seat belt bolt removal
Old Dec 2, 2008 | 10:29 AM
68Tom's Avatar
I'm having a difficult time removing my rear seat belts. There's no rust on the bolts, but they're still not budging. Are they reverse thread or something? Or are they just seriously bolted in?
I've used PB and WD40 with a breaker bar to no effect. Might need to get a second person involved as it's tough to get good torque on it as the 13/16" socket slips off the bolt easily.
Ideas?
Old Dec 2, 2008 | 10:52 AM
gearheads78's Avatar
car guy
Grind a socket down so the inside taper is gone. Since the bolt is so short when you add the inside taper to the socket you barley have any meat to hold the bolt. If you don't have a way to cut a socket push hard pressure down on the socket. No reason you cant get it with a breaker bar.
If for some reason the bolt hex is stripped the best way to get it is to weld a nut to the head. Just take precautions with carpet so you don't burn the car down.
Old Dec 2, 2008 | 10:56 AM
68Tom's Avatar
Yeah, I think I'm simply going to have to put pressure down on the socket/bolt while someone handles the breaker bar.
Seat belts are otherwise in nice shape. Just clean 'em with a bit of liquid tide and they'll be as good as new. Now I just wish the guy didn't discard the front belts.....
Old Dec 2, 2008 | 11:17 AM
L-O-N-G Breaker bar [and get some help]
Old Dec 2, 2008 | 11:45 AM
The seat belt bolts have a very aggressive nylon locking patch on them. They are very difficult to unbolt. They are conventional RH thread. Just get a longer breaker bar.
Old Dec 2, 2008 | 05:28 PM
Redog's Avatar
Air Rachet
Old Dec 2, 2008 | 07:38 PM
rocketraider's Avatar
Oldsdruid
Air IMPACT. An air ratchet will never have enough torque to break them loose. It'll flip you upside down first.
Move into the 70s, when they started using TORX head bolts back there. I had one hell of a time getting them out of the Hurst.
Old Dec 3, 2008 | 02:23 PM
68Tom's Avatar
Well, sadly I have no compressor where I'm working on the car.
Oh, man. I hate those TORX bolts.
Old Dec 4, 2008 | 03:53 PM
Alb's Avatar
Alb
Had the same problem. I put some heat to it. The floor area, not the bolt.You want to heat the nut threads and not the bolt threads.
Alb
Old Dec 4, 2008 | 05:13 PM
rocwal
Guest
Posts: n/a
Like Joe stated ,if they are factory installed they used a plastic compond to seat the threads for saftey reasons ,use a long breaker and socket . never had one that would not come out ,unless floor was rusted then the whole backer plate twist off.
rocwal
Dan B
Old Dec 4, 2008 | 05:17 PM
bigoldscruiser's Avatar
2 '66 98's
Look under the floor. The bolts should be protruding. Apply the heat or loosening juice from the bottom.
Old Dec 4, 2008 | 07:53 PM
Once again, the bolts are retained with plastic locking material. Heat will destroy this material. If you heat the bolts, I strongly suggest that you use new ones to reinstall the belts.
W-27
Jun 17, 2015 01:35 AM
Rocketbrian
Jan 20, 2015 06:59 AM
denf221
Nov 12, 2014 08:57 PM
Beob
Apr 12, 2011 07:59 AM
Olds98
Aug 6, 2010 05:02 AM
