'72 Cutlass Supreme Restoration
Old Feb 11, 2011 | 04:28 PM
  #121
oldzy's Avatar
Not much really interesting, but here is a pic of the new heavy duty Hotchkis billet 7075 aluminum front 1 3/8" sway bar mounts. Also a pic of the vapor/charcoal canister bracket I acquired from a member here recently that I just had powdercoated.
Old Feb 13, 2011 | 03:53 AM
  #122
mrgm's Avatar
Looking good. I am about to start a 71 that looks like you 72, just a tad darker.
Old Feb 17, 2011 | 08:06 PM
  #123
oldzy's Avatar
Front Disc Backing Plates and Caliper Brackets back from Steve Gregori @ brakeboosters.com. Still has a bit of an unsightly dent on the bottom of one of the backing plates.
Old Feb 17, 2011 | 08:23 PM
  #124
oldzy's Avatar
Crude painting methods of spindles and steering arms using Cast Blast. New Moog tie rods, center link, and idler arm are next.
Old Feb 17, 2011 | 09:15 PM
  #125
O's_Car's Avatar
Wow, I just sent my backing plates and caliper brackets to Steve for replating this week, and I was going to take my spindle and steering arms to a shop for blasting before painting them grey. I even had a similar dent in one of my backing plates. Kinda freaky man!
Keep up the good work, it motivates me to do the same on mine.
Old Feb 17, 2011 | 10:33 PM
  #126
mrgm's Avatar
I love the look of "just cleaned" cast parts.
Old Mar 19, 2011 | 04:30 PM
  #127
oldzy's Avatar
Springs and spindles finally installed. Nothing is torqued yet.
Also have not yet fixed the rear wallowed out frame ear mount hole on the drivers side lower control arm. Will likely tack weld a washer to the outside of the mount later on.
Old Mar 21, 2011 | 06:25 PM
  #128
4424me's Avatar
wow. everything looks great!
Old Mar 21, 2011 | 06:42 PM
  #129
oldzy's Avatar
Thx. Now I am trying to figure out the best way to address this 'gap' issue. Obviously this mount was stressed quite a bit, as the rearmost hole is wallowed out as well.
Old Mar 22, 2011 | 06:46 PM
  #130
oldzy's Avatar
Torqued spindle castle nuts to ~43 and 73ft lbs top and bottom, and mounted the backing plate/caliper bracket/steering arm (all from '2blu442' BTW) on the pass. side. The top aftermarket spindle bolt has a thick head on it... hoping it clears the rotor fine, as I cannot recall the gap between inside of rotor and backing plate. I was going to have the original bolts replated, but do not really trust 40 year old bolts, especially ones that need to be torqued to 90+ ft lbs.
Old Mar 22, 2011 | 08:17 PM
  #131
Cratethis's Avatar
Great work! Enjoying your thread!
Old Mar 23, 2011 | 07:26 AM
  #132
Schne442's Avatar
No it's not a parts car!!
Looking good. It would be fun to see how many cars have 2blu442 parts on them. I got a set of lower control arms from him, look near new after sand blasting them.
Gary
Old Jun 3, 2011 | 08:33 PM
  #133
oldzy's Avatar
Not much lately. These are about the latest pics, hope to have the front end done within a few weeks, and working on the drivetrain.
Old Jun 14, 2011 | 07:45 PM
  #134
oldzy's Avatar
Not much done recently other than my tie rods (too long) don't fit the fancy Hotchkis adj. hex sleeves.
Picked up a set of Rear LCA Currectrac's by Currie. Still not sure if will be using the huge beefy steel Hotchkis ones I have on there now (poly on both ends), or these. These Currectrac's weigh exactly 7.22lbs each. Of course they are purty and all, plus being solid aluminum. Got them directly from Currie.
One of the main reasons I got these ones, is that the Hotchkis arms are wide and hit the axle ears (which forbids any kind of decent 'drooping' to install springs for example). I am 'assuming' these ones won't have that issue since they are so much thinner. But then there is the issue of sway bar fitment.
Old Jun 16, 2011 | 05:03 PM
  #135
oldzy's Avatar
Just a FYI (since I have not seen any pics yet), this is what you get when order Fusicks' Olds gold paint.
Old Jun 19, 2011 | 06:09 PM
  #136
oldzy's Avatar
Removed rear Hotchkis LCA's and put on Currie Currectrac's. There is a now a gap and the arms are not hitting the axle ear mounts like they did with the Hotchkis arms.
Hotchkis arms
Currectrac arms
Old Jun 20, 2011 | 07:49 PM
  #137
75cutty455's Avatar
This is one serious restoration project. Keep up the good work. Inspiring I tell ya. Inspiring......
Old Jun 23, 2011 | 11:37 AM
  #138
oldzy's Avatar
Thx.
I just ordered another set of tie rods, this time from AC Delco. Reason was that my Moog tie rods did not work properly withe my Hotchkis adj sleeve (last pic below). Rods seemed too long, and the rotor/disc assembly would not straighten out, even after the rods were threaded in as far as they could go.
The AC Delco (the inner rods anyway) seems about 1/4" shorter. Anyway... it was a nice change to see the below stamp on the inner tie rods.
Old Jun 23, 2011 | 11:39 AM
  #139
oldzy's Avatar
So... if these Delco tie rods work... then I will have a extra set of new inner/outer tie rods that I will prob sell. I cleaned and primered them all, then sprayed with Seymour Cast Blast.
Old Jun 23, 2011 | 08:12 PM
  #140
oldzy's Avatar
Intake (from 2blu4u) bead blasted and painted with Fusick Gold. I don't know... it looks a little pale/flat in person. Flash is on in pics as well.
Old Jun 25, 2011 | 06:35 PM
  #141
scubastever's Avatar
this is not my car lol
wow what a build! impressive parts list..
FYI the moog tie rods are always too long, and have to be hack sawed to proper length. the secret is running the lock nut onto the tie rod before cuttin. then back off the nut slowly and chase the threads.
keep up the great job!
Old Jun 26, 2011 | 05:10 PM
  #142
oldzy's Avatar
Thanks.
Here is a pic of the thermo housing I just painted with Fusick Gold. You can see what I was talking about in re to the 'pale' look of the intake. The machine shop did it, and looks like they just gave it a light dusting of paint. If there can be that much variation in the turnout... I am actually not certain what the best method is. Several coats... several 'light' coats... a few heavy coats, distance, etc.
Old Jun 28, 2011 | 01:01 PM
  #143
oldzy's Avatar
Took a valve cover off as was curious how good or bad it looked like. It looked pretty good, same as did 17 years ago when I rebuilt the engine. Still has the orange/red paint on from the machine shop to keep oil moving (they called it loptik, gloptik or something - can't recall for certain the name).
Old Jun 28, 2011 | 01:52 PM
  #144
Indy_68_S's Avatar
Glyptal !
Wow... That looks really clean. Did you even drive it after the rebuild ?!?
Old Jun 28, 2011 | 08:44 PM
  #145
oldzy's Avatar
Glyptal, that it, thx.
I drove it quite a bit actually, especially back in the college days when it was my only ride.
However, when I took the intake off for the very first time a few years before rebuilding.... there was this most disgusting odor I cannot even really put into words, and this buildup of black 'stuff'. The car was driven daily all year round (lots of salt here in the winter) for at least 16 years before I got it.
Old Jun 28, 2011 | 09:50 PM
  #146
scr8p's Avatar
was it damp or real humid when you painted the intake? looks like it blushed to me.
Old Jun 28, 2011 | 09:52 PM
  #147
oldzy's Avatar
The machine shop painted it... very lightly. It needs more coats. They also did not bead blast into the crevices good enough and I can see rust spots. joy
Old Jul 3, 2011 | 12:12 AM
  #148
oldzy's Avatar
Not great quality, but some rear bumper pics. Bumper is NOS from eBay (one of the 1st things I picked up). Even though NOS, the ear mounts for the tail light housings were out of whack. Had to bend most with a pair of pliers just to get them in. One was inward too much about 1/2".
Tail light/reverse/license lenses are repros, and rear tail housings are originals off eBay that were cleaned up a bit. Reverse/License housings and Tail light rock shields are repros as well. License plate bracket is my original.
Just need to paint the tail light screws black, and put in the 4 red inner tail light things.
powdercoated in flat black (seems 'satin' to me)
Old Jul 4, 2011 | 01:25 AM
  #149
mrgm's Avatar
so cool. better than factory .
so what's up with the body?
Old Jul 4, 2011 | 03:56 AM
  #150
Aron Nance's Avatar
Remarkable detailing!!!!!! A pleasure to peruse this thread when you wake up too early some morning and have a lot of time to really "look" at the pictures. You are going to make your Grandmother proud when her/your Oldsmobile is finished!
Old Jul 4, 2011 | 09:26 AM
  #151
oldzy's Avatar
Thanks.
As for the body, I am leaving it last. It is badly rusted/rotted, so I am going to prob have some body person come out to see if worth while to fix (the shell - rotted roof in particular), then go from there. If it is not really worth while, then I am going to look for a nice rust free shell.
Old Jul 4, 2011 | 10:22 AM
  #152
oldsguybry's Avatar
NOVICE car nut
excellent job....so when are you going to do my car ?....I wish I had the time....money.....and the place to do mine , but all I can do is keep it from rusting till I either give it to my kid some day or sell it
Old Jul 20, 2011 | 02:33 PM
  #153
oldzy's Avatar
Picked up a gaggle of S/S valves (and bronze guides) from 'thevalveguy' off eBay (std. and W31 size valves). Got both sets just in case I decide not to have the bigger valves put in for whatever reason. Can't do much though head wise right now, since I don't have a cam in hand, springs, etc. The plan was to have the heads done by BTR Performance in Rochester, NY, as I am not convinced my local machine shop is a big Olds guy.
Old Jul 20, 2011 | 10:46 PM
  #154
UnkleMarc455's Avatar
GM's Best Division
This is a fantastic build, thanks for keeping the updates coming!
Old Aug 10, 2011 | 01:14 PM
  #155
oldzy's Avatar
Slowly starting to accumulate some engine parts $ permitting. Picked up my custom ground hyd. roller cam (from BTR Performance), and Harland Sharp pedestal mount roller rockers, as well as BTR's max perf. book.
This roller related stuff is expensive. Roller lifters and pistons are next. I forgot that I posted a question over @ Comp Cams forums asking whether these roller cores were made in the USA. They replied that they were. Will have to take their word for it. Just a bonus if true though.
Old Aug 10, 2011 | 01:38 PM
  #156
OLD SKL 69's Avatar
GM Enthusiast
Nice detail work Oldzy! Keep the pics coming.
I would be nice to find some NOS bumpers for my 71 too, don't want to buy the chinesium stuff either.
Pretty sure that all comp cams items are made in the USA. That's the only brand I have been using for 20+ years now.
Old Aug 11, 2011 | 08:18 PM
  #157
oldzy's Avatar
Thx.
There is a fellow local to me with a NOS 71-72 rear bumper (with cutouts though). He is also a member here. I lucked out finding that NOS one above. It was even shipped in its original GM wrapping (with other padding wrapped around it of course).
http://s613.photobucket.com/albums/t...t=DSC00548.jpg
http://s613.photobucket.com/albums/t...t=DSC00557.jpg
Old Aug 12, 2011 | 04:23 AM
  #158
aretubj's Avatar
Oldzy
Although I'm doing a '73, we are both at the same stage in restoration and I too live in Hamilton.
We should compare notes.
Joe
Old Sep 2, 2011 | 08:17 AM
  #159
Hot 442's Avatar
Oldzy - I'm starting a 72 442 from the south. In need of a pair of bumpers.....any idea what he wants for his rear nos?
Do you have his contact number or user name on here?
Thx
Ps I'm just east of you near Oshawa, awesome work, I've been following the thread. How much you figure you have in the project thus far?
Old Sep 2, 2011 | 07:21 PM
  #160
oldzy's Avatar
No idea on the price unfortunately.
His uname here is 'madd442' (https://classicoldsmobile.com/forums...s/madd442.html)
Steve
905-692-0406
Binbrook ,ON
thecutlassguyu@hotmail.com
http://s613.photobucket.com/albums/tt216/THECUTLASSGUY/
As for cost so far... too much. I will have to sit for a while to figure it out.
