69 Cutlass S differential gasket
Old Oct 1, 2021 | 05:34 AM
lala5818's Avatar
I have a 69 cutlass S. 12 bolt rear diff. When I change the fluid do use RTV sealant alone or use a gasket with the sealant?
heres several pictures of the gears. Will any of these numbers tell me the ratio and whether or not it’s a posi?
Old Oct 1, 2021 | 10:23 AM
v8al's Avatar
Registered Olds Owner
Looks like a 2.56 rear. "16 A 41" translates to: 41 ring gear teeth divided by 16 pinion gear teeth 41/16=2.56
Can't tell if it's an anti-spin carrier from the pics.
You can test by manually spinning the driveshaft and seeing if both tires rotate in the same direction
Old Oct 1, 2021 | 11:52 AM
BackInTheGame's Avatar
Before you put the cover back on, spin the diff and look into the spider gear area in the middle of the carrier. If you can see clutch plates on the outer edges of the carrier - toward the axles - and an "S" spring in the middle, it's Anti-Spin.
Old Oct 1, 2021 | 12:35 PM
You can use RTV only, just make sure to thoroughly clean all the oil off the mating surfaces. When I use a gasket, I typically put a thin smear of sealant on both sides of the gasket, just to make sure it doesn't leak. I don't like leaking gear oil.
The Anti Spin (posi) carrier will have an S spring visible between the side gears as in the picture below. An open diff will not have the S spring.
https://classicoldsmobile.com/forums...-ratio-123000/
Old Oct 1, 2021 | 02:22 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have used just RTV on multiple diffs, including my 70S 12 bolt Type O.
maineolds
Jul 17, 2021 03:47 PM
Oldssupreme
Jul 27, 2016 03:56 AM
fatgroundhog
Jun 14, 2015 03:04 PM
Harmon
Drivetrain/Differentials
Oct 27, 2013 07:33 AM
spyke
Mar 28, 2013 08:13 PM
