1970 442 Pace Car Restoration
Old Dec 20, 2012 | 12:56 PM
  #41
costpenn's Avatar
Charlie - two things from your pics:
When hooking up the lines running to the cylinders from the pump, is there a port on the pump that should go to a specific line going to the cylinders? In other words, is one of the outlet ports specifically for going up and the other for going down - and if so, how do you know?
I noticed you mounted the condenser on the blower motor with the mounting tab between the blower motor and the cowling - is this the way the original was? I put mine between the bolt head and the blower body - is this incorrect?
Thanks,
Joe
Old Dec 20, 2012 | 04:28 PM
  #42
charlierogers's Avatar
Thanks,
Joe
the pump ports are specific, i purchased a complete hyd set and when bolting things up and laying lines out it is kind of self explanatory {sp} the blower motor cond/supressor is in the correct spot. if you look at your cond with the mount tab you will see a little barb that digs into the firewall for ground. hope this helps.
charlie,,,
Old Dec 21, 2012 | 04:26 PM
  #43
69442C's Avatar
Hi Charlie,
Your car is looking great and it looks like you are well on your way.
I noticed you installed the rear speak and grille. When the top is done and the well liner is installed, you'll need to remove the speaker grille and cut a hole in the liner around the speaker and then put the grille back in place but now over the liner. Otherwise, the well liner will cover over the speaker and grille which will block the sound.
Brian
Old Dec 24, 2012 | 05:58 AM
  #44
ScottoW31's Avatar
Looks great!
Old Feb 21, 2013 | 05:39 PM
  #45
getting all the small stuff installed on engine before putting front end on. still looking for 70 radio amp .
Old Feb 21, 2013 | 05:43 PM
  #46
more pics,,,
Old Feb 21, 2013 | 05:48 PM
  #47
more pics, after a couple different windshields we finally got a great fit.
Old Feb 21, 2013 | 07:32 PM
  #48
72w442's Avatar
72 442 Conv Viking Blue
Thumbs up
Looking good charlie, are those the Inline tube vacuum hoses on your motor? I was thinking about picking up the set for my motor, How is the quality?
Good to see you getting close.
Old Feb 21, 2013 | 11:04 PM
  #49
70Post's Avatar
Charlie - on the D side of your intake, forward of the carb...there's two holes in a "pad" on the intake one of which is threaded. Don't know if your application uses a throttle stop "plunger" type setup(nothing installed there in your pics) but if it doesn't then be aware that one of those holes goes clear through to the intake port. Leave it open and you'll have one massive vacuum leak. For cars that didn't use the throttle stop "plunger" setup you would install a bolt in that hole to plug off the opening.
Old Feb 22, 2013 | 03:54 AM
  #50
fjross's Avatar
Originally Posted by 70Post
Charlie - on the D side of your intake, forward of the carb...there's two holes in a "pad" on the intake one of which is threaded. Don't know if your application uses a throttle stop "plunger" type setup(nothing in installed there in your pics) but if it doesn't then be aware that one of those holes goes clear through to the intake port. Leave it open and you'll have one massive vacuum leak. For cars that didn't use the throttle stop "plunger" setup you would install a bolt in that hole to plug off the opening.
I was thinking the same thing. On my 71, I believe it's called a dash pot and was very difficult to find one in working condition or a condition that was acceptable for my restoration.
Old Feb 22, 2013 | 09:29 AM
  #51
how ya been? yes the vacuum hose set along with the date coded spark plug wires are from inline tube. i have been very happy with there products along with there tech help!
Old Feb 22, 2013 | 09:45 AM
  #52
Patton,, fjross, thank you very much on the tip/advice on the throttle stop/ dashpot. was looking at that a couple days ago and was wondering what the heck goes there. i think i will plug it until/if i can find a working correct piece. to be honest i dont know why olds did not put the w-30 intake on all the 442's as the only difference is the weight. it would of been nice if olds gave the w-30 a more fitting intake {hi rise, maybe a holley} for its top dog. it might bother some of the purest olds guys but i could not put the stock cast iron int back on. i just painted it and put it in a wooden crate.
Old Feb 22, 2013 | 02:27 PM
  #53
i thought the dashpot was used for a/c or 4spd cars only? or is it correct for auto cars too?
Old Feb 22, 2013 | 02:38 PM
  #54
Post
fitting the air cleaner, love the gas tank stencil
Old Feb 22, 2013 | 08:56 PM
  #55
70Post's Avatar
You saved some money!!...not applicable to your car being non-AC/Auto trans.
You just have to spring for a bolt and you're done there.
Old Feb 23, 2013 | 04:50 PM
  #56
pcard's Avatar
70 Cutlass SX
Hi Charlie - I may not be right but are you missing your TVS (termostatic vaccum switch). Also, on my harness the green wire goes to the coolant temp sender, and the blue/white one goes to the oil pressure.
Your car looks amazing I hope to see it one day. I hope you are going to drive it!!!
Old Feb 27, 2013 | 04:58 PM
  #57
pcard, that harness is from m&h electric and the way it is laid out {wire length to senders} that is the only way it fit nicely. with that said and a little investigating thru past threads it seems you are correct! thanks for the tip. as for the tvs,,, i believe it is a little diff with the oai / w-30 setup. maybe some of the experts will chime in?
Old Feb 27, 2013 | 08:16 PM
  #58
70Post's Avatar
I think you may need the TVS ('70 version) in the spot on the P side front water passage of the intake where you currently have the large square pipe plug. If I'm looking at this Olds manual correctly I believe the 442's with auto (NON-AC) used the TVS.
If you are going for the W30 look, then a '70 W30 Auto (NON-AC) would not use the TVS setup and the plug you have is correct. '70 W30 Auto w/AC would use the TVS setup.
Old Feb 27, 2013 | 08:51 PM
  #59
pcard's Avatar
70 Cutlass SX
Charlie: I understand about the harness fit - my harness does not run straight accross the valve cover either but loops toward the front.
As to the TVS, you and Patton are correct, with reference to the section 6 page 32 of the engine assembly manual the W30 Auto Trans does not take the TVS with no AC.
If you are going to drive the car: I have the TCS installed, but I bypass it when I drive the car so that I get manifold vacuum to the advance at all times - the engine seems to like it.
Old Feb 28, 2013 | 10:40 AM
  #60
thanks for the clarification guys! this should answer the look i am going after!
Old Feb 28, 2013 | 10:54 AM
  #61
forgot a shot of the driveshaft. color appears lighter in picture.
Old Feb 28, 2013 | 11:28 AM
  #62
pcard's Avatar
70 Cutlass SX
Beautiful!! Will it be ready for the Nationals? If it is I do not stand a chance of winning any prizes.
Please tell me you are going to drive this car.
Old Feb 28, 2013 | 02:05 PM
  #63
thanks for the compliment! i should tell you this is my wifes car. yes she will drive it some. to be honest this started as a quick/light resto to be driven daily and turned into a monster. not really the best idea for us money wise as we have a 4 kids that one day will need to go to college. she has it signed up for a big show in springfield il, in july i believe. not sure if this is the nats? i am not really into points/judging shows. but now that i have a car that is built to a higher level i am looking foward to a big show! i talked to lee pear's {1970 w-30 ragtop. great guy} at a points show a year and a half ago and some of the nonsense he told me about points and deductions was just silly. will see
Old Feb 28, 2013 | 03:36 PM
  #64
2olds's Avatar
Beautiful nice job.
Old Feb 28, 2013 | 07:44 PM
  #65
Pace car girl's Avatar
Thanks for the compliments, guys! I'm looking forward to having the car done & I can't wait to drive it. It's been really cool to watch it come together so beautifully. Larry has done an amazing job!
Yes, I will be driving the car (on nice days) & doing some shows with it. I am planning on taking it to Nationals. I emailed Gene & he was very helpful in getting me signed up & registered. I've never had a car in a show to be judged before. There's a lot more to it than I expected!
Old Mar 1, 2013 | 06:28 AM
  #66
pcard's Avatar
70 Cutlass SX
The same thing happened to me, I started out wanting to redo the paint, upholstery and safety gear. Ended up with a brand new car. Our (my wife and mine) biggest motivation was a personal, stark reminder that life is unpredictable and can be shorter than you think.
I am glad you will be at Nationals, and look forward to meeting you there.
Cheers, Peter
Old Mar 1, 2013 | 07:02 AM
  #67
Del70's Avatar
very nice. - fyi oil fill caps on the 70 are flat. the heater hose from the factory were routed above the alternator bracket.
Old Mar 1, 2013 | 04:14 PM
  #68
was not sure on the routing on the heater hose, we tried it both ways and it seemed a better fit under the alt bracket especially with the protective wrap. did not know the oil cap difference though. thanks for the tip!!
Old Mar 1, 2013 | 04:19 PM
  #69
progress,, LOVE those red fenderwells,,,,,,,, it must be a W-30
Old Mar 1, 2013 | 04:22 PM
  #70
more pictures,,,
Old Mar 1, 2013 | 04:26 PM
  #71
i gotta say those red fenderwells pop nice against the white paint
Old Mar 2, 2013 | 02:24 AM
  #72
Del70's Avatar
I referenced the 70 assembly manual for the routing info. Thanks for posting the progress...
Old Mar 2, 2013 | 04:30 AM
  #73
RALLYE KID's Avatar
FYI all these things and the red inner fender wells you will get ding for at the nationals.
Old Mar 2, 2013 | 05:15 AM
  #74
Octania's Avatar
Very nice, what fun to redo a car like that!
Any chance you found the frame VIN stamp in all that, photographed it?
"some of the nonsense he told me about points and deductions was just silly"
Well, sure, you have to understand that, in that arena, all the offerings are very nice, so in order to have a winner, you have to resort to nitpicking the smallest of details sometimes. [Amount of overspray on the mufflers for example] Also, opinions vary regarding e.g. exact shade of gloss of the various blacks used, which was used where, how well yours matches what they think it was/ should be.... etc.
Oil fill cap is easy- I see the NOS one on epay at $90:
http://www.ebay.com/itm/NOS-1967-68-...ce8c0a&vxp=mtr
or somewhat less elsewhere for [presumably] Chinese "copy" unit. Painted engine color I believe. As should be your rocker cover bolts and lower alt bracket. While not 100% sure, it looks to me like your oil level indicator has too long of a handle. A used OEM one might work better for showtime- more of a short "P" rather than a long tall "?" shape. Upper alt bracket at intake should be just a hex head bolt, not flanged. No flat washer under nut at top PS bracket to 5/16 boltstud.
And Lord I hope you have the right flavor and angle of orientation of the wireform hose clamps.
Mind you, I am not a show car judge, but I went over the photos above and noticed things that show car judges may find require a pts deduction, especially if the car next to you is "more correct"
Motor Mount pads to frame should have Lock Washer Nut topside not underneath- frames were upside down when first few parts were put on? PN sticker for example [on the '66 I helped with] was upside down.
The intake's heater hose nipple looks wrong- brass? Maybe it's zinc plating? Does it have a proper restriction of about 1/4" ID- if not yo may rupture your heater core or at least have objectionable coolant flow noise.
PS pump paint daub missing?
firewall stamps were present on every factory original car I have seen- "EE" or similar, usually two or more.
Similarly, on the original '66, we found wax pencil markings "943" or similar- which I believe was the job # as it came down the line. We duplicated these markings in size and location as best we could. Of course, if yours were obliterated in previous work, you could only guess at what and where they were.
Fuel pump ac logo missing?
date coded diodes in the alternator? [Seriously, I have heard Corvette folks agonize over this level of detail...]
The exact shape of the oil pressure sender- Ck this one for example:
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
choke adj appears to be off- perhaps an early photo- the adjusting line should be near the other indicating lines.
carb air horn screws have been black plated not gold zinc plated on every original carb I have seen.
Heavy flat washers are not used under the bolts at the intake's U bracket- the bracket serves that purpose- but then I am not used to AL intakes of the 1970 models, so I might be wrong there.
throttle return spring should be a double- a redundancy for safety in case one breaks.
Seems a shame to drive something like that - all them pretty part number tags are going to get wasted.
Old Mar 2, 2013 | 05:47 AM
  #75
i will be the first person to say i know nothing about how the point system shows work. thats why i think it is great that there is so many friendly olds guys here with alot more experiance{sp} than i have and are helping me out along the way. i know some of the olds purist will frown on the red fenderwells and w-30 intake but thats ok.{the correct parts are restored and boxed up} in the end i would rather the olds community appreciate the car for what it is rather than the judges and the points.
Old Mar 2, 2013 | 12:47 PM
  #76
good info here! some things like firewall stamps, double throttle spring, and some of the other things we knew about and are in process of doing. i think we will take care of some of the other things as they seem simple enough. what a eye on the rear heater nipple. we are waiting on the correct black nipple with the restrictor in it. paint daub is on power steering box.i did not know one went on the pump? i think the a/c logo is on the fuel pump. is that the proper/correct oil pressure unit in the ebay link? yes we did find the matching vin on frame, i think it was right by the driver door if i remember correctly. i think we got a pic of it, cant really remember with all of the pics we have taken before tear down and after. i need to decide where to stop on the little things otherwise i might go nuts lol. i could not bring myself to have all the correct overspray put on the car. seems like just a shame to do this after all the hard and meticulous work done? this is just my opinion i know others feel different. anyway i do appreciate the nitpicking as then i can decide what i am willing to change.
thanks charlie,,
Old Apr 15, 2013 | 07:24 PM
  #77
a few updated pics. with a few changes for correctness{sp} forgot to install correct oil dipstick but i got it. been slow going due to money issues not a whole lot left now. should have bumpers back in a week or so. new firestones tires should be in soon. if you guys watching could check pics closely for correctness and chime in that would be great. after careful reading and checking of assy manual i can see they really do have detailed pics of orientation of hose clamps, headlight wiring grounds pointing in specific directions, ect,ect, sheesh! oh well we are trying to go just as manual says. located nos oil fill cap, nos oil pressure guage, correct used oem oil dipstick, nos small ear, raised letter, rc15 rad cap.
charlie,, notice 2nd pic, stickers are not on yet. was wondering where exactly the smaller coolant sticker goes???
Old Apr 15, 2013 | 07:27 PM
  #78
pics,,
Old Apr 15, 2013 | 07:32 PM
  #79
pics,,,
Old Apr 15, 2013 | 07:35 PM
  #80
pics,, hope you guys are not getting bored.
