a frame there till I finished with the next body. I found one I need. I am apparently a serial cutlass collector.
Old Jun 5, 2016 | 04:11 AM
I had a frame of a 69 GTO hanging in my rafters at one time. I did get that car done. here ae pics, sorry about quality, this are pics of pics, sold the car 12 years ago.
Old Jun 5, 2016 | 05:54 AM
Gary M's Avatar
Nice work
Car looks great.
Old Jun 20, 2016 | 08:25 AM
working on dash now, sanded primed and painted black, now for the steering column, and defrost vents.
Old Sep 10, 2017 | 02:24 PM
back on cutlass, only a year later. put body into epoxy primer today, now if I find time , I will start body work next week.
Old Sep 10, 2017 | 05:07 PM
Gary M's Avatar
Lookin good.
Old Sep 15, 2017 | 01:34 PM
did my doors, fenders, and truck lid today, in epoxy primer.
Old Sep 15, 2017 | 01:51 PM
droptopron's Avatar
delete
Where are you working that you have so much space? I'm envious
Old Sep 15, 2017 | 02:07 PM
I call it "My shop " my wife calls it " my man cave" . It's a 64 X 40 x 14 pole barn, in my back yard
Old Sep 15, 2017 | 02:50 PM
It's taken my wife and I 30 + years to get to this point. ( yes she worked too to get me to this point) . I started out in two car garage( first pic) yes are cars go in there, but my wife has it set up for garage sale. then built a 24 x 40 ( next 4 pics) then I built another 24 x 40 ,but with two doors ( 6th picture ) then the new one. ( last 4 pics).
Old Sep 28, 2017 | 06:19 PM
Wow! Nice shop. nice cars, apparently nice wife....
Old Jan 28, 2018 | 01:28 PM
now that things are slowing down around here, back to the cutlass.
Old Mar 24, 2018 | 12:03 PM
did get some thing done. I think my heater hose to water pump is in wrong place, need to change that.
Old Jun 20, 2018 | 02:40 PM
  #31
made some progress on the 70 cutlass today, got those jambs all painted up. Now to put these parts back on the car for good, and get that hood out of box and start on it! It has taken me a long time of primer , block sand, primer, block sand, primer, block sand. but I'm there.
Old Jun 21, 2018 | 06:00 AM
  #32
Jeffs71's Avatar
Fantastic work so far
very impressive garage also
Old Jun 22, 2018 | 07:06 AM
  #33
Old Jun 22, 2018 | 07:08 AM
  #34
more progress yesterday, put the doors, and trunk lid on. And put my radiator support into paint. The yellow tape is holding rubber hose in place , so doors will not hit door jambs, and rub paint.
Old Jun 22, 2018 | 01:42 PM
  #35
pulled the hood out of the box, has been setting on top of a car for around a year now ! not the best hood, but you get what you pay for. I found this hood on craigslist, 15 miles from me, the man that sold it , gave up on his project, and was selling all the parts for about half price at that time. I see waves and low spots, ( glass hood ) . holes for air intake don't look right, and I can see pop-rivets in the openings . will be doing a lot of primer and block sanding. Any advice on priming and painting a fiberglass hood?
Old Jun 26, 2018 | 11:41 AM
  #36
One more step closer. Put hood in epoxy primer today.
Old Jun 26, 2018 | 12:10 PM
  #37
RetroRanger's Avatar
72 Olds CS
i like the blue will you do white stripes on the hood ? looks good so far
Old Jun 26, 2018 | 02:22 PM
  #38
When I get to that point, I'm going without a stripe , and see what it looks like, then decide stripe or no stripe. I was thinking a black stripe, because the car will have black interior and a black vinyl top.
Old Jun 27, 2018 | 09:46 AM
  #39
More progress today, put radiator support in, and fenders back on car. Still need some adjustment, after I put hood back on.
Old Jun 27, 2018 | 05:26 PM
  #40
72 Olds CS
Yeah black stripe would go nice w the top and interior.
I just got back from a local cruise about 100 cars 2 olds my supreme and an 80s cutlass!
