1968 Cutlass S Holiday Coupe - "Millie" pt 4
Old Nov 12, 2010 | 07:10 AM
arodenhiser's Avatar
STOP call'n it a Chevelle
After 4 months, 4 days and 2 hours since being delivered to paint, she was loaded back on the tow truck to come home.
Next post - Starting to reassemble.
Adam
Follow Millie's rebuild here...
Part 1 - As purchased - Play Time https://classicoldsmobile.com/forums/major-builds-projects/27563-1968-cutlass-s-holiday-coupe-millie.html
Part 2 - Tear down - Metal Work https://classicoldsmobile.com/forums/major-builds-projects/28997-1968-cutlass-s-holiday-coupe-millie-pt2.html
Part 3 - Paint Shop - New Stripes https://classicoldsmobile.com/forums/major-builds-projects/28998-1968-cutlass-s-holiday-coupe-millie-pt-3-a.html
Part 4 - Reassembly - Rebuilding https://classicoldsmobile.com/forums...ie-pt-4-a.html
Part 5 - Headliner - Some Interior https://classicoldsmobile.com/forums/major-builds-projects/29699-1968-cutlass-s-millie-pt-5-headliner.html
Old Nov 12, 2010 | 07:18 AM
citcapp's Avatar
Lookin sweet
Old Nov 12, 2010 | 07:46 AM
Cleaning up and upgrading
So she now looks nice and pretty on the outside. Inside is another story. I know she was masked and papered during paint, but, it looks like a war zone inside due to the dust and debris. First step vacuum. Second was to use Simple Green, hot water and a plastic tire scrub brush to the entire interior.
It looked like after vacuuming....
So after scrubing and washing, then wet/dry vacuuming, she got two days to dry completely. Then a nice coat of brushed on rust proofing paint.
Another couple days to let the paint cure. Then came a task that was long, sticky, tiring. I decided to sound proof the entire interior, floor, roof, rear side panels, kick panel and sail panel areas with rubber based FatMat. It's a product like Dynamat. It is like trying to wall paper your car with self-adhesive wall paper that will pull paint of instead of peeling off.
I will be doing the doors and trunk areas once the windows and lights, etc are back in.
Next task is the windows and front end headlight areas.
Adam
Part 4 - Reassembly - Rebuilding https://classicoldsmobile.com/forums/major-builds-projects/29001-1968-cutlass-s-holiday-coupe-millie-pt-4-a.html
Old Nov 12, 2010 | 11:35 AM
Refinished Front End / Grill Parts
It seems like this would be a good spot to show some of my refinished parts. My original headligt housing and grill were painted black. They all were cracking and peeling. I repaired the cracks and made/replaced some broken.missing tabs. Then all parts were hand sanded with 260 followed by 400 grit sand paper. The left housing was so bad I got a donor from filbily, thanks Kurt. I used Krylon's Dull Aluminium and SEM Trim Black for the paints.
Driver side headlamp housing.
Passenger side core.
Grill
Here is how my parts turned out. Three coats of each colour with a little sand between coats 1 and 2 to smooth out few spots. It is closee the factory. I like the black grill over the factory aluminium. The black and aluminium line is not in the correct spot. I choose this line so it would flow better with the black grill. I like the finished result.
My hood louvers/grills were painted black. These were chemically stripped. Cleaned and painted. It was a very long process to mask all the tiny thin edges but it worked out well.
Next post - Parts go back on.
Adam
Old Nov 13, 2010 | 05:32 PM
I finished off the front end today. The head light housing, lights, bezels abd chrome/stainless trim all back on. It might need a little more tweaking to get the lines all perfect. Here's how it looks.
The only thing missing is the hood ornament.
Next I have to finish the windows....
Adam
Old Nov 13, 2010 | 06:05 PM
Rickman48's Avatar
Good job - funny, as I had the lighter blue on a '69 442 coupe, with the 3-tone blue bucket interior. Was going to paint that side stripe too, with a darker blue! 30 yrs. ago! [another I shoulda kept!!]
Great to see it on a cutlass!
Love the pics - keep 'em coming!
Old Dec 13, 2010 | 02:42 PM
agpilot442's Avatar
Man She is a Beauty!!
Keep up the good work
Old Dec 13, 2010 | 03:39 PM
Beob's Avatar
I like, lookin real nice!
Old Dec 13, 2010 | 04:40 PM
Ranzan's Avatar
Getting There
that thing is sexy .............. nice job
Old Dec 13, 2010 | 06:26 PM
gearheads78's Avatar
car guy
Looking good man.
coldfire
Aug 13, 2019 08:08 PM
arodenhiser
Dec 16, 2010 01:57 PM
arodenhiser
Nov 12, 2010 06:44 AM
arodenhiser
Nov 12, 2010 05:31 AM
arodenhiser
Oct 4, 2010 01:47 PM
