68 442 sports coupe resto
Old Jan 28, 2020 | 12:55 PM
wakid's Avatar
1968 442
sapphire blue DD
black bucket seat
floor shift auto and
ac
i purchased the car before I had children and started getting things done, I felt rather quickly then progress ceased till recently. Took bout 4 years to get back to working on the car but Now I think I got somewhat of a handle on the parent thing and have started working on it again.
got two cars with the purchase both are 68s one f85 and the 442.
the 442 had been rear ended once upon a time and they put a new tail light panel in the car. So I took the chassis out of the f85 cleaned it up sand blasted wire wheeled sanded so on then treated it with por 15.
Now I would have done a epoxy treatment and real paint but such is life...
built the rear end 12 bolt type O got 3.90 rear gears Eaton POSI unit from JD RACE great guy to work with, also upgraded the shafts..
has all umi rear suspension tubular lowers adjustable uppers. And their kit with the Viking coil overs.
front has all new bushings tie rods idler ect everything is all new including disc brake set up..
working on the body now.. have quarters en route and will be starting in that process soon..
Old Jan 28, 2020 | 01:42 PM
BackInTheGame's Avatar
Nice! Good luck with the Project - that's a pretty intense effort!
Old Jan 28, 2020 | 01:50 PM
wakid's Avatar
Thanks.
way more work then I wanted to put out but when finished they cost more then I want to pay.
Old Jan 28, 2020 | 02:50 PM
Nice work. Its always good to see the old cars resurrected.
Old Jan 28, 2020 | 05:39 PM
oldsmoboogie's Avatar
Looks like you have a handle on it, keep it up.
Old Jan 29, 2020 | 08:33 AM
wakid's Avatar
Couple more photos of work already done. im
hoping by the end of the week to have epoxy on bottom of the floor. And the bedliner applied to it as well.
Old Jan 30, 2020 | 12:21 PM
wakid's Avatar
Fixed the the rear of back of the quarters best I could yesterday, really wish they made full quarters for our cars.
also got the only rust in the trunk cut out and patched in..
Old Feb 2, 2020 | 07:18 PM
wakid's Avatar
Is this foam required? I’m assuming they don’t sell blocks of it any where would spray foam work as a substitute?
Old Feb 10, 2020 | 12:17 PM
wakid's Avatar
Decided to just run the rear window patched without the foam don’t see it affecting the window or it’s seal later so it’s welded up.
got some done on the core support pretty happy with how it turned out.
waiting for quarter skins still hopefully be here by the weeks end.
Old Feb 10, 2020 | 02:48 PM
Eddie Hansen's Avatar
Pretty damn awesome work keep at I’ll be following along I have no idea what the deal is with that foam? Sound deadener?
Old Feb 10, 2020 | 05:40 PM
wakid's Avatar
thanks! it’s going At a snails pace it seems.
only thing I can think of for the foam would be to help stop movement of the sheet metal under the glass? No idea we’ll see if I have issues with it in the future because it don’t have foam now.
Old Feb 26, 2020 | 11:12 AM
wakid's Avatar
Haven’t made much for progress on the car lately but decided to build a rotisserie should help aid In painting the bottom of the car.
Old Feb 26, 2020 | 05:17 PM
RetroRanger's Avatar
72 Olds CS
nice work that will make it much easier to access the bottom of the car for sure.
Old Feb 28, 2020 | 11:50 AM
oldsjoe's Avatar
It can be a time consuming project. But well worth the efforts in the end! Nice work! Joe
tkcutlass
Drivetrain/Differentials
24
Mar 27, 2021 07:42 PM
oldstata
Nov 30, 2020 05:25 PM
olds4421st
Dec 28, 2019 05:52 AM
gearheads78
Dec 7, 2017 07:16 PM
flatoz
Mar 23, 2017 04:40 AM
