View Poll Results: Should I run with it?
Yes its fine
0%
No may wiggle pin loose
0%
Not sure
0%
Need more nfo
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
59 394 oldsmobile rocker bars
Old Feb 7, 2026 | 01:39 PM
59oldsthunder!'s Avatar
Yes I just got brand new set of rocker bars from kanter with rocker arms an stands! One of them where pinned stand is has a wiggle front to back when grabbing it should I run with it or make them send another shaft? Here's pics!
Its that stand with the pin thats wiggles!
Old Feb 7, 2026 | 02:17 PM
Charlie Jones's Avatar
Phantom Phixer
Do you have micrometers and bore gauges?
Measure the shaft several places along it's length:. Measure the inside bore all rockers.
If the measurements vary more than .001
I would send them all back.
Old Feb 7, 2026 | 02:29 PM
Rocker shaft
Yes I got mic I'm thinking the hole for pinned stand on shaft is drilled too big I tried tap it in more an it goes way down and stand is loose not good!
Old Feb 7, 2026 | 04:30 PM
Run to Rund's Avatar
When you assemble a rocker arm set, use moly cam lube on the wearing surfaces so they will break in without scuffing.
Old Feb 7, 2026 | 06:40 PM
Phantom Phixer
Rocker arms and shafts wear. Stands don't.
You might try substituting the original stand for the defective one.
Make sure the oil holes in the shafts point downward, toward the head.
Kanter is not the best choice for parts. Too much cheap chinesium
Old Feb 7, 2026 | 09:12 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Good tip on the holes pointing down toward the head. I learned that the hard way when I had my 54.
Old Feb 8, 2026 | 05:03 AM
I don't know 394's but does shaft stay stationary while rockers "rock" on it? If so then the stand and shaft don't move against each other? That seems how it would work....
Old Feb 8, 2026 | 05:18 AM
Answer charlie
Yes I got info that kanter does use forged rockers but not sure of rest parts I tried original pin did same thing have to try old stand I messaged kanter they need do somethin!
Old Feb 8, 2026 | 05:20 AM
Video of loose stand with pin
I will make a video of how it wiggles later c what I'm saying thx!
Old Feb 8, 2026 | 06:10 AM
Phantom Phixer
You are correct.
Old Feb 8, 2026 | 06:16 AM
Phantom Phixer
Those sure look like nodular castings to me, not forged.
Old Feb 8, 2026 | 09:03 AM
^^^THIS^^^
Precision measurement will tell you if the shaft and rockers need to be replaced. A magnetic dial indicator will also tell you how much the rockers wobble.
FWIW, when I was a soldier I put 371 rockers on the 394 in my 64 98. The rockers had worn so much that they started to chatter. This is before I knew about Kanter. I got the parts from a 63 Dynamic 88 I found in the salvage yard.
Old Feb 10, 2026 | 02:20 PM
Rocker arm shaft
So with my caliper of great quality I took this reading the hole for pin an oil as well on bottom showed these readings! So makin progress!top reading new shaft bottom oem!
Old Feb 10, 2026 | 06:36 PM
Phantom Phixer
The hole in the new shaft is .004 larger than it's supposed to be.
No wonder the pin is loose.
Send that stuff back and get your money back.
Get your stuff from Egge or Fusick or Terrill Machine.
Old Feb 11, 2026 | 12:24 PM
Rocker bars
Yes like that song Elvis used to sing return that crap to sender!😡
Old Feb 12, 2026 | 02:06 PM
Rocker bar returns
Hey olds fans so this what kanter sent me for what need to do
Old Feb 12, 2026 | 07:35 PM
Phantom Phixer
Do you have the old original rocker stands?
If you do, try installing the stand, with the pin, on the shaft.
Tap the pin in and see if it's tight
If it is, you're good to go.
Stands don't wear.
jensenracing77
Jan 31, 2023 06:01 AM
tav
Nov 15, 2017 03:01 PM
4424fun
Aug 19, 2016 12:31 PM
2nevets
Nov 19, 2011 06:40 AM
daddysflatty
Aug 14, 2011 09:03 PM
