70 cutlass supreme convertible my first frame off
Old April 17th, 2021, 01:36 PM
  #121
Phoenix8990's Avatar
I agree with you, a lot of little pieces vs. some big ones. Just the firewall and rust under the dash makes it look pretty endless, but you wouldn't be the first to take something like that on. I think that you'll be happier in the long run with the one your working on. It looks like it has good bones and will come out nice.
Steve
Phoenix8990 is offline
Old April 17th, 2021, 06:51 PM
  #122
tkcutlass's Avatar
Some progress today, finished removing the rear cross member cleaned up the valence, and hit it with rust converter, removed the trunk drop off.
With luck tomorrow I can start putting the trunk in along with the rear cross member. I left the original trunk edge in the hopes it will make things easier to line up properly.
tkcutlass is offline
Old April 18th, 2021, 07:49 PM
  #123
tkcutlass's Avatar
Got a late start today, silly little things like mowing the lawn.
Trunk drop-off is in and the rear cross member is tacked in.
I may try to get the car flipped back over and onto the frame to ensure proper alignment.
Old April 20th, 2021, 09:26 PM
  #124
tkcutlass's Avatar
Got the rear cross member welded in, back onto the rotisserie, and flipped back over without it falling off.
Old April 21st, 2021, 05:54 AM
  #125
Your getting closer, can't wait to see it back on the frame! It is nice to have all the metal fabricating equipment you have. Great job!
Steve
Old April 25th, 2021, 05:30 PM
  #126
tkcutlass's Avatar
Finally got the trunk tacked in.
Haven't decided how to handle the center seem yet but through some aerobatics, I managed to get trunk dropoffs aligned.
Old April 26th, 2021, 05:43 AM
  #127
Looking good, moving right along, looking forward to seeing it in primer.
Steve
Old April 28th, 2021, 09:23 PM
  #128
tkcutlass's Avatar
More welding, got the seam welded up.
Next time I will properly use the flange tool on the seam.
Old May 1st, 2021, 06:53 PM
  #129
tkcutlass's Avatar
I finished welding up the trunk.
The new cross member has multiple mounting points which allowed me to extend the rotisserie arms wider so i could roll the frame in place leaving the rotisserie attached.
I lifted front with an engine hoist and was able to move the front of the rotisserie out of the way
Old May 2nd, 2021, 05:58 AM
  #130
Looking good, when do you think you will be ready for primer?
Steve
Old May 2nd, 2021, 07:17 AM
  #131
tkcutlass's Avatar
Steve
Thanks, Steve,
I am about a week away from the 1-year mark of the initial tear down.
I would love to have it primed by then.
With luck, I will have the frame attached today and have the rear braces welded in.
I have to replace the RH front cowl. If all goes well I will be priming by next weekend.
Thanks for the encouragement.
Tim
Old May 2nd, 2021, 10:12 AM
  #132
Trophyblue442's Avatar
Looks good. Glad to see the trunk brace put to good use!
Trophyblue442 is offline
Old May 2nd, 2021, 06:52 PM
  #133
tkcutlass's Avatar
Thanks for providing the brace, I think the one I ordered is still stuck in the Suez canal.
Old May 2nd, 2021, 07:15 PM
  #134
tkcutlass's Avatar
Little work today but big progress I managed to get all 8 frame to body mount bolts installed.
Normally probably not that big of a deal, however after repairing several body mounts on the frame, installing a new rear cross member, and welding a section of floor brace, I was very concerned about 1 or more of the 9 or so opportunities to out of tolerance.
With luck, I will weld the trunk braces in tomorrow.
Old May 3rd, 2021, 06:07 AM
  #135
At first glance I thought you were lowering the body down onto the unpainted frame and thought OMG how can he be doing that, then remembered you had the frames stacked and took a closer look. Great progress and Looking good, amazing job you are doing.
Steve
Old May 3rd, 2021, 09:31 AM
  #136
BackInTheGame's Avatar
Very cool! Fun to follow along with your progress!
BackInTheGame is offline
Old May 3rd, 2021, 03:46 PM
  #137
tkcutlass's Avatar
Thanks, guys I appreciate the support.
Old May 3rd, 2021, 08:18 PM
  #138
tkcutlass's Avatar
Removed the rotisserie and engine lift for better access.
Got the trunk braces tacked in.
Figured I'd take advantage of it being on the frame so I started removing the RH cowl.
Old May 5th, 2021, 09:32 PM
  #139
tkcutlass's Avatar
Finished removing the cowl.
Cleaned up some rust and hit it with rust converter.
Looks like I may have a little work before installing the new cowl.
Old May 9th, 2021, 06:40 PM
  #140
tkcutlass's Avatar
Even though you wouldn't be able to see it I couldn't leave the swiss cheese where the inner cowl meets the fender mount.
Old May 14th, 2021, 05:35 PM
  #141
tkcutlass's Avatar
I got the cowl mostly wrapped up.
Next up a little grinding then back on the rotisserie.
Old June 6th, 2021, 08:00 PM
  #142
tkcutlass's Avatar
Removed the body again. and welded up the trunk braces.
Old June 7th, 2021, 04:46 PM
  #143
72 Olds CS
RetroRanger's Avatar
looking good
to hot to be doing any weleding IMHO tho !!!
RetroRanger is offline
Old June 10th, 2021, 07:29 PM
  #144
tkcutlass's Avatar
Package from Right Stuff showed up.
Brake and Fuel lines going in
Old June 10th, 2021, 07:42 PM
  #145
tkcutlass's Avatar
Removed the frame underneath cleaned and painted the rear,
Old June 10th, 2021, 07:49 PM
  #146
tkcutlass's Avatar
Got the wrong control arm bolt kit (it was for the front)
Laid out the suspension parts for install. (waiting on correct bolt kit)
Old June 10th, 2021, 08:24 PM
  #147
tkcutlass's Avatar
Prepped the last few suspension parts.
Old June 20th, 2021, 07:26 PM
  #148
tkcutlass's Avatar
Got a few more pieces painted and installed the rear suspension.
Old June 20th, 2021, 07:29 PM
  #149
tkcutlass's Avatar
Blasted the steering arms and started assembling the front suspension.
Old July 16th, 2021, 01:06 PM
  #150
Car Nerd
OldSoldier's Avatar
tk, that looks like it is coming along nicely. I kind of wish that you'd continued on ole red, because that's even rustier than my ole red, ha! I never saw one worse, at least that I remember. I haven't posted it up here yet in detail because I don't want others to talk me out of it. I've already spent too much on parts to turn back now...
Good work sir!
OldSoldier is offline
Old July 18th, 2021, 08:01 PM
  #151
tkcutlass's Avatar
Good chance I will go back to that one at one point.
Old July 18th, 2021, 08:30 PM
  #152
tkcutlass's Avatar
A few updates.
rebuilt steering box installed with most of the suspension installed.
Old July 18th, 2021, 08:35 PM
  #153
tkcutlass's Avatar
More welding and patching
Old July 18th, 2021, 08:45 PM
  #154
tkcutlass's Avatar
Decided to add a 455 to the mix
Stripped it and brought it to the machine shop
Old July 22nd, 2021, 07:36 PM
  #155
tkcutlass's Avatar
Tackled the trunk gutter I am pretty happy how it turned out the channel from rust repair helped tremendously but I had to fab a companion piece based on all the rot.
Channel from rust replace
fabbed companion piece
Old July 23rd, 2021, 06:18 AM
  #156
It's coming along. Are you getting close to completing the metal work?
Steve
Old July 31st, 2021, 09:53 PM
  #157
tkcutlass's Avatar
Steve
Getting closer, moved on to quarters and patched outer wheel wells.
Not sure about the shape and size of the edge on the outer wheel well, had to guestimate based on the edge of a rusted piece.
The bulge goes below the quarter panel, not sure if it should. Anyone with pics of the quarter to wheel well behind the tire.
Not sure about the bulge from the outer wheel well
Old August 1st, 2021, 06:04 AM
  #158
It's a little late but I was told you could take the opposite wheel arch and they would fit. PS front to DS rear or DS front to PS rear. You could cut it out and it would fit properly. Needless to say, you are doing a great job. It's nice to have all the sheet metal equipment to fabricate and have the space o work in.
Steve.
Old August 10th, 2021, 08:58 PM
  #159
tkcutlass's Avatar
Got a couple more patches in on the passenger quarter, realized I had the outer wheel well patch on the driver's side inverted. the rounded edge goes in front of the wheel, so I will be doing a lumpectomy on that lump on the drivers side.
Old August 11th, 2021, 05:55 AM
  #160
How do you eat an Elephant? One bite at a time! WOW, you are getting there, I'm looking forward to seeing it in primer one of these days.
Steve
Quick Reply: 70 cutlass supreme convertible my first frame off
