66 and 67 0.921 lifter interchange years
Old Dec 4, 2022 | 11:46 AM
oldsnmopar's Avatar
Does the 0.921 lifters from 57-64 engines fit the 66 and 67 E block 400 in the 442? Same size, hydraulic, but the working height and all?
Old Dec 4, 2022 | 01:32 PM
OLDSter Ralph's Avatar
Check this catalog out
http://toplineauto.com/
Old Dec 4, 2022 | 02:35 PM
66-3X2 442's Avatar
I believe the early lifters have a different bleed hole/oil groove location than the later .921 lifters. If they are the same the part# would be the same.
Old Dec 4, 2022 | 05:15 PM
Charlie Jones's Avatar
Phantom Phixer
The STOCK .921 lifters from 57 thru 64 did not supply oil to the pushrods. And cannot be used in 65 thru 67 engines.
The 65 thru 67 lifters provide oil through the holes in the pushrods to the rockers. All replacement lifters made today are the 65 thru 67 type.
The 65 thru 67 lifters will work in a 57 thru 64 engine, although the pushrod oil feed is blocked by the solid push rod end and is not used.
Old Dec 4, 2022 | 05:24 PM
oldsnmopar's Avatar
Thank you for the responses.
Old Dec 4, 2022 | 05:27 PM
oldsnmopar's Avatar
I've looked, and I dont see the 921 for the 66 442
Old Dec 4, 2022 | 06:03 PM
Phantom Phixer
Look under 442, 65-67 6.6 liter # A-0957
tecar442
Nov 28, 2020 07:57 AM
67Rocket
Drivetrain/Differentials
May 19, 2017 06:14 AM
scotts67
Cars Wanted
Jun 19, 2015 08:05 AM
Kevin W
Apr 27, 2012 05:50 AM
yammiman
Jan 16, 2009 08:17 AM
