'66 442 Disc Brakes
Old Sep 25, 2014 | 08:00 PM
patmills's Avatar
442forsure
'66 442 Disc Brakes
I would like some advice. I am considering putting power disc brakes on my car. Supercars Unlimited lists the stock parts for the '67 brakes set up. It is not important to me that the parts be Oldsmobile original as long as they are good quality and not made in China. Has anyone used the stock Olds parts and do you have any advice for the install? Has anyone used parts other than Olds and if so what were they and who was the supplier?
Pat Mills
Old Sep 25, 2014 | 08:05 PM
johnnyjaws's Avatar
any buick or pontica should work even chevy as long as its of an a body
Old Sep 26, 2014 | 05:52 AM
Ranzan's Avatar
Getting There
Pat i put a set on from Canada line and tube
he is located in Victoria and great to deal with
Old Sep 26, 2014 | 11:19 PM
patmills's Avatar
442forsure
Thanks Wes - you moved since we last talked. My car has just sat for the last while - am wanting to do some more projects - thinking about a 6 speed Tremac , power steering, the power disc conversion, new coils and shocks, and so on.
Pat
Old Sep 27, 2014 | 07:28 AM
2blu442's Avatar
Hi Pat
If you'll read through this thread it may give you some more ideas. I've done this swap several times, plus adding power steering can really make driving these cars more pleasant. John
https://classicoldsmobile.com/forums...sk-brakes.html
Old Oct 6, 2014 | 07:47 PM
patmills's Avatar
442forsure
John
Thanks for the information.
Pat
Old Oct 6, 2014 | 08:17 PM
66luvr's Avatar
I like this company's stuff because you can use your original spindles and their conversion does not set the wheels out (closer to the fender lip). The hub is a thing of beauty, pity it is not seen when the job is finished.
http://ecihotrodbrakes.com/early_che...nversions.html
Old Oct 19, 2014 | 03:18 PM
patmills's Avatar
442forsure
Mike
Thanks for the advice - will check it out - your '66 is very sweet - would love to hear it!!!
Pat
Old Oct 19, 2014 | 04:37 PM
66luvr's Avatar
Originally Posted by patmills
Mike
Pat
Pat,
You are welcome to stop by for a ride whenever you are in the area.
Mike
olds3442
Mar 2, 2014 12:11 PM
62radarlove
Feb 23, 2012 05:35 PM
buddys442
Oct 19, 2011 04:19 PM
russell-t
Brakes/Hydraulic Systems
Apr 30, 2011 05:56 AM
rockethound
Feb 13, 2010 10:22 AM
