Dual Gate Shifter
Old Jan 14, 2011 | 07:24 AM
frasco's Avatar
1970 Cutlass Convertible
Dual Gate Shifter
I have a 1970 Cutlass bucket seat car. I want to change the origianl shifter to a dual gate.
Does the dual gate bolt on to the same mounting plate that is used on a standard shifter?
--Scott
Old Jan 14, 2011 | 08:36 AM
rptw32's Avatar
--Scott
NOPE
the dual gates have their own mounting brackets - although the rear holes in the dual gate bracket doest bolt up to same two rear holes as the standard floor shift - the console is marked on inside underneath that shows where you have to cut additional material out for the dual gate top plate to mount properly - then the top plate and front top extension cover are different for that vs. standard shift .
not a hard conversion if you have the correct pcs - ( the shifter cable is also different for dual gates - it's slightly longer than the stock cable to trans as well.
Rgds
Old Jan 14, 2011 | 08:55 AM
frasco's Avatar
Dual gate
If u have a few minutes could u call me 314-607-9811
Old Jan 14, 2011 | 09:18 AM
vette442's Avatar
Type in "Dual Gate" in the search function above - there are several threads with lots of good information on converting to a 70-72 Dual Gate setup.
Terry
RS3SDL2MG
Hurst/Olds
Oct 7, 2009 05:42 PM
1968 42
Apr 24, 2008 02:35 PM
1968 42
Apr 3, 2008 05:15 PM
