70 cutlass supreme convertible my first frame off
Old November 12th, 2021, 08:12 PM
  #201
tkcutlass's Avatar
Only had 1 can of trunk paint figured I'd get a light coat on before the topcoat window closed and I would have to sand it down.
Unfortunately, it appears it's no longer available from Eastwood.
Got a kit coming from Thorton to finish it.
tkcutlass is offline
Old November 13th, 2021, 08:09 PM
  #202
tkcutlass's Avatar
Started the block sanding.
Old November 14th, 2021, 08:40 PM
  #203
tkcutlass's Avatar
another round of blocking. I may hold off on pics for a while how many pics of blocking can anyone take.
Old November 15th, 2021, 06:30 AM
  #204
72 Olds CS
RetroRanger's Avatar
Your still making great progress on this.
will you work thru the cold weather months?
maybe paint in the spring.
here in mass weve been seeing nightime temps in the mid 30s w several predictions for snow showers in the coming days.
RetroRanger is offline
Old November 15th, 2021, 08:26 AM
  #205
tkcutlass's Avatar
I have a nice HD75 propane heater, so with luck I will be blocking and moving on to the fenders hood and trunk and have everything ready for painting in the spring.
Hope to have the engine back from dyno in the next couple of weeks.
The plan is to put the engine and tranny in, put the radiator support in and start fitting the hood, doors, and fenders. (Hopefully by Christmas)
Thanks for viewing.
Old November 15th, 2021, 05:23 PM
  #206
tkcutlass's Avatar
The paint from thoron came in, I think I overdid the aqua. You really need to spray at a great distance like 3ft to get small dots.
dusted a little more gray
Old November 16th, 2021, 08:02 PM
  #207
tkcutlass's Avatar
I was lucky enough to have a 50 yr veteran body man over to give some tips on the bodywork. ( This is sh....t I think was his first comment). Jeez ... Tell me how you really feel.
Hopefully, he set us on the right track.
It's nice to have a straight shooter that knows what he's doing.
Old November 22nd, 2021, 07:41 PM
  #208
tkcutlass's Avatar
more mud and sanding, then primer
Old November 27th, 2021, 07:37 PM
  #209
tkcutlass's Avatar
Worked on the other quarter and trunk lid.
corner needs a little tlc
Old December 12th, 2021, 08:42 PM
  #210
tkcutlass's Avatar
Got the quarters pretty close to where they need to be.
Stripped the hood and added some filler to the trunk lid.
Little tweaking required
Old December 13th, 2021, 05:29 AM
  #211
Phoenix8990's Avatar
It's looking really good, great work! I noticed your bead blaster, who makes that?
Steve
Phoenix8990 is offline
Old December 13th, 2021, 06:59 AM
  #212
1968 442 Convertible
bry593's Avatar
You are learning so much, not to mention this manual work should help keep your body in shape.
Did not know spray booth bounce house is a thing. Pretty cool. I used to hang tarps under carports, or even worse, just paint completely exposed outside and hope for the best.
Almost time to reassemble to frame. That will be cause for a celebratory beer or two.
bry593 is offline
Old December 13th, 2021, 08:02 AM
  #213
tkcutlass's Avatar
Steve
Steve Thanks for the kind words.
USA made barrel blaster https://www.barrelblaster.com/
Old December 13th, 2021, 08:07 AM
  #214
tkcutlass's Avatar
Hoping to put the engine and tranny in before mating the frame to the body. With luck that will be in the next month or so.
Old December 20th, 2021, 08:06 PM
  #215
tkcutlass's Avatar
Got the trunk brace in and the trunk lid close to being lined up.
I was very concerned that I wouldn't be able to get the brace and catch lined up properly but it wasn't as bad I thought.
Needs a little cleanup but it's now functional.
The post on the rotisserie blocked access to the trunk keyhole so I made a tool to unlock it through the back seat.
Special tool to unlock trunk from back seat
Old December 21st, 2021, 04:23 AM
  #216
Looks good. Tim. You have the "stick to it 'till done" mentality, it's so hard to maintain but you have . Great job!
Greg Rogers is online now
Old December 21st, 2021, 08:08 AM
  #217
tkcutlass's Avatar
Thanks Greg.
Not done yet. I hope to continue "the stick to it" be nice to have it on the road for the summer.
Old December 22nd, 2021, 09:06 PM
  #218
tkcutlass's Avatar
Cleaned up the welds and got the catch support painted,
Added a couple shims to the trunk lid per tnswt suggestion and it made a big difference.
Old December 23rd, 2021, 06:38 AM
  #219
72 Olds CS
That looks much better, and better price for shims than the 2 for $29 you had posted.
i just noticed you have the antennae hole on the rear fender, did you add that or was it like that?
Old December 23rd, 2021, 07:53 AM
  #220
tkcutlass's Avatar
Yup 10 bucks for 144.
The hole was there, covered with Bondo if I remember correctly.
Thinking of putting a power antenna there. Any suggestions on a compatible power antenna?
Old December 30th, 2021, 09:31 PM
  #221
tkcutlass's Avatar
A little wet sanding and I think this quarter is dam close.
Old December 30th, 2021, 09:51 PM
  #222
tkcutlass's Avatar
Taking a little break from bodywork and trying to get the chassis ready.
Had to make a bracket and modify the brake lines to accommodate the rear discs.
Old January 2nd, 2022, 07:49 PM
  #223
tkcutlass's Avatar
Trying to clean up a few loose ends and get more in primer.
A little more clean up on the wheel arch and the quarters should be good to go.
Old January 2nd, 2022, 09:08 PM
  #224
Progress is progress. Good for you.
Did you figure out if that is a factory power antenna location?
no1oldsfan is offline
Old January 3rd, 2022, 08:32 AM
  #225
tkcutlass's Avatar
No idea if its factory location sure looks like it.
Did not see it on the build sheet, and it does have the windshield antenna connector.
Old January 3rd, 2022, 02:42 PM
  #226
Looking good, you have had quite the journey!
Steve
Old January 10th, 2022, 09:04 AM
  #227
tkcutlass's Avatar
Stripped the fenders that I picked up, one was in very good shape.
The other not so much. paid top dollar for a pair of fenders with "No bondo"
Check your purchases carefully.
Old January 12th, 2022, 08:24 AM
  #228
tkcutlass's Avatar
Had better luck with a pair of doors that I found on CL.
Picked up my th400 on the way to get the doors.
Got one fender and the hood primed.
Old January 24th, 2022, 09:38 PM
  #229
tkcutlass's Avatar
The door patches ended up being more of a challenge than I thought.
One area I tried patching was so bad I cut it out and started again. (Remembered a trick from this video
The second patch came out pretty good but attaching it was tricky.
Ugly patch kept burning through trying to attach to various old thin rusted areas
Start of patch tacked in
attaching each a few layers
detach patch
weld inside and out
much better than the disaster I cut out from the first attempt
tacked back in to cut and add a top section
Old January 25th, 2022, 08:16 AM
  #230
72 Olds CS
Good tip, rev 2 looks much better than 1.0
Old January 26th, 2022, 05:57 AM
  #231
it's a complex corner to do, a lot of surfaces, Looks good,
Steve
Old January 27th, 2022, 10:49 AM
  #232
Car Nerd
OldSoldier's Avatar
Thanks for sharing, I have to do these corners on my doors and this was what I was thinking of doing. Good to see the process worked well.
OldSoldier is offline
Old January 29th, 2022, 07:45 PM
  #233
tkcutlass's Avatar
The other door was in better shape.
Small patch on the corner and on the front.
Old January 30th, 2022, 07:53 PM
  #234
Eddie Hansen's Avatar
Wow wow wow
Man you have been on a tear!! Great work spent the evening getting all caught up on this build , great work !! Thanks for sharing
Eddie Hansen is offline
Old January 30th, 2022, 08:17 PM
  #235
tkcutlass's Avatar
Thanks for the kind words, it's nice to see you back.
Trying to spend at least an hr or two a day to keep things moving.
Unfortunately not much done this weekend (besides dealing with the foot of snow)
Old January 30th, 2022, 08:28 PM
  #236
Hear that
Lol yeah it was a good storm we got about the same
I did manage to spend some time sorting stuff , looking forward to your progress
Old February 3rd, 2022, 10:45 PM
  #237
tkcutlass's Avatar
Got some mud on the doors, and got them primed.
A little more tlc and they should be good to go.
Old February 13th, 2022, 07:45 PM
  #238
tkcutlass's Avatar
Painted the dash, firewall, and underside of the deck lid.
got a few runs to deal with
Old February 20th, 2022, 02:32 PM
  #239
I may have missed it in the past but what color are you going to paint it?
Steve
Old February 20th, 2022, 03:19 PM
  #240
Looking good man real good
Quick Reply: 70 cutlass supreme convertible my first frame off
