64 Cutlass project
Old Jul 12, 2009 | 09:56 PM
vista461's Avatar
64 Cutlass project
Well almost 3 years ago I was cruising Ebay and saw a 64 with a good body at a cheap price, said to my wife "Man I wish I could get that but it pretty far." She said go ahead and buy it , I just had to get rid of a parts car I had. So I bought the 64 off ebay as a no interior or drivetrain roller. I drove out west because here in Wisconsin trying to find a 64 at all is hard and to find a solid body at a reasonable price is nearly impossible. Plus roadtrips are always fun
Here it is right after we loaded it up on the trailer.
We got it home and it sat for a little while. I have been doing a little here and there over the last few years as I have been working fulltime and going to school fulltime so that doesn't leave much time for anything else.
I traded a friend my G-body x-pipe system for a 3 " Pypes x-pipe setup
Dropped in my 455 that had been in two other cars but never left the driveway
I bought an aluminum radiator from www.rocketracingperformance.com
Its a universal one but fits pretty good , no internal trans cooler but I have that handled too.
I pulled out the 3.08 8.2" rear that was stock in favor of a 3.42 geared 71-2 Cutlass 8.5". The rear is still waiting to go in when I have some extra time, I just put new brake lines on it since it was out.
I did find a set of seat cores from another Olds guy, got them for a pretty good price, they were originally from AZ so the covers and foam were trashed, the foam was crispy like, well rice krispies. lol
I have the exhaust all welded together and installed and connected to Hedman 58150 headers.
Going to stay with the drums for now and maybe upgrade later to discs, but it is getting new shoes/rubber lines and dual res. master.
For a graduation present my wife got me a new interior from Legendary, I just have to get a few extra bucks together to have an upholstery guy put it on the seats. WIth my luck I'd do something to wreck the covers. lol
It's going to have the stock style light blue interior.
It was a bucket/console car so I picked up a console at a local swap meet.
I also manage to get a set of 64 dogdish caps over the course of two different swapmeets, so I'll be running them eventually.
That's about it for now
Old Jul 12, 2009 | 10:55 PM
Wasted's Avatar
Looking good, nice find seems like 64s are hard to find anywhere. But that just means you probably will never see one driving next to you on the street.
Old Jul 13, 2009 | 07:22 AM
citcapp's Avatar
Nice work so far, looking foward to more pictures
Old Jul 13, 2009 | 09:02 AM
442scotty's Avatar
Looks great!
Old Jul 13, 2009 | 09:26 AM
vista461's Avatar
Thanks guys.
It does seem like there are more 64s and 65s coming out of the woodwork, but I don't think I'll ever see as many 70-72s.
Old Jul 14, 2009 | 06:59 AM
1964f-85's Avatar
Welcome fellow 64 owner, when converting to discs check out ECI breaks narrow track conversion, it moves the front wheels in 1/2" over drums and 1" over 68-72 dis converions, a must for 64's with wider wheels.
Look for a front 1.25" sway bar off of a mid 70's trans am, fits perfectly and will help keep the car level with the 455 in corners. The rear is good for now, but I would suggest eventully getting an exact fit Moser 9", it is the stock width and will allow for wider tires in the rear. Make sure the headers don't rub the frame, I have never found headers that fit well that I didn't have to mangle to clear the 64's narrow frame rails.
Contact me if you need any advise.
Scott
Old Jul 14, 2009 | 10:44 AM
Originally Posted by 1964f-85
Look for a front 1.25" sway bar off of a mid 70's trans am...
Actually, it needs to be off a T/A with the WS6 package. Lesser T/As may not have it. You also need the end links for the T/A (not for the Cutlass) and the frame brackets and bushings for the T/A to accommodate the larger bar. It's also a good idea to replace the cheesy sheet metal screws holding the brackets to the frame with real nutserts and bolts. The stiffer bar can pull the original bolts right out of the frame. I've routinely found these bars at swap meets for $25-$30 each. Just got another one at Spring Carlisle.
If you install this bar, you definitely want the boxed lower rear control arms and rear bar. The problem with the A-body cars is that they understeer badly. Increasing the stiffness of the front end reduces roll but makes the understeer problem worse (so at least your level as you plow off the road). A rear bar helps with understeer. In fact, these cars like a rear bar that's at least as large as the front one. Unfortunately, the only factory bar is 3/4". Larger ones are available from the aftermarket, but are pricey.
Old Jul 14, 2009 | 01:03 PM
vista461's Avatar
Scott
The 8.5 will be enough for anything I plan to throw at it, but thanks for the suggestion. All ready have the headers in, had to trim some metal , but no biggie. Yeah the stock front sway bar looks kinda small, so I may do the front and rear upgrade.
Old Jul 22, 2009 | 01:58 PM
1964f-85's Avatar
on the rear i used the factory boxed lowers with the stock upper that I boxed in with mild steel, energy suspension bushings and, if I remember correctly, a Vista Cruiser rear sway bar. She is no Porche, but it is a 1000 times better than the stock set up. On the front, I agree with using nutserts on the front sway bar bushing mounts, as I recall the poly bushings/mounts and end matching end links are available at most auto part stores.
Old Jul 23, 2009 | 06:28 AM
Very cool car.
Keep us updated with news and pictures... or else.
Old Jul 23, 2009 | 09:11 AM
citcapp's Avatar
I really like those valve covers. Mind telling me where you got them
Old Jul 23, 2009 | 09:58 AM
vista461's Avatar
A friend of mine had them and I traded some G-body parts I had to him for them. They are TALL. So I won't be running power brakes.
Old Jul 23, 2009 | 02:57 PM
nonhog's Avatar
Registered car nut
Great so far. 455 Cutlass I like the sounds of that !
"I also manage to get a set of 64 dogdish caps over the course of two different swapmeets"
Are you going to run wider than stock wheels since your a bit higher than stock on torque ?
I had some 14x5's changed to 15x8 years back, wish I had them back.
Keep the pics coming !
Old Jul 23, 2009 | 06:11 PM
gearheads78's Avatar
car guy
nice project........... keep us updated on it
Old Jul 23, 2009 | 06:18 PM
vista461's Avatar
I'm thinking I may do some 15x7 in the back and some 14x6 in the front. But finding cheap steel wheels around here isn't as easy as it used to be. lol
People used to just throw them away.
Haven't had much time to work on it lately, I was getting my wagon ready for the trip to Norwalk, now I should be gettting some more time to play around with it.
Old Jul 25, 2009 | 02:23 PM
vista461's Avatar
Well I got the rear in today. Took longer than 4 bolts should have. PITA trying to get it lined up by myself without it falling off the jack. lol
I took the manual steering box off my 64 442 and looks like a mounting bolt broke somewhere along the way in the last 45 years. The other two were a little thin in the middle too. So now I have to get the broken piece of bolt out and get it cleaned up and painted and installed.
Old Aug 22, 2009 | 08:23 PM
vista461's Avatar
Put in a manual steering box and a new ragjoint.
Yesterday I started another project on the car.
This will either turn out well or will turn out as a "but it looked so easy on that website" type project
I was going to pay to have the seat recovered, but I looked in my wallet and I didn't see any money in their with the cobwebs and moths
So I started by taking the old covers of of the pass seat. Yes covers as in two. I bought this seat set from an Olds guy about 45 min away., they are from a 64 Post Coupe. He got them from either NV or AZ I forget, both covers were trashed from the heat and sun. The foam is crispy , but the springs, frame and tracks are in good shape.
Clearly red seats aren't going to go with a blue car, unless I was Superman or something.
Hmm looks like the cloth insert used to be red too
Like an onion these seats have layers
I've taken a ton of pics all over so far to make re assembly easier. We'll see how it goes.
Today I started to make more progress on the pass bottom seat cushion.
Old Aug 23, 2009 | 01:32 PM
Aron Nance's Avatar
Nice little '64. Bet that sucker hauls w/the/455! I had forgotten that in 1968 I had a '64 4 door, think it had the small V8. Ran it a lot to college/home (commuter school) and to Arkansas to see my main squeeze (then). Plain white, cannot remember interior color. Gosh, this gettin' older is gettin' tough, what with the CRS, CHS, arthritis, etc. Still on the right side of the dirt, though!
Old Sep 11, 2009 | 12:43 PM
jims2000lt's Avatar
11.52 @116
Nice 64. The one you picked up looks like the one in my mind that I want to get someday. Good luck with the build. Going to Byron for thr Bop wars?
Old Sep 11, 2009 | 04:24 PM
vista461's Avatar
No not going to make Byron. I have a busy weekend
Old Oct 13, 2009 | 04:32 PM
therobski's Avatar
Correct me if I am wrong the 64 dog dish hub ( poverty) caps are a one year only piece?IMG_0092.jpg
Old Oct 13, 2009 | 04:40 PM
vista461's Avatar
Yeah they seem to be, def different than 65. Was kind of a pain to get a set together for my car
Old Oct 16, 2009 | 03:28 PM
therobski's Avatar
I'm hooked on these 64-65 "post" buggy's. They are getting VERY hard to find.
Old Oct 17, 2009 | 09:55 AM
vista461's Avatar
Yeah they are hard to find, out of the 4 64's I've had only one was a post.
Old Nov 23, 2009 | 10:27 AM
Mongoose's Avatar
If you still want to run power brakes with those tall covers you can use a smaller diameter power booster.
By switching to manual steering you've eliminated the issue of the power steering bracket not clearing those tall covers. I'd love to find a set of those myself (and not have to pay $300-400 for them). Polish them up and they'd be awesome.
Old Nov 23, 2009 | 03:08 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Vista461, What year manual box is that?, and where did you find a new rag joint for it? I need one for a 65'
Also, I have a few ssII Olds wheels here if you get desperate.
Old Nov 24, 2009 | 05:30 AM
therobski's Avatar
Mogoose, I looked at a I believe a 6 inch Corvette P/B booster and the only proplem you would have is you would have to remove the booster to pull the valve cover off to service the engine on that side.
Old Nov 27, 2009 | 05:44 PM
vista461's Avatar
It's "on loan" from my 64 442. I found a repair kit for the ragjoint at one of the Jefferson swapmeets a few years ago
Old Jun 13, 2010 | 04:48 PM
vista461's Avatar
Well not a whole lot of progress, new job, got a motorcycle,etc. But I did convert to manual brakes and put a dual res master on it and new shoes up front . New front lines and brake hoses will be next.
oldstofty
Jun 3, 2019 03:46 PM
Rickman48
Apr 9, 2012 04:50 PM
hubb_99
Apr 12, 2007 07:18 PM
tex70
Dec 18, 2006 12:59 PM
fin170703
Aug 17, 2006 04:59 AM
